Previous in Forum: Removing a Stuck Coupling   Next in Forum: Landmines and Seismic Sensing
9 comments
Sump Pit Sizing
09/24/2008 4:35 AM
Good day to all I'm a newbie here so please bear with me with my question. I'm just confused on how to size a sump pit for basement parking (commercial)..what parameters to be consider? some say to consider flow for sprinklers, others say it should not because you'll get a high capacity pumps..could someone enlighten me please?
Good Answers: 230
Re: sump pit sizing
09/24/2008 4:52 AM
Hello "Guest"
Before a proper answer may be given, you would need to advise several factors not yet known:
  1. Layout of building (A sketch would assist, with dimensions)
  2. Is street water able to run down the entry/exit ramp?
  3. Possibility of flooding during monsoon etc
  4. Size in floor area
  5. Number of cars/trucks etc expected plus maximum of same
  6. Fire sprinkler capacity in quantity per hour per sprinkler (More than one sprinkler may emit water in a vehicle fire)
  7. Stormwater outlet capacity (you have to pump sump water somewhere)
  8. Are there other vehicle floors above? - advise how many, and if the top floor is open to the weather or roofed over please
  9. Other useful factors - Advise please.
Reply here, with
Kind Regards....
Reply Score 2 for Off Topic
Re: sump pit sizing
09/24/2008 5:01 AM
the condition is in middle east so no storm water runoff to be considered. consideration is just draining the car park for cleaning purposes (which is seldomly done). It is a 3 level basement parking. So if little water (washdown) flow rate is being considered, is there a minimum flow rate in the code say 20 gpm to be the minimum pump size..then just consider 15 minute retention time for the volume of the pit?
Good Answers: 230
Re: sump pit sizing
09/24/2008 5:57 AM
Hello ericpolc
<"....the condition is in middle east so no storm water runoff to be considered....">
Even in the "Middle East" sudden unexpected heavy rainstorms have occurred during the last few decades, on a sporadic basis.
Thus the "Stormwater runoff" situation is a serious consideration, even though this may not happen for several years.
It would be prudent to allow for such sudden rainfall.
Those qanats and cisterns hewn from rock were often filled by brief but heavy rainstorms.
If you have a basement park full of customer's cars, and they float in water, then sink, because of something you didn't allow for, those customers are going to take it out on your hide, and that would be very unpleasant, believe me.
Kind Regards....
Good Answers: 101
Re: sump pit sizing
09/24/2008 5:13 AM
Most important detail to consider: comply with your local Codes-of-Practice for factors like minimum retention time, minimum required flow etc.
Re: Sump Pit Sizing
09/25/2008 2:50 AM
shound like a simple 2 hp sump pump would cover all your needs easy.
Re: Sump Pit Sizing
09/25/2008 3:36 AM
First: I should say that I know nothing about this sort of thing, so, just ignore me if I'm being stupid.
It seems as though you need a pit shaped a bit like this:-
The small pit will accommodate the small pump for routine duties, and, the larger pit will hold water caused by an emergency. The small pump would empty the large pit eventually, but, I guess the local fire service would do it if there had been a fire or flood for other reasons.
Of course the main pit could be covered with something strong enough to support the expected "traffic".
Re: Sump Pit Sizing
09/25/2008 7:54 AM
sump pit size should be minimum 1 qbic miter general if water flow more then 1 tom per day than go one day flow of water somp size
bassantdas
www.charchitchemical.com
Canada - Member - New Member Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Piping Design Engineering - New Member Hobbies - DIY Welding - New Member
Good Answers: 11
Re: Sump Pit Sizing
09/25/2008 11:12 AM
The size of the sump is based on the size (capacity) of the pump(s) you want to put in it. The capacity of the pumps will be based on the flow you need to get out. For a commecial installation, a typical design criteria is to allow the car park to fill up to 100mm of water depth in two hours. This will not damage the cars inside, and all other equipment, especially electrical, should be mounted at least 200 mm above this allowable water height if they are located on the same level.
What you need to determine is what will be the design flow into the car park. This could be based on the maximum hourly rainfall in the area (if suceptible to flooding), a number of sprinkler heads or fire hoses defined by local fire codes, or other criteria. This part you'll have to determine with local authorities or the owner.
The 100mm height x area of car park = allowable accumulation
inflow - outflow = accumulation (typically allow for two hours to develop accumulation)
Since you've defined inflow and accumulation, you can calculate outflow. This will define the pump capacity.
As for sump sizing, the sump is sized by the minimum inflow expected. In you case, this sounds like the flow from a small utility hose during washdowns.
The sump should be sized so that the pump will not start more than 6 times per hour (or the number of starts specified by the selected pump manufacturer) at the minimum inflow . Too many frequent starts causes the pump to overheat and fail due to heat caused by the inrush current at starting.
If this requires too big a sump volume, it is best to put in a small jockey pump to handle the minimum flow and a larger pump (which is only activated on very high sump level) to handle the emergency situations.
Good luck! Steamer Stan
"You are, what you do, when it counts" - John Steakley (Armor) 1984
Re: Sump Pit Sizing
09/25/2008 12:41 PM
Your pit size is probably not as important as your pumping capacity. In order to design that you need to know your flooding sources and rates.]
The fire suppression system will have a good flow and losing all the cars on the lowest level to flooding might make someone unhappy. Electric failure during emergencies is pretty common so there may be no helping this.
Storm flooding is difficult to predict but there will be data for the area somewhere.
Ground water seepage is typically all these systems are designed to handle. Insurance is there to cover the rest.
If that is the case here, I think the 2hp pump sound about right and good drainage and a small - 0.25 to 1.0 cu meter sump would be ok. If you need more sump capacity buy a plastic tank and bury it. It will cost a lot lot less than forming a sump pit out of concrete.
Best wishes,
Mr. Gee
Anonymous Poster (1); dadw5boys (1); DVader1000 (1); ericpolc (1); Mr Gee (1); Randall (1); Sparkstation (2); Steamerst (1)
