Previous in Forum: cooking onions   Next in Forum: Sump Pit Sizing
25 comments
Removing a Stuck Coupling
09/24/2008 3:23 AM
HOW DO I REMOVE A STUCKED COUPLING HUB(GEAR TYPE) FROM THE SHAFT. I HAVE TRIED HEATING THE COUPLING AND USING A PULLER. IT FAILED TO COME OUT. THE SHAFT IS 100mm DIAMETER.
THANK YOU.
Good Answers: 230
Re: MR.
09/24/2008 4:37 AM
Hello jacky
You don't need to type all CAPITALS, we can read OK without spectacles, thanks.
You do not explain the location of the shaft + frozen gear hub.
Is this in a large truck gearbox situation. and for a better answer advice re the location would be helpful.
Is the gear hub keyed or on a taper, or both?
I presume you have checked that the gear hub is not actually threaded (LH or RH thread) onto the shaft.
If heating and use of a puller did not enable dis-assembly, it may be possible to cool the shaft and when the shaft is cool enough, apply sudden heat plus the puller.
Cooling could be done via liquid CO2 or liquid N2 - but you would need to ensure the shaft metal was not embrittled by the sudden cooling.
When the shaft was sufficiently cooled, oxy-acetylene or propane torch could be applied to the gear hub, and when that was sufficiently heated, the puller applied.
If all else fails, you may need to grind a pair of opposite side slots in line with the shaft along the hub, the seized gear then has a pair of slots into each of which in turn a heavy cold chisel placed into the slot, and is firmly struck with a 4 pound or larger hammer.
Of course that last above procedure destroys the seized gear hub, which often splits very rapidly, so eye and other protection should be used - we often used to wrap the gear hub in cloths which prevented personal injury during that "split open the slot" procedure.
Advise your further details and/or progress, with
Kind Regards....
Re: MR.
09/24/2008 5:04 AM
Hello, Sparkstation.
the hub is keyed but not threaded nor tapered. the frozen hub is on a motor that drives a draft fan.
i am going to try cooling as suggested.
( can you notice my caps are off?)
thank you.
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
Re: MR.
09/25/2008 8:07 AM
The main thing is...take your time! Don't try to pull it off by hurrying along. As you've heard, use lots of penetrating oil, and also, don't beat it to death. Use your pullers smoothly and steadily, and if it doesn't come off the first time, let it stand, and try again later. If you do this, you'll get it off eventually.
I have seen pulleys/gears that have stood for decades that were eventually removed by the puller/oil/heat method. One time took three weeks on and off, but it did come off with minor damage.
Patience is the key.
Speak softly and carry a big stick.
Re: MR.
09/25/2008 11:14 AM
PB Blaster!!
will help break apart almost anything.
Good Answers: 58
Re: MR.
09/24/2008 5:12 AM
Sorry - wrote my reply before seeing your response.
Re: MR.
09/25/2008 11:56 AM
Hey Sparky,
After 30 years in the business , I could not have come up with a more comprehensive answer than yours. !!!!!
Had an exact same problem once , and even though the manual said interfrence fit, the hub was actually screwed !!!!! direction of rotation is important since it dictates the type of threads (LH or RH).
Only other suggestion is when using liquid penetrant to free up the sized components, you may need a product such as Kroil .
Works fine for me. Said to be the most penetrative oil in the market.
Learn more, Do more , Be more
Re: MR.
11/05/2010 2:28 PM
hey hi there
its my third day & i have tried to removed the hub by heating n pulling for
pulling i have made a puller with 20mm thick plate even though its getting bend
i have given 400 bar pressure with hydraullic jack too
now only i have to try by cooling the shaft by N2....
Re: MR.
11/07/2010 1:28 PM
A laast i made it in the fourth day busing big nozzle torch by heating evenly
& raising the pressure of hydraulllic pressure at 310Bar...
Good Answers: 58
Re: MR.
09/24/2008 5:07 AM
I do not have any magic suggestions except that heat is usually the most successful.
I assume that you are talking about a keyed parallel shaft to coupling hub fit?
