Previous in Forum: Food Grade Steam   Next in Forum: distinguish SS316 from SS304
18 comments
Air Compressors
10/15/2008 1:32 AM
how to install 2 units of screw type air compressor efficiently. we are now encountering huge pressure loss now on our plant..one thing the technician noticed is the connection with "T" going to the main tank..he advise to install "headers" to increase the system pressure..as of the moment the two compressor are continously running and can not reach the cut-off of 6 bar. Please help me to find a best connection and set-up for this compressor to maximize its performance and save on power consumption as well (reached the cut-off of 6 bar)...thank you very much...
Re: Air Compressors
10/15/2008 8:51 AM
Downstream of the main tank, there is sufficient consumption and leaks to make the two compressors supplying it undersized. So one way of solving the problem is to fix the leaks.
Re: Air Compressors
10/15/2008 9:31 AM
PWSlack is correct.
Another item to save air is to use Regulators on all circuits and set them as low as possible and still maintain cycle and force integrity.
One other suggeston for regulators is to use one on all cylinder return strokes when the return stroke is at low force.
Any Air Blow Off devices should be replaced with other means or AT LEAST USE A VALVE TO TURN THE BLOW OFF ON ONLY WHEN REQUIRED. Electrically driven Squirel Cage blowers are often used to replace Air Blow Offs.
Bud Trinkel
Re: Air Compressors
10/15/2008 11:37 PM
Well I've done a few of compressed air project long time ago.
1.The first thing first. If you think there is a leakage; you should find and fix it.
2.Check your total outlets capacity(user points). It is most likely that your consumption is more than capacity of your compressors.
3.How you have calculated the capacity of your reservoir tank? Is it big enough to cater for at least a couple hours?
Never laugh at anyone's dream. People who don't have dreams don't have much.
Good Answers: 19
Re: Air Compressors
10/16/2008 10:03 AM
Good answer for items 1 and 2, but I disagree with #3. Given the rate of air consumption, I doubt it would be practical to have a receiver sized for 2 hours air usage at 6 bar. Assuming 100 cfm consumption, the tank would need to be 12,000 cubic feet?
Re: Air Compressors
10/16/2008 12:46 AM
When we did our last air project we found the following site http://www.kaeser.com.au/Online_Services/Toolbox/default.asp#0
Helpful it has calculators for maximum demand, how to size a receiver and how to measure air usage due to leaks, pressure drop and a few others. If you have had to add another compressor your receiver tank is probably now undersized. I would suggest doing an air audit usage of your site, air leakage audit and look at hose sizing eg a 1/2" air drill only needs 3/8 hose not 1/2" hose
Good Answers: 15
Re: Air Compressors
10/16/2008 12:58 AM
Your machines are running "air jets" ?
Many people use these things when they have a problem to solve, but don't realise the following line..
Air is expensive
If they think its not, they use alot of air, and the compressors are running continously.
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
Good Answers: 19
Re: Air Compressors
10/16/2008 9:59 AM
Headers will not increase pressure, but can reduce pressure losses.
..as of the moment the two compressor are continously running and can not reach the cut-off of 6 bar. .
This sounds more like a capacity issue, not a pressure drop issue.
Before doing anything take an inventory of air consumption and see if it balances to air produced. If you don't run 24/7, go in on an off shift, and run the compressors. Any hissing noise will be $$$$$ lost and gone forever! Find the leaks and fix them.
As a rule of thumb, I try to design Compressed Air systems for a 5% pressure drop from the compressor outlet to the farthest point in the plant. For 6 bar, the drop should only be 0.3 bar.
Good Answers: 16
Re: Air Compressors
10/16/2008 10:34 AM
#1 Concern is certainly leaks in your system.
#2 Current machines efficiency, you really need to know that you are not adding two other compressors into the mix with units that are in need of repair. For the price of a new unit you may be able to repair what you already have.
DO THIS SIMPLE TEST FIRST. I copied this a while back for checking compressors.
