Previous in Forum: design and analysis of a staple pin remover   Next in Forum: Mine Hoist Brakes
9 comments
Pig Launcher - Support Locations
01/26/2009 3:45 AM
I am still on the pig launcher design, and have encountered another problem I think will need yor input.
In locating the support, I used ASME Standard for locating saddles. But since I consider the launcher more of a pipe than a pressure vessel, and because I am designing based on ASME B31.8, I felt I must have done something wrong.
I need your advice.
My Process parameters are,
Launcher is 24" x 28"; Reducer=.610meter, Major Barrel= 5.7 meter, Minor barrel= 1.5meter.
Design Pressure 100 Bar, Design Temp 50 deg Cent. It is transporting Natural gas.
Regards,
Chike Nwachukwu
Re: Pig Launcher - Support Locations
01/26/2009 10:30 AM
Even though you are designing "pipe" in accordance with B31.8 - you may/have to look to other standards/codes for your design. In your case, when a reducer size is not specifed by ASME B16.9 or MSS SP-75 you may design as a "conical head" as per ASME Sec VIII Div 1 in accordance with B31.8 paragraphs 831.36, 831.373 & Appendix A.
01/26/2009 12:13 PM
Reading your question again - what exactly is the problem?
B16.9 has a standard size for 28"x24" reducer.
01/27/2009 2:09 AM
Guest,
My question is that I want to know exactly how to determine the location of supports for the pig launcher, ang which code to use.
Chike.
01/27/2009 2:31 AM
(right - I was without my morning coffee when I read your question earlier)
You should design in accordance with the stress equations of B31.8 Sections 832, 833, 834. If you don't have access/knowledge of computer software (such as Caesar II) you will have to do it the manual way (which shouldn't be difficult as this is a pretty small system).
01/26/2009 10:56 PM
I need your advice.
Regards,
Chike Nwachukwu
Hi Chike,
Locate your major barrel saddle to be clear of the drain (2"?) and the kicker line. First trial 2.0 m from the QOC. Slope the launcher at 1 in 100 towards the drain. Locate the minor barrel saddle say 1.0 m from the end flange. Run Caesarii or Autopipe to check stresses.
BOL
Stewie
01/27/2009 2:15 AM
Thank you Stewie, I will do just that and get back to you when I am through.
Chike.
01/27/2009 3:48 AM
For manual design calculations for saddles, please refer to Pressure Vessel Handbook, 10th edition by Eugene F. Megyesy, Chapter Horizontal Vessels Supported by Saddles, Page 86 and a solved example Page 92.
(Pressure Vessel Publishing, Inc., P.O. Box 35365 " Tulsa, OK 74153)
01/27/2009 11:37 AM
Great,
I have the latest edition of the book. I made reference to it, that was the basis of my question.
Thanks,
chike
01/28/2009 2:18 AM
hi
please follow 31.3 for receiver and launcher
Register to Reply 9 comments
Abdel Halim Galala (1); Anonymous Poster (1); Chike Nwachukwu (3); Guest. (3); Stewie (1)
