Previous in Forum: Ideas for a graduation project ..   Next in Forum: Pump Shutt-off head
Chemical Treatment procedure for HVAC system..
10/26/2008 2:33 AM
Hi there.. can anybody inform me about the chemical treatment procedure/ flashing etc??? the system includes cooling towers / chillers/ AHU / fcu, condencer/ primary/ secondary pumps..what about looping?? all the system should be tested alll in once??
Thankssss
Good Answers: 19
Re: Chemical Treatment procedure for HVAC system..
10/26/2008 10:25 PM
Your question is jumbled and trys to combine too many topics in too small a space.
Are you interesting in cleaning and flushing treatments or on-going chemical treatments?
What is the concern with looping? What kind of tests are you looking for?
What is your location and raw water conditions?
United States - Member - US Citizen - Born & Raised Engineering Fields - Control Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Instrumentation Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Energy Engineering - HVAC/R Simplified Using PLC Controls
10/27/2008 5:35 AM
Review this specification, modify it for your needs and send it to a water treatment contractor. The sales representatives are very good at helping out knowledgeable operators!
NC STATE University Construction Guidelines
15189 HVAC Water Treatment
Rev 0 – 07/26/04 Page 1 of 4
Part 1: General
1.01 This section sets forth the minimum requirements for HVAC WATER TREATMENT
used on University building renovations or new construction.
1.02 This section includes water-treatment systems for the following:
�� Heating, hot water piping (closed-loop system).
�� Chilled-water piping (closed- loop system).
�� Heating, steam and condensate piping).
�� Condenser water piping (open system).
Part 2: Design Guidelines
2.01 CHEMICAL FEED DESCRIPTION
A. Closed-Loop System: One bypass feeder on each system with (5 gallon size on all
systems with > 1, 000 gallon volume) isolating and drain valves at circulating pumps,
unless otherwise indicated.
B. Closed- Loop Heating Steam and Condensate Piping: Lead-lag switch controls the
sequence of boilers and introduces the chemical to the boiler through an appropriate
chemical feed system.
C. Open- Loop Condenser Water Piping: Chemical feed and bleed control systems with
integrated inhibitor and dual biocide feed
2.02 PERFORMANCE REQUIREMENTS
The water treatment program includes boiler systems, cooling towers, hot water loops,
and chilled water loops. The contractor will provide all chemical products (currently
consisting of oxygen scavenger, scale inhibitor, organic dispersant, alkalinity adjustment,
condensate treatment, fuel oil treatment, combination scale/corrosion inhibitor with
dispersants, non-oxidizing Biocide A&B closed water treatment, and lay-up treatment as
required), along with equipment, and professional consulting services to accomplish the
following:
A. Produce clean heat transfer surfaces which are substantially free of scale, sludge,
deposits, corrosion, pitting and biological growth when treatment is administered in
accordance with vendors directions and recommendations.
B. Reduce fuel and electrical consumption through improved heat transfer efficiency, by
minimizing scale, corrosion, fouling and microbiological growth which create deposits on
heat transfer surfaces.
C. Minimize repair and maintenance costs associated with replacement and cleaning of
equipment due to scale, corrosion, fouling or microbiological activity.
Rev 0 – 07/26/04 Page 2 of 4
D. Provide professional, knowledgeable and involved sales/service personnel to ensure
program success.
E. Accurately monitor program results and communicate appropriate recommendations
with quantifiable business oriented justifications.
F. Provide Training to University personnel on the implementation and control of the
program.
2.03 SUBMITTALS
A. Product Data: Include rated capacities; water-pressure drops; shipping, installed, and
operating weights; and furnished products listed below:
�� Pumps
�� Chemical feed and bleed control systems with integrated inhibitor and dual
biocide feed tank.
�� Chemical bypass feeders
�� Chemical water treatment program and MSDS
�� Test equipment
�� Filters
2.04 QUALITY ASSURANCE
Installer Qualifications: Provide an experienced installer who is directed by an authorized
representative of the chemical treatment supplier for both installation and maintenance of
chemical treatment equipment.
3.01 PRODUCTS
A. MANUFACTURERS
Manufacturers: Subject to compliance with requirements and in conjunction with the
existing contracted University HVAC Water Treatment Program, provide products by the
current Chemical Treatment Vendor for the University:
Contact Facilities Operation to obtain the current contracted Vendor.
Every effort must be made to maintain a level of uniformity in chemical formulation to
insure a line of continuity. Deviation from existing formulations that are applied across
the University shall be avoided.
Provisions should be made for the removal for any unused chemicals. In addition,
provisions must be provided for the proper disposal of all empty containers.
B. CHEMICAL TREATMENT TEST EQUIPMENT
�� Test Kit: Furnish all necessary manufacturer recommended equipment and
chemicals for testing and controlling the water treatment. Provide a program for
testing pH, bio-count, chloride, alkalinity, total hardness, and inhibitor.
�� Corrosion Test Coupon Assembly: Constructed of corrosion resistant material,
complete with piping, valves, mild steel and copper coupons. Insure 6 gpm flow
across the coupons. Locate copper coupon downstream from mild steel coupon
Rev 0 – 07/26/04 Page 3 of 4
in the test coupon assembly. Analysis of the coupons each 90 days will be
performed at no additional cost to the University.
