Previous in Forum: Oxygen Piping   Next in Forum: cant find the leak
43 comments
Micrometer Screw
01/16/2009 9:58 AM
hi to all, plz look at the picture and its explanation this is called a micrometer screw,but i could not find anything like this around or on net can anybody explain what this is exactly and how this works its application etc.. http://www.sendspace.com/file/wpllzk
User-tagged by 1 user
Good Answers: 103
Re: Micrometer Screw
01/16/2009 11:07 AM
Is it possible to paste the jpg or the kink. Unfortunately my firewlls puts all the download servers on fire- and I get only the ash.
Good Answers: 97
01/16/2009 1:12 PM
It is the word screw that causes that (sort of off-topic). You would require the OK from your adult (parent) supervisor to overrule the setting.
Good Answers: 103
01/16/2009 11:13 PM
Office firewall - normally (you know of course why) - these sites with download/ upload facilities are blocked.
Infact I get some of the Globalspecs blocked (without screwed tried with our network admin bulldozed and coaxed- but not able to get the hotlinks activated - globalspec news letters, ASQ newsletters etc - any idea how to fool the wall)
01/16/2009 11:54 AM
Off to the bar so I've done my bit!
01/17/2009 1:51 AM
This arrangement is illustrated in the book 'Mechanical Movements' published by W. M. Clark, New Jersey, USA, copyright by HENRY T. BROWN.
The copy I am having was reprinted June 1933, some 16 years before I born.
I have seen this arrangement in a slightly different mechanism on composite screw jacks. This used to lift/move loads quickly by fewer rotation of screw. If both threads are of same direction (right handed), for the following arrangement, for every rotation of the outer screw, the load will be moved/lifted by P1 + P2 distance.
But the arrangement on discussion has threads of different direction (one 'right handed' and the other 'lift handed'). Though I have not seen or used, it quite is understandable. Suppose if a heavy weight is to be moved/lifted for smaller distance, threads of different directions could achieve it. In this case the distance would be P1 ~ P2.
Imagine a situation of lifting 10 tons for a height of 0.01 mm, it is possible by having P1 = 5mm and P2 = 4mm, squire threads. Every rotation will lift 1mm. If we arrange micro head with 100 divisions on the head screw (least count = 0.01mm), we can lift 0.01 mm for the rotation of 1 division on the head screw.
Had it been only one screw arrangement (as in normal screw jack) with a pitch of 1mm, the same results can possibly achieved, but can not lift huge weight (loads), since 1mm pitched screw may not handle huge weight beyond its capacity.
Good Answers: 50
01/17/2009 2:19 AM
So you're exchanging the action on one inclined plain for action on a much more shallow and longer inclined plain... You don't climb as fast, but in return, it's much easier to climb.
A gold sovereign for the first "real" engineer to find one in use in some actual device!!!
Hobbies - Fishing - Popular Science - Paleontology - New Member
Good Answers: 27
01/17/2009 8:20 AM
This screw mechanism is based on two screw pairs each with different pitch such that the slider moves a distance proportional to the pitch difference. This device is used in precision measurement instruments. It is called a differential screw thingy.
For another gold sovereign I'll show you the instruments its used in.
Prophet Freddy has the answer!
Good Answers: 103
01/16/2009 1:22 PM
Principle is simple but never seen this type of instrument - it will be like a screw jack- with a reduction gear mechanism -
Suppose the top screw (the larger, hollow one) is held in a guide - then one rotation of it will pull in the smaller screw by the pitch difference between them and that reduction ratio will generate the equivalent extra torque
01/16/2009 5:36 PM
Looks like the screw out of a ceramic tool holder. Could not google a picture.
Regards JD.
