Previous in Forum: presentation   Next in Forum: design build.
16 comments
Control Circuits for Streetlights
02/16/2009 2:49 AM
i am an electrical engg student doing my final project in streetlighting
what type of control circuit is good for street lighting...circuit with timer /sensor...?can i use both in one circuit
Good Answers: 62
Re: CONTROL CIRCUIT FOR STREETLIGHTS
02/16/2009 7:19 AM
Yes
and
Yes
02/16/2009 9:02 AM
You have two ways of making the control circuit. One is by way of 24 hours timer in the circuit which will switch ON and OFF the contactor at designated time. Secondly by way of photoelectric sensor in the circuit. This sensor can be adjusted to certain lux of light and will Switch ON or OFF the contactor if lux fall below the set limit or raises above the set limit respectively. Second method is most preferred method as the lights switch ON early during winter and late in summer which is required.
02/17/2009 7:16 AM
Hi,
24 Hour timer may not work unless the timing portion of the driver (That energizes the contactor coil) is electronic and backed up by a battery or ultra capacitors. A solid-state relay is recommended for switching the coil. Make sure to use a high commutation type of SSR.
Good Answers: 183
Re: Control Circuits for Streetlights
02/16/2009 9:57 AM
For energy saving it is also possible to use presence sensors. If a moving element > a critical size moves in the field light will go on and stay as long as the timer will allow it if the object does not continue to move.
Good Answers: 38
02/16/2009 11:02 PM
Yes, or you could use a PLC or you could use switches controlled by a computer program
Good Answers: 204
02/16/2009 11:35 PM
a book I was reading recently says you need to use a constant current circuit, with the lamps in series, so that if one bulb burns out, you don't over power the other lamps.
Good Answers: 38
02/16/2009 11:41 PM
In series? not parallel?
Good Answers: 204
02/16/2009 11:59 PM
yes
its an older book.. but these circuits are out there..
I checked again.. because what I know about this stuff could fill a thimble
Chris
Ireland - Member - New Member Engineering Fields - Energy Engineering - New Member
02/17/2009 12:55 AM
Interesting answers, but misleading. Your key word is street lighting.
Street lighting uses the most economical lamp source available, high pressure sodium (HPS) or metal halide (HIT). These sources do not respond well to being switched frequently (most manufacturers limit this to 6 per day). Interestingly, fluorescent is rarely used in street lighting, except maybe in tunnels and walkways, and respond better to frequent switching.
Presence detection is never used on street lighting:
  • the PIRs and wiring are too complex
  • it is difficult to cover a street with multiple PIRs
  • they are too unreliable
  • they are subject to vandalism
  • do not respond well to large fluctuations in temperature
  • there are legal implications with lighting turning off unexpectedly
Timeclocks are rarely used on street lighting, and never in public streets, only in amenity areas:
  • they are unreliable and require regular attention for changes in summertime
  • cannot respond to unusual circumstances, such as fog or bad weather
  • have legal implications to the relevant authority if the lighting turns off unexpectedly or at the wrong time
Photocells are used almost exclusively. If you look closely at some lanterns, you will see the culprit mounted on top of one of the fittings. This is wired to a contactor in the street lighting column, which will energise the whole circuit. There is generally a failsafe contact, such that photocell failure or destruction will trigger the circuit permanently on. The system is fit and forget; there are no timings to set, and the system will repsond to fog or snow etc. You may see a number of vertical rods around the detector, which are usually interpreted as lightning protection, but are there to keep birds from depositing their lunch
One alternative is an impulse contactor, which receives a timing impulse sent along the mains, from a central control. These are increasingly rare.
A recent project here in New Zealand was Wellington's Waitangi Park, which used a lighting control system called C-Bus. In general however, local councils do not have the inclination, budget, or wish the legal exposure associated with failed street lighting. One accident or injury can cost many $100,000s, even just to defend a case, so the energy saving associated with complex controls is non-sensical.
I love deadlines; I love the whooshing sound they make as they pass by. - Douglas Adams
02/17/2009 3:22 AM
GA from me too
Good Answers: 38
02/17/2009 3:34 AM
You are right, when i gave my answer i was under the impression that he meant traffic lights
Good Answers: 68
02/17/2009 1:00 PM
Hello BabyGuinness:
A very easy to understand and well written piece.
GA to you sir!
02/19/2009 3:42 PM
does it have long life?.....I think there will be a chance of unexpected operation,even if i go for photocell due to dust particles....
02/20/2009 8:59 AM
Excellent answer and viewpoint.....when it comes to dealing with local authorities on "projects", their question is never what is efficient; it is always "how little can we spend" and do we have any liabilities? From an engineering standpoint, we constantly look to improve and update, but the real world environment will almost always rise to roadblock you.
oldgolfer
02/17/2009 8:29 AM
I am a member of this forum, but at the moment I don't remember my password, so I am answering as a Guest.
BabyGuiness offered a very good answer. Here are some more items to consider.
1. If the street lights are spaced very far apart, such as only at intersections in a residential neighborhood, the best way is with individual photocontrols on each luminaire. The lamps will come on at dusk and go off at dawn year round. Most luminaires will come with a twist lock receptacle on top in which you can mount the photocontrol. Some will even come with the control mounted as an integral part of the luminaire. If not, you can mount them on a bracket adjacent to the luminaire.
2. If you are lighting a major thoroughfare you might want all the lights to come on at the same time. You can install a photocell at the source of the power and it will energize the circuit at dusk, but this is limited capacity and only works for a few lights. You can also use a relay in conjunction with a photocontrol to energize the circuit at dusk. The relay should be normally closed. That way if the photocontrol fails the circuit will come on and stay on all the time instead of staying off all the time. Most relays are going to be 30 amp or 60 amp. If you exceed that, you can cascade relays or use a pilot wire. The pilot wire would be hot during the day time and would hold several normally closed relays in the open position. Then it goes off at dusk, allows the relays to close, and energizes the lighting system.
3. Timers are not normally used on street light systems because it gets dark at different times during the year. If you were doing an area lighting project, such as a large parking lot at a shopping mall, then you could use a time to turn the lights off after the mall is closed. The says some energy because the lights are not on all night, but may cause some security problems.
4. Street lighting systems are rarely set up in series anymore. I haven't seen a series street lighting ciruit in over 30 years.
Jim Cartwright
Good Answers: 68
02/17/2009 1:08 PM
Hello 'Guest'
GA to you sir for your good answer!
PS "CR4, The Engineer's Place" cr4admin@globalspec.com Send an email to admin and they will sort your password out for you.
Take care...............
Register to Reply 16 comments
Anonymous Poster (2); babybear (2); BabyGuinness (1); chrisg288 (2); edignan (1); Epke (3); gsuhas (1); nick name (1); oldgolfer (1); vins (1); zodiac (1)