If so, clean everything, use lots of penetrating oil, attach and tension your very good quality puller, heat the coupling on one side only until it is seriously hot (only you know how hot that can be, I do not know anything about material or duty or the machine), give the coupling a number of good healthy cracks with something that will not damage it too much. Hope for the best and then let cool, add penetrating oil and try again heating on a different side of the coupling. I prefer to use a C shaped backing plate and a strong-back with a couple of M16 stud bars to pull on rather than most commercial legged pullers.
Good Answers: 266
Re: MR.
09/24/2008 7:46 AM
Cut it off a long the keyway. Right angle grinder with cut off wheel works well. At the keyway you can get all the way thru with out damaging the motor shaft Once thru the one side it may relieve it enough that a puller will take it off. Small chisel as a wedge in the cut will open the bore to add some relief.
Re: MR.
09/24/2008 8:04 AM
hello, ozzb.
Truth is i want to re-use the hub so, i am going to attempt cooling the shaft and heating the hub then applying the puller as earlier suggested by 'Sparkstation". I will only use your suggestion if my attempt of smooth removal fails.
Thank you.
Re: MR.
09/25/2008 7:36 PM
I think you will find your problem is the key. if it is half moon type try getting a sharp chisel or appropriate screwdriver UNDER the lip and prising up Or use a drift to tap down on the key and break it loose in the slot. Make sure there aren't any locking grub screws securing the key in place, they can be hidden under surface grime.
If you do use heat, heat a line along the keyway. I would try not to heat it as the heat can damage the coupling, particularly the tooth hardening.
try using a Hydraulic puller. They are far more effective than regular ones in these situations.
Good Answers: 16
Re: MR.
09/25/2008 9:50 PM
"if it is half moon type try getting a sharp chisel or appropriate screwdriver UNDER the lip and prising up Or use a drift to tap down on the key and break it loose in the slot."
An appropriate screwdriver does not exist for this or any other striking, bending or prying application and if you were to go this route it probably would have little effect on a 100mm shaft application anyhow. And you may be explaining to someone how you got a foreign object wedged in the keyway and broken off thus causing you to destroy the hub in order to remove it.
And Mr. Burns won't be happy...
Re: MR.
09/25/2008 10:30 PM
There are specific screwdrivers made for just such work. They are quite different in construction to a normal screwdriver, normally having the shaft running all the way through the handle, terminating in a metal top. the shaft steel is also different, having far more spring and the tip is chip resistant. Obviously you can't use them in electical applications. Stanley is one manufacturer however you won't find them in kits or the local hardware as they are a specialist tool.
Re: Removing a Stuck Coupling
09/25/2008 3:06 AM
Do all the above, but most important keep tension on the puller whilst you are doing it, hitting the protected shaft and/or hub will often break the surface welding.
The nice thing about Standards is there are so many to choose from.
09/25/2008 4:17 AM
Do not use a hammer as you may cause damage to any bearings on the same shaft, unless of course your aim is to replace the bearings in the first place. Then tighten up the puller hard and give it a few sharp hits with a hammer, sometimes this will start the ball rolling (so to speak!).
If you cannot see a keyway (look for a slot either in the hub or the shaft, use a mirror to check between motor and pulley), it is most probably threaded. The direction of the thread will be so that the hub/thread tightens when the motor is loaded by the fan....turn it in the opposite direction to loosen.
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
09/25/2008 9:42 AM
I am of the same mind as you Andy, I have had a lot of pulley and gear hubs that have been solidly stuck such as this. After applying a bit of heat, I find that when I have the right puller on, a sharp strike to the puller center shaft will definately get the hub moving.
This is of course after many foul expletives, and usually followed by a victory dance.
If necessity is the mother of invention then is laziness the mother of necessity?
09/25/2008 12:14 PM
Perfectly put!!
You remind me strongly of my own experiences in the RN......its still a good memory!!! (inspite of the swearing till it was off!!)
That "sharp" tap with the hammer on the end of the puller was a great help.....and did not damage anything either.