C. CHEMICALS
Furnish chemicals recommended by water treatment system manufacturer that are
compatible with piping system components and connected equipment.
�� System Cleaner: Liquid compounds with emulsifying agents and detergents to
remove grease and petroleum products. The formulation must be compatible with
the system components.
�� Biocides: Two alternate non-oxidizing micro-biocides with different kill
mechanisms.
�� Closed- Loop, Water piping Chemicals: Contain sequestering agents to reduce
deposits, chemicals to adjust pH , and corrosion inhibitors to protect system
metals.
�� Heating Steam and Condensate Piping Chemicals: Liquid formulations to prevent
deposits, adjust pH and alkalinity, scavenge oxygen, and protect condensate
system components.
�� Open-Loop, Condenser Water Piping Chemicals: Deposit dispersants and
penetrants to inhibit scaling, corrosion inhibitors, and micro-biocides.
3.02 EXECUTION
A. WATER ANALYSIS
Perform an analysis of supply water to determine the type and quantities of chemical
treatment needed to protect from corrosion, deposition, and fouling.
B. Installation
Install treatment equipment level and plumb.
Perform chemical cleaning as recommended by the water treatment supplier. The water
treatment supplier must test and certify in writing that the systems are clean and free of
organic and inorganic contaminants.
3.03 FIELD QUALITY CONTROL
Engage a water treatment service representative to perform startup service.
Inspect field- assembled components and equipment installation, including piping and
electrical connections. Report results in writing.
Inspect piping and equipment to determine that systems and equipment have been
thoroughly chemically cleaned, rinsed, and filled with water, and are fully operational
before introducing chemicals for water treatment system.
Place HVAC water treatment system into operation and calibrate controls during the
preliminary phase of HVAC systems startup procedures.
Test chemical feed piping as follows:
�� Do not enclose, cover, or put piping into operation until it is tested and
satisfactory test results are achieved.
�� Test for leaks and defects. If testing is performed in segments, submit separate
report for each test, complete with diagram of portion of piping tested.
Rev 0 – 07/26/04 Page 4 of 4
�� Leave uncovered and unconcealed new, altered, extended, and replaced water
piping until it has been tested and approved. Expose work that has been covered
or concealed before it has been tested and approved.
�� Cap and subject piping to static water pressure of 50 psig above operating
pressure, without exceeding pressure rating of piping system materials. Isolate
test source and allow test pressure to stand for four hours. Leaks and loss in test
pressure constitute defects.
�� Repair leaks and defects with new materials and retest piping until satisfactory
results are obtained.
�� Prepare test reports, including require corrective action.
3.04 DEMONSTRATION
A. Engage a qualified water treatment service representative to train owner's
maintenance personnel to adjust, operate, and maintain HVAC water treatment systems
and equipment.
B. Furnish a one-year service program by a qualified service person, performing
service on a full-time basis. Service calls will be scheduled on a twice a month schedule
coordinate with the University as to the day of the month that service will be performed.
Upon arriving on campus, the service person will contact the University representative.
Upon completion of the service call, a copy of the service report shall be given to the
University's representative. Response to emergency service calls shall be less than 24
hours. The University shall make the equipment available/ accessible to the service
person so as not to cause delays.
C. Train Owner's maintenance personnel on procedures and schedules for starting
and stopping troubleshooting, servicing, and maintaining equipment and schedules.
D. Review manufacturer's safety date sheets for handling of chemicals.
E. Schedule at least 8 hours of training with Owner with at least seven days'
advance notice.
"Memorize the calculations, you look like a fool searching your notes while teaching class"
12/30/2008 6:45 AM
Hi there, I my opinion the biggest sources of bacterial pollution are failing septic systems and pet wastes. In rural areas, you can usually add livestock waste. In some areas, wildlife contributes their own pollution. Each year, health inspectors focus on a handful of watersheds in Kitsap County. The fact that local waters are growing cleaner in the face of expanding development must be testimony to their success. If you want more information about your question visit the website which is given below it will help you http://www.jnblabs.com/.
Hi there, in my judgment Ceramic tiles are made from refined clay and other material. Maintenance is important through routine cleaning with mild soap and water. If you have some stains to remove, try a few of these suggestions to get your tile looking new again.
1. Clean the stained area with plain water and a soft cloth. Dry thoroughly.
2. Put on gloves. Use these to protect your hands even if the product is considered natural or non-toxic.
3. Mix borax and lemon juice together on a disposable plate or bowl. The consistency should be a paste-like substance. Rub onto the stain and allow it to dry completely. Rinse the ceramic tile with water and repeat until stain is gone.
4. Use a mixture of a vinegar and salt to make a paste. Apply to the rust stain and wait 4 to 5 hours and then rinse with hot water. Repeat as necessary.
5. Consider purchasing a Lustrous Italian cleaning kit. Apply to area with a moistened, soft cloth. This Lustrous Italian will remove the stain and not scratch surfaces.
Register to Reply 3 comments
jcchiefeng (1); juan1 (1); Ried (1)