01/16/2009 11:57 PM
hi to all again .... i am surpized a bit the so called guru,s on this forum are making fun of it or are confused about it i dont know wht the west define a status of a guru ,but we in india a guru is consider to be a wise men who help others ... i would like to inform, all my brothers -n- elders of a piece of history about this ,i got this thing in a book called mechanical movement by someone called HENERY T.BROWN EDITOR oF AMERICAN ARTISAN published in new york in 1871 around 138 years ago. the day i saw this i am confused about it this thing,this looks very amazing but how do this work i can understand as both the screws are in opposite direction and diff. pitch so how does one moves the another if this technology was a avaliable around so long why couldn,t we see anything like this around i have talked to many people about it but no one heard to such thing ,even there is no such thing on the web itst its amazing a forgotten technology.. this it not only one drawing in it the book contain many such amazing mechanical things.. hope that no war of words will start with my this post but something positive will come out by grace of god........ ......................................................................................... all i had is hope and HOPE....that keeps me going.....
Good Answers: 50
01/17/2009 12:14 AM
Considering a screw is really an inclined plane, but this sort of work like a lever and fulcrum. I don't think I need to explain that.
The threads are in opposite direction so that tightening one end loosens the other and visa versa. If they were in the same direction, you would get the pull would you.
Make any sense?
01/17/2009 10:35 AM
The status of "Guru" on this forum has nothing to do with "west," south, north or east. One only has to post enough messages to obtain the status. Whether or not good answers play any role in it or not I am not sure but "me thinks not." Often good answer status is awarded mostly to those that get there first only to find out later the dissertation was merely a brain fart.
Always use protection.
01/17/2009 10:43 AM
Welcome trailblazer11.
I, and I beleive we, all enjoy seeing the out of the ordinary. I am a "Guru" because CR4 says I am - not because I say so.
I have seen similar somewhere before but can not for the life of me recall where. I am a machinist (was) by trade and think that it was somewhere in that environment.
I want to say it was on the mainscrew (leadscrew) of a movable plate for an inspection microscope......just can't quite recall.
Also, I am a novice collector of rare and out of print tech manuals and the such. I look forward to researching the title you have provided.
And again, welcome.
01/17/2009 11:48 AM
"I have seen similar somewhere before but can not for the life of me recall where."
Tap handle (used for threading holes) has differential screw arrangement, towards holding the shank of taps.
Good Answers: 50
01/18/2009 2:11 AM
This is not intended directly at you, TexasCharley.
Jeez! I think we all better lighten up about this "guru" thing. Life's too short to get all balled up about this type of crap! All it takes in one asteroid to make this whole issue completely ridiculous! That or the coronary you're going to have by stressing over things like this... I'm guessing this isn't the only trivial stuff they stress over in their lives.
01/18/2009 9:27 AM
Thanks. I am a delicate and fragile ego ya know. That could have crushed me out right.
Good to see you are still bouncing about Vermin.
Good Answers: 196
01/17/2009 12:11 AM
Trailblazer11-- This device is more commonly referred to as a:
DIFFERENTIAL SCREW
1. A compound screw by which a motion is produced equal to the difference of the motions of the component screws.Source: Webster's Revised Unabridged Dictionary (1913)
This is one of the mechanical contrivances you can keep in your bag of engineering tricks for an entire career and never find an actual use for. It always seems to be that the utility of this device for linear is greatly limited by its large length relative to the machine where you want to achieve the function it offers.
But that's just me, maybe.
The one good application that comes to mind is in the type of milling vise that moves both jaws together or apart the same amount by rotating one screw. Since the difference of motions is exactly zero in this case one is able to set up to machine a feature at the exact center of a workpiece, regardless of its width, without needing to reset the milling machine table for each in a succession of separate workpieces.
I think micrometers must have been made that way although I've never seen one that I recognized as such.
Ed Weldon
Good Answers: 58
01/17/2009 2:57 AM
The screw you refer to is commonly found on a turnbuckle, however, this is comprised simply of a right hand and identical left hand thread at each end. A compound (differential) screw is comprised of two threads of different pitches so that the motion is the difference between the pitches of the two screw threads.
01/17/2009 12:03 PM
I think a turnbuckle is also a differential screw, for one rotation of the screw, the nuts on either ends are pulled (or pushed) for two pitch distance, right?
