Previous in Forum: can u solve(Digsilent)   Next in Forum: Control Gear Glossary
capacity calculation
11/03/2008 8:04 AM
how to calculate ampere hour of a 24 volt battery connected to a motor of input power 4 KW to run 2 hours?
Re: capacity calculation
11/03/2008 8:22 AM
4kW times 2 hours, divide by a thousand is <tap, tap, tap>, er, so-many watt-hours, which is <tap, tap, tap>, that, then divide by 24 volts is, er, <tap, tap> so-many amp-hours. Eureka!
Good Answers: 53
11/03/2008 9:35 AM
It depends on what discharge level you choose. Lets say you operate 24 Volts battery between 20 to 24volts,
Max current your Motor will draw is 4000/24=166.666
So the amount of charge required to run motor for 2hrs = I x T= 167 x 2 x 60 x 60
= 1202400 Coulomb.
Min discharge level =20 Volts
%Age coulombs available for motor ={(24-20)/24} x100= 16.66%
So the total amount of charge required inside the battery
= 1202400 / 0.1666=7214688 coulomb
Total Amp-Hr required = 7214688 /3600 = 2004 Amp-Hr (1amp hr = 3600 Coulomb)
11/03/2008 10:15 AM
Good learning for me, My GA.
Good Answers: 18
11/03/2008 2:19 PM
And 1 Coulomb = 6.241 509 629 152 65×1018 electrons . . .
03/03/2009 3:29 AM
thanks Rakesh, all these days I though calculation of AH is to just multiply the current drawn with the no. of hours.
Dream is not what you see in your sleep, but is the one which does not let you sleep - APJ ABDUL KALAM
11/15/2008 3:03 AM
well done guys, it is a good learning for me too,
normally I'll just multiply the current by the time and get the AH ( ampere hour )
Thanks
William Tan
There are no Mistakes , Only Lessons.
Bill (1); ganapa (1); mark (1); MultiTech (1); PWSlack (1); rakesh_semwal (1)