The compressor must feed a receiver or tank of a known volume. (stamped tag)
To conduct the test, close the valve that isolates the receiver from the plant's distribution system and turn off the compressor. Vent the receiver down to approximately 30 psi and turn the compressor back on. Study the pressure gauge on the receiver and use the stopwatch to time how long it takes for the pressure to build from 50 to 100 psi. Use the following formula to calculate the flow (scfm) of your compressor:
0.45 VR t = OC
where:
VR is receiver volume, gal
t is time, minutes
OC is Compressor output, scfm
Dividing the results of the test by the manufacturer's flow specification will indicate what percentage of the original capacity the compressor is operating at.
As an example, lets say a 712-hp compressor has a factory rating of 28 scfm and an 80-gal receiver. It takes 2 min and 6 sec to build the pressure from 50 to 100 psi. Then:
0.45 80 2.1 = 17.1 scfm, and
17.1 28 = 0.61
So the compressor is operating at only 61% of its original capacity. This indicates that the compressor is operating at a severely diminished capacity. This information should be carefully considered before replacing the unit.
Good Answers: 19
Re: Air Compressors
10/16/2008 1:12 PM
What is the source of this equation? It does appear to be a handy tool.
Does this equation exist in SI units for our friends in other parts of the world? I think they would prefer to use bar, liter/sec, m^3/sec, etc.
Good Answers: 16
Re: Air Compressors
10/16/2008 1:29 PM
I do not know of a metric version nor have I ever needed to do this as 80% of the machinery here is not metric.
I don't see why you couldn't simply use a standard conversion table to get what you need. I'll bet however that someone, somewhere in the world today will post one equal to or better than mine in metric from there side of the world.
Re: Air Compressors
10/16/2008 7:51 PM
From your description and what your technician said it sounds like the T is your problem. I usupect if you measure pressure at the compressor exits ti would be over or close to your 6 bar. Your problem is one compressor is trying to shove its air up the outlet of the other compressor. The harmonics of the gas flow can also slow the opposite compresors airflow by causing a harmonic obstruction in the line.
You also need to ensure the pipes are large enough to handle the required gas flow at 6 bar
Presuming the pipes are correctly sized, your technician is right, using a manifold will fix your problem, that is you need to get rid of the T and join the pipes in a parrallel tapered joint. The joint area between the end of the two inlet pipes and the single (same size) exit (though perhaps you might want to enlarge the exit pipe for better flow?) should be of a length to ensure the joint walls converge at no more than 7 degrees from the centreline to prevent flow loss.
The above will also solve any harmonic interference.
Good Answers: 16
Re: Air Compressors
10/16/2008 8:01 PM
"Presuming the pipes are correctly sized, your technician is right, using a manifold will fix your problem"
You obviously are under the assumption that there are no leaks and the compressors are operating at peak performance or do you know this to be a fact due to personal experience with this particular plant??
Re: Air Compressors
10/16/2008 9:09 PM
Tim,
Actually I'm presuming the Technician and Engineer are both competent and would have fixed all the leaks if there were any. I also relied on the fact that other posters had already dealt with the leaks and high flow devices issue and your excellent earlier post ( thanks for the calculation it will be most useful!) deals with compressor sizing and efficiency issues. That only really leaves harmonics, pipe sizing and backflow compression issues which I think I covered.
Good Answers: 16
Re: Air Compressors
10/17/2008 7:34 AM
When you look at it from that angle, I see what you were getting at. Thanks.
Good Answers: 15
Re: Air Compressors
10/16/2008 8:25 PM
Has the compressor tank been dumped of condensate?
As the tank fills, you'll have less reserve left the more condensate is in the tank.
We have had people here forget to drop the condensate and wonder why the compressor is running flat out with little use.
Re: Air Compressors
10/17/2008 12:15 AM
In this case you can reduce the system pressure below 6 kg/cm^2 and put a booster nearer to the place where high pressure is needed.this may solve your purpose since high pressure will not required in all places
Re: Air Compressors
05/15/2012 9:08 AM
Hey. I have a problem with my air compressor tank. It's not getting filled up properly. Can anyone help me ?
Good Answers: 16
Re: Air Compressors
05/16/2012 2:52 AM
Your joking right?
Reply to Forum Thread 18 comments
Anonymous Poster (2); BudT (1); g_nraja (1); Grochy (1); Hamid K Saberi (1); MarkhamCornoit (1); PWSlack (1); Ried (3); Snaketails (2); Tim in Mexico (5)