Imagine one of the threads has different pitch than the other, then for each turn will yield a pull equal to the difference of pitch lengths. Let the right handed thread has a pitch of 1mm and that of left handed thread has 0.8mm pitch, then you have 0.2mm per every turn, so a micro movement.
01/17/2009 11:28 PM
I'm sorry, there a mistake in my projection...
In a turnbuckle, if the right handed thread has a pitch of 1mm and that of left handed thread has 0.8mm pitch, then you have 1.8mm per every turn and not 0.2mm as I wrongly said.
To achieve 0.2mm both the threads are to be of same direction.
01/17/2009 11:51 PM
01/18/2009 7:12 PM
Very Nice Ed, very well put in words, now add the Z axis and we have a team.
01/17/2009 11:48 AM
I have never seen this particular configuration of combining mechanical advantages in a practical application and I have seen many screws and other mechanical devices in my years as a machinist and project engineer/machine designer. I will take a crack at explaining what this is from the picture and description though. It appears to be a larger screw with a smaller screw inside of it. The larger screw has a coarser thread, while the smaller screw has a fine thread. The movement of the smaller screw in one direction would appear to move the larger screw in the opposite direction. The smaller screw would rotate many more times than larger screw to achieve one rotation of the larger screw due to the increased number of threads per inch on the smaller screw. Hence, your mechanical advantage would be "magnified." The fact that this is called a "micrometer screw" and the fact that there are finer threads on the smaller screw would lead me to think that maybe this configuration could be used in some sort of measuring instrument. My conclusion is that, because there is usually sufficient mechanical advantag in a simple screw with fine threads, there is not much need for such a device.
Regards,
Keywalker
01/17/2009 11:47 PM
Yes, I agree that to sufficient mechanical advantage in a simple screw with fine threads.
But when you need to achieve a micro movement against a huge force/load, the fine threads might giveaway. Square threads or knuckle threads may be preferable. Invariably squire or knuckle thread to suite huge load may call for higher pitch length, each turn (or part of a turn) may shift undesirable long movement. Will not a differential thread arrangement (under discussion) help in such requirement?
01/17/2009 11:52 PM
01/18/2009 10:38 PM
There are probably some instances in which this configuration might prove desirable. I just can't remember ever seeing this before though. The turnbuckles and jacks I have seen, just not the combination of smaller screw inside a larger one with differing pitches and directions of rotation.
01/18/2009 11:50 AM
Looks like and Optical comparator screw to me (Starrett) which the older models have a lead in micrometer instead of a Digital Read Out. Just moves the X axis table to achive standards of 0.0001 in parts or a master glass scale.
Good Answers: 27
01/18/2009 3:14 PM
Same principal; differrent set up. circa 1880. Model: M08 Differential Screw Mechanisms with Two Spur-Gear Pairs In model M-8, the screw is moved by a spur-gear pair at one end and by another pair attached to a keyed sliding joint shaft at the other end. The two gear pairs have teeth ratios of 62:14 and 60:15 at the screw end and rotating slider ends, respectively. The two pinion gear wheels are driven by the same crank. The screw is thus moved proportionally by the difference in rotation of the two gears. These devices were used in precision measurement equipment.
Francis Moon 2004-07-00
Reference :
  • Reuleaux, Kennedy :
01/18/2009 4:44 PM
So response #15 wins the bean?
Good Answers: 27
01/18/2009 5:00 PM
Nope..and me neither. The diagram in the original question indicates opposing thread which acts in reverse to what we were on about.
01/18/2009 6:54 PM
doesn't that explain why on some devices there is a "counter intuitive" turning that occurs?
I am thinking again of my old inspection scope with the sliding table. And as someone else mentioned; an optical comparator.
Good Answers: 27
01/18/2009 7:55 PM
They'd be fine adjustment screws. Your scope and comparators would have such a device.
The ones I use have two speeds the faster of which is engaged when the turning knob is pushed in and engages the coarse thread. High precision microscopes have these adjustors with three and four sets of threading.
01/18/2009 8:05 PM
Now do I get a banana? Huh..Huh? How 'bout now?
