One of the most serious lapses in the classical physics
model of the world was its inability to explain the existence of matter. If the electron is taken as a charge e moving
with acceleration w and emitting I ergs each second, it will lose its energy
over time and fall into the nucleus. Calculations show that this time interval
would be 10^^-10 secs. Therefore a strict application of classical laws seemed
to prove that matter could not exist. QM got around this fact by proposing
wave-particle duality for the electron. Wave-particle
duality became one of the corner stones of QM, something to be never questioned on pain
of being ejected form all credible scientific circles. But is there no alternative to this rather
abstruse theory.
One possible solution lies in the second of Heisenberg's
Uncertainty Principles. The Heisenberg
uncertainty principle , as it was originally formulated, states that the more
certain we are of the position of a particle, the less certain we can be of its
momentum. We can determine its position precisely but in that case we cannot
determine its momentum at all. However, it was later seen that in addition to
the reciprocal uncertainty of position and momentum, there is also a reciprocal
uncertainty of time and energy. The less uncertainty there is about the time
involved in a sub-atomic event, the more uncertainty there is about the energy
involved, and the other way around. Thus if the time involved is of very short
duration 10^^-15 secs or less, the energy involved becomes arbitrary. So in effect
while conventional wisdom holds that nothing for nothing is the rule in
physics. In actual fact it is possible to get something (energy) for nothing providing
it takes place in a very, very short span of time.
This has led to the theory that electrons are able to maintain a constant orbit around the nucleus by continuously
emitting and absorbing photons, in this way a balance is maintained and there
would be no need for the electron to fall into the nucleus. However, the photons that the electrons are continually
absorbing and emitting are not real photons but 'virtual' photons. The emission and absorption of these 'virtual'
photons take place so quickly that the conservation laws of mass-energy are not
disturbed.
The other part of the theory holds equally good, if a
particle has an extremely small amount
of energy then it stands to reason that,
that particle can exist practically indefinitely.
The interesting thing about this theory of how the electron
maintains its orbit i.e., by the constant emission and absorption of virtual
photons, is that has actually been verified by an experiment which has come to be known as
Lamb's shift.
