What we are doing:
- Multiple pattern pieces need to be hand cut and assembled from polyethelene foam sheeting (Plastazote in the UK as far as I know, the supplier here in South Africa is Sondor).
- We need to have the pattern pieces for each object arranged and printed onto the PE foam sheets using wide-format printing.
What I need:
- Find an entry level (**this is a once-off project**) nesting programme that can read my files easily (either Corel DRAW .cdr or AutoCAD .dwg) and assist with maximising material usage and minimising waste.
- So far I have been arranging components/sections manually on CAD and Corel. With the big volume of templates to be created and prototyped for this project I do need something that will streamline the process and save time.
I have looked at Turbonest and will be following up with them soon. Any other suggestions?
