Previous in Forum: what is the Design Basis of a hydro-pneumatic tank in fire protection   Next in Forum: Encoders and Resolvers - What are the Differences?
Flange Thickness
12/02/2008 9:18 AM
can anybody tell me the formula to calculated the min required thickness of a bolted flange, mounted against separating force of X kg
Re: Flange Thickness
12/02/2008 10:58 AM
Are you doing this to a piping or vessel code - or just general mechanical design?
What is this for specifically? Does it need to contain a fluid pressure?
12/04/2008 9:06 AM
Just general mechanical design...
(Side cover for Power steering unit)
08/13/2010 2:52 AM
dear sir,
i required how to deside the flange when flange standard is not standard. if we using minimum thickness if you have formula for this please give me reply
12/03/2008 12:57 AM
Please refer to the following CR4 threads for design of blind flange under internal (or external) pressure as per ASME Code, Section VIII, Division 1:
• can you tell me thickness calcu........ &
• External Pressure Blind Flange
12/04/2008 9:23 AM
Side cover flange thickness for Power steering system....
Inside pressure may be 200bar
I would like to have formula with related to No. of bolt & Bolt position.....
12/04/2008 9:23 PM
It seems you actually have two questions/problems -
  1. Design of bolts/gaskets
  2. Design of cover plate
So I would suggest
  1. Do a quick look into what size and number of bolts you will need for your pressure and size of opening.
  2. Download a program such as this: https://www.klingeruk.co.uk/pages/klinger_expert
  3. Figure out all the details on your bolting/gasketing/torquing
  4. Post that information here
  5. I can give a thickness of the cover plate based on this information and a material.
    1. You could design the cover to ASME, however, I think that will be too conservative for you (particularly with the allowable stresses they use - but that could be adjusted, anyways ................)
    2. I have a better solution/calculation for your cover plate, see: http://www.springerlink.com/content/p77mk14727066602/fulltext.pdf?page=1
    3. Alternatively - design the cover plate with FEA.
12/03/2008 6:35 AM
That also depends on pipe diameter.
But this looks rather like a college question to me. If so, you should be consulting your textbooks and working things out for yourself; (in any case, asking help with coursework contravenes CR4 house rules)
Register to Reply 7 comments
Abdel Halim Galala (1); Anonymous Poster (4); rathesh4u (2)
