I've started doing some research into Wood Gasification, I'd like to build one to power my truck. The design's are pretty darn simple and as long as you are not stupid enough to run them indoors look pretty safe. I don't really see them as very practical to solve the world energy problems. But they sure did a lot for Europe during WWII. It is really fascinating how clean you can burn wood with this process, as well as being able to run your gas powered car with the discharge gas. There is a lot of good information out on the internet and even what appears to be a very well designed kit.
http://www.allpowerlabs.org/index.html
I also haven't found anything on efficiency. They talk about it being more efficient then just burning the wood. But the designs I've been looking at look like there is a lot of heat loss. So maybe someone knows more then I do. There is a wonderful article that talks about how much energy you can get out of the GAS.
http://powercubes.com/listers_12.html
But it doesn't really say anything about how efficient you can make the process. The process burns nearly 100%, and please note I said nearly, of the fuel so in that respect is should be efficient. But on the other hand you have to cool the discharge gas in order to get it dense enough to burn in your car. In my mind anytime you have to throw away heat you have a loss of efficiency.
So I wanted to bring the subject to all of you and see what everyone thinks. Maybe someone out there has built one of these and can give us some first hand information about the process. If nothing else it should bring out some lively discussions.
