Previous in Forum: Instrument Accuracy and Calibration   Next in Forum: timer in PLC
Units of Measure
01/19/2009 10:51 AM
hi
as we know that pressure is the force/unit anrea kg/cm2 but i m confuse about these units
mmH2o, inH2o, mmHG,INhg,atm
how we will define it
regard
United States - Member - NE, USA Hobbies - Target Shooting - New Member Engineering Fields - Aerospace Engineering - Engineering Fields - Electromechanical Engineering - New Member
Re: Units of Measure
01/19/2009 12:05 PM
http://en.wikipedia.org/wiki/Pressure#Units
Units Mercury column
The SI unit for pressure is the pascal (Pa), equal to one newton per square metre (N·m-2 or kg·m-1·s-2). This special name for the unit was added in 1971; before that, pressure in SI was expressed simply as N/m2.
Non-SI measures such as pound per square inch (psi) and bar are used in parts of the world. The cgs unit of pressure is the barye (ba), equal to 1 dyn·cm-2. Pressure is sometimes expressed in grams-force/cm2, or as kg/cm2 and the like without properly identifying the force units. But using the names kilogram, gram, kilogram-force, or gram-force (or their symbols) as units of force is expressly forbidden in SI. The technical atmosphere (symbol: at) is 1 kgf/cm2. In US Customary units, it is 14.696 psi.
Some meteorologists prefer the hectopascal (hPa) for atmospheric air pressure, which is equivalent to the older unit millibar (mbar). Similar pressures are given in kilopascals (kPa) in most other fields, where the hecto prefix is rarely used. The unit inch of mercury (inHg, see below) is still used in the United States. Oceanographers usually measure underwater pressure in decibars (dbar) because an increase in pressure of 1 dbar is approximately equal to an increase in depth of 1 meter. Scuba divers often use a manometric rule of thumb: the pressure exerted by ten metres depth of water is approximately equal to one atmosphere.
The standard atmosphere (atm) is an established constant. It is approximately equal to typical air pressure at earth mean sea level and is defined as follows:
standard atmosphere = 101325 Pa = 101.325 kPa = 1013.25 hPa.
Because pressure is commonly measured by its ability to displace a column of liquid in a manometer, pressures are often expressed as a depth of a particular fluid (e.g., inches of water). The most common choices are mercury (Hg) and water; water is nontoxic and readily available, while mercury's high density allows for a shorter column (and so a smaller manometer) to measure a given pressure. The pressure exerted by a column of liquid of height h and density ρ is given by the hydrostatic pressure equation p = ρgh. Fluid density and local gravity can vary from one reading to another depending on local factors, so the height of a fluid column does not define pressure precisely. When millimeters of mercury or inches of mercury are quoted today, these units are not based on a physical column of mercury; rather, they have been given precise definitions that can be expressed in terms of SI units. The water-based units still depend on the density of water, a measured, rather than defined, quantity. These manometric units are still encountered in many fields. Blood pressure is measured in millimeters of mercury in most of the world, and lung pressures in centimeters of water are still common.
Presently or formerly popular pressure units include the following:
  • atmosphere
  • manometric units:
    • centimeter, inch, and millimeter of mercury (torr)
    • millimeter, centimeter, meter, inch, and foot of water
  • customary units:
    • kip, ton-force (short), ton-force (long), pound-force, ounce-force, and poundal per square inch
    • pound-force, ton-force (short), and ton-force (long)
  • non-SI metric units:
    • bar, decibar, millibar
    • kilogram-force, or kilopond, per square centimetre (technical atmosphere)
    • gram-force and tonne-force (metric ton-force) per square centimetre
    • barye (dyne per square centimetre)
    • kilogram-force and tonne-force per square metre
    • sthene per square metre (pieze)
Pressure Units
pascal
(Pa)
bar
(bar)
(at)
atmosphere
(atm)
torr
(Torr)
pound-force per
square inch
(psi)
1 Pa≡ 1
N/m2
10
−5
1.0197×10
−5
9.8692×10
−6
7.5006×10
−3
145.04×10
−6
1 bar100,000≡ 10
6 dyn/cm2
1.01970.98692750.0614.5037744
1 at98,066.50.980665≡ 1
kgf/cm2
0.96784735.5614.223
1 atm101,3251.013251.0332≡ 1
atm
76014.696
1 torr133.3221.3332×10
−3
1.3595×10
−3
1.3158×10
−3
≡ 1 Torr; ≈ 1
mmHg
19.337×10
−3
1 psi6,894.7668.948×10
−3
70.307×10
−3
68.046×10
−3
51.715≡ 1
lbf/in2
Example reading: 1 Pa = 1 N/m2 = 10−5 bar = 10.197×10−6 at = 9.8692×10−6 atm, etc.
Good Answers: 53
01/21/2009 12:09 PM
1kG/cm2= Force of 1kg on an area of I cm2.
Lets convert in mm Of H2O.
take a tube of internal area if 1.0 Cm2 and fill it with the 1kg Of H2O. measure the total filled height of water.
shouldn't it be about 1000Cm = 10000mm Of water
assuming density of water 1.00.
Register to Reply 2 comments