Good Answers: 16
09/25/2008 9:19 AM
Patience is key for sure. But also keep in mind that when the heat is applied, it should be done with a Multi-Flame heating torch (rose bud) and not your typical cutting torch. The typical torch takes too long to heat sufficiently and you typically end up transferring too much heat to the shaft thus canceling out your expansion efforts.
Have your puller set up and ready, heat the coupling (very hot and fast), immediately pull and don't stop pulling until the coupling is completely off.
Here is the hard part, if it does not move you absolutely need to wait until all parts have cooled completely. Be careful trying to cool the shaft or coupling to quick after it's screaming hot. I have seen guys use the "quenching" method, but I have never seen this method actually authorized by any gear or coupling manufacturer.
09/25/2008 9:32 AM
Following on from Tims comments on heating. Traditionally boilermakers "heat and shrink" by heating an area and pouring water on it, be careful not to shrink the coupling and make matters worse.
Hobbies - DIY Welding - pipewelder
09/25/2008 11:03 AM
It sounds to me that you may not be heating the coupling hot enough or you may be heating the shaft while you are heating the coupling. Also try and select a puller that is way stiffer than you think is needed because if it flexes it won't work as well. One thing you may try is to use a hydraulic type puller, heat the coupling all around to a dull red color, mount the puller and once you have a applied the force start to "ping" the coupling with a hammer. Many times I have seen the vibration from a hammer strike (or several) will cause the coupling to release. Also you may need move the puller around the coupling several times so that the force is applied to several different locations. If the coupling moves a little and freezes up again you may need to re-heat it during the process.
pipewelder
pipewelder
09/25/2008 12:28 PM
I had a coupling one time, that was rusted and the outer surface was covered with a layer of build up that was hiding 2 holes that had recessed allen set screws.After cleaning out the holes and loosening the set screws,it came right off. Skipper
Hope for the best,Expect the worse,Take whatever comes
09/25/2008 1:58 PM
If you can get the shaft out put it into a hydraulic press and push it out. Heat and cooling will all help too. You could mount the shaft vertically between two large wooden blocks and hammer it out with a sledge hammer protected by hardwood or copper dolly.
Peter Jensen
09/25/2008 4:43 PM
It has to do with obtaining max temperature differential between coupling hub and shaft.
You need an hydraulic puller (or press if space allows) (50 to 100 tonnes)fully preloaded. Then, if bare shaft section is available pack this section with dry ice and let soak to lowest temperature. When that has been accomplished you have to heat the coupling hub with the largest torch available. Try to apply an impact hammer in the shaft direction on top of the hydraulic ram. Monitor temperature differentials (shaft & hub) with infrared thermometer and make sure hub heat does not flow into shaft section. You really have only seconds to accomplish this after the heat is applied. Remeber that steel expansion rate is about 6 mils/inch dia/100 degree F>
Best wishes, Rene Vanderspek, Toronto, Canada
Good Answers: 123
10/06/2008 8:31 PM
PATIENCE!
If there is one thing I have learned it is that you are not in control in these situations. I have had some luck in the harder ones by applying heat with the hottest torch available Sometimes a Mapp torch, sometimes oxy-acetylene. Keep steady tension on with the puller. Sharp raps with a steel hammer in a non critical area. The idea is not to bend, or distort the flange, but to start vibrations. Try cooling with penetrating oil. My favorite is PB blaster as noted before. I would try to rap the flange in line with the length of shaft. Another effective method to use is to shock the play out of the mechanical gear puller. As you tighten the threaded shaft into the puller, all the play in the puller threads are forced in the direction away from the shaft. Take the 4 pound or larger hammer, and drive the puller's threaded shaft into the shaft. Again. Again. Now re-tighten the threaded shaft again. Repeat as needed. Remember the first thought PATIENCE. Good luck.
Bob
Register to Reply 25 comments
Andy Germany (2); Anonymous Poster (6); bob c (1); djacob (1); double_j_b (1); jacky (2); ozzb (1); pipewelder (1); Pj3ns3n (1); Skipper (1); Sparkstation (1); standarded (1); The Prof (2); Tim in Mexico (2); Tonymech (2)
