Previous in Forum: Valve Failure Position   Next in Forum: Relay Logic and SIL Level
10 comments
What's the Difference Between Casting and Molding?
12/04/2008 5:13 AM
What is the difference between casting and molding?
Re: What is the difference between casting and molding?
12/04/2008 8:07 AM
The difference between Casting and molding is that in one material, mold, and output product has a lot differences.
Re: What's the Difference Between Casting and Molding?
12/04/2008 10:42 PM
First four letters are different
Engineering Fields - Mechanical Engineering - Member
12/04/2008 11:36 PM
Generally the term casting is used, when the material used is a metal & moulding for non-metals such as plastics (in UK English). From what i have seen in American books, the term mould is used for a die - gravity die/permanent mould & pressure die casting/ die casting
12/05/2008 12:14 AM
Both the process is very similar in which molten material is poured in to the close mold / die which will take the shape of the cavity of close mold and then it cured and removed from the mold.
The basic different is the method of pouring the material in to the mold. In moulding it will be poured the material pressure and in most of the casting process, it does not require any external force to pour the material as the molten material has very less viscosity and is capable to flow with its gravitational force only.
In moulding process the output is the final finished part but in most of the casting process, the output is unfinished part that required the final finishing(machining).
Paras Desai
04/19/2010 2:14 AM
but what is the basic & important difference of moulding & casting
12/05/2008 2:34 AM
Casting - generally for metal and input metal enters by gravity in to the cavity.
Moulding - both metal and non metal,cavity is used repeatedly. the input can be by pressure or gravity.
Sometimes they can be mixed up . Say in Battery making. the Grid is made in "grid mould" by pouring molten alloy,but the machine on which the Mould is mounted is called "Grid Casting Machine".
12/05/2008 11:28 PM
Casting uses a "one time" use mold while molding you can repeat the process with the same mold.
Brad
12/07/2008 10:27 PM
Not really U V.
Gravity die cast and pressure die cast, uses same mold again and again.
As cleared earlier, normally, metals process is called casting and plastic process is called moulding.
12/07/2008 11:56 PM
And that is why I cast my model parts out of resin cast plastic in a reusable mold.
Happy Holidays qsuhas,
Brad
05/02/2013 4:50 AM
Dear Friend,
CASTING is POURING THE MOLTEN METAL in to the already made profile as per the components - with different allowances inclusive.
MOULDING is the PROCESS of making the profile in such away - the space is occupied by the moulding sand in the boxes other than the shape of component to be cast and the boxes are called drag, cope and cheek for 3 pieces and the hollow or empty portion will resemble the component required.
DHAYANANDHAN.S
Anonymous Poster (3); dhavalgatorwala (1); dhayanandhan (1); gsuhas (1); Paras Desai (1); U V (2); venkat (1)