Good Answers: 50
01/19/2009 1:52 AM
Totally off topic (as I have marked myself), but odd that in the 60's Chrysler cars and trucks had right-handed wheel lugs on the right wheel and left-handed lwheel ugs on the left wheel. Now what was the purpose of that?!
Good Answers: 27
01/19/2009 7:24 AM
Coming from Chrysler that makes perfect sense though it sounds suspiciously like they stole it from one of Fords better ideas.
It would effectively give owners a first hand opportunity to appreciate what being stranded is all about.....further on the upside, you'd only lose two tires if someone happened to steal them.
Good Answers: 196
01/19/2009 11:50 AM
I once had a 63 Dodge Dart station wagon. The left front wheel had 4 left hand nuts and one right hand. I knew this. The kids who stole the tire from the other side didn't know. To this day I can't help but laugh at how they must have felt wrestling in the dark with that last stubborn lug nut.
Ed Weldon
Good Answers: 27
01/19/2009 12:05 PM
He he.......actually not a bad idea given the funny aspect
We had a guy try to siphon fuel out of a septic tank on an RV. Owner came out to discover one very ill thief writhing on the ground. Cops laughed so hard they forgot to arrest him.
Good Answers: 18
01/21/2009 2:22 AM
vermin, This is not anything but good engineering, the reason for this prevented the lug nuts from loosening on their own due to wheel rotation. Think about it, J.Conway
For every great advancement in medicine there is an equal and opposite advancement in the denial of treatment.
Good Answers: 50
01/22/2009 11:10 PM
Well, how come no one else needed to do it?
Good Answers: 18
01/23/2009 2:52 AM
Vermin. Well, how come no one else needed to do it? The need existed and still does today. I take it maybe someone thought the problem was worthy of their time and sought out the solution to prevent the wheels from falling off. How many times have you Seen vehicles on the side of the road with a wheel missing? Have you ever had lugs come lose and had any thought as to why this happens? Or do you just re tighten it an move on? You know that you tightened it but what the heck. I won't go into the various reasons for this but those left hand threads sure helped keep the wheels on. I have been crew chief for race teams in NASCAR, ARCA, Southern Dirt & NHRA for many years & won another Championship at South Boston in 2008 and if it wasn't for having to make rapid tire changes I would probably do the same as Chrysler Corp, for safety s sake. As to why no one else done it, well many different manufacturers over the years have and do. As in so many replies on CR4 too many people try to answer questions that they have no hands on experience with, or if they do its a situation to where they do as they have seen done without knowing or questioning why. Its like on another thread that's on CR4 about splicing v-belts, everyones telling him ya, no problem, do it all the time and then proceed to describe how to splice a flat conveyer belt, just not the same thing and their answers are going to get someone hurt or maimed. I'm a firm believer in only giving answers to what you have personally experienced the repercussions of. I have personally experienced having anothers life in my hands in my responsibilities and have freed body parts from machinery because safety wasn't given enough if any consideration in someones design, be careful of what you make light of because there's that chance you might be taken serious. J.Conway
Good Answers: 196
01/23/2009 1:01 PM
Jerrell -- My sentiments entirely. You get a GOAT (good answer, off topic; but with a forever4 firing order)........
When will we see you at the Salt?
Ed Weldon
Good Answers: 50
01/24/2009 10:10 PM
I'm guessing that Chrysler did this as a safety precaution in case someone tried to screw the lugs nuts down the wrong way. The curved end of the nut looks like it should be pointing away from the wheel - which, of course, could lead to all kinds of trouble.
Good Answers: 50
01/19/2009 1:46 AM
Yep! Too bad they're no longer legal tender.
Register to Reply 43 comments
Anonymous Poster (2); Duckinthepond (6); Ed Weldon (3); Hendrik (1); Jak_Flash (2); jdretired (1); Jerrell Conway (2); Keywalker (3); Mr. Truman Brain (1); sb (3); TexasCharley (5); trailblazer11 (1); vermin (7); welderman (1); yesyen (5)
