Previous in Forum: what is the formula to determine blank diameter of ellipsoidal head ?   Next in Forum: license agreement
Mysterious Viscometer
03/03/2009 9:21 AM
We run a training lab for paint technicians down here and we are always on the scrounge for redundant equipment - we either use it if we can or put it in our museum if we can't. This animal which is essentially a ball and cup was given to us and it has got us all beaten as to how to use it.
There are two slots in the box which obviously held levers of some sort.
Has anyone out there seen this animal before and know how it is used
You can always tell the pioneers - they are the ones with arrows in their backs.
Re: Mysterious Viscometer
03/04/2009 12:22 AM
A commercial viscometer has recently come into use, which is of
exceedingly simple type, and gives fairly usable results. A steel
1 m. in diameter is placed inside a hemisphencal steel cup of
slighhtly larger dimensions. The cup carries on its internal surface
three small projections in length about 0-002 in. A little of the oil
under examination is poured into the cup, and the ball placed in
position inside the cup. The ball is pressed down on to a table,
; cup being uppermost, and at a given instant cup and ball are
lifted clear of the table. The time taken for the ball to detach itself
is measured, and this gives a measure of the viscosity of the oil.
THE MECHANICAL PROPERTIES OF FLUIDS c.1946
03/04/2009 2:57 AM
That makes sense - but this one has no projections in the cup. - Will try it.
Must use the principle that the weight of the ball coupled with the viscosity must be enough to break the vacuum.
03/04/2009 12:25 AM
Just a suggestion, but I would try looking up the patent. I'd do it, but I can't quite make out the number in the photo. There are a few sites where you can look up patent documents for free (one being www.freepatentsonline.com). It would be interesting to see how it should be used.
03/04/2009 12:31 AM
Took a guess at the patent number, and found it on free patents online. http://www.freepatentsonline.com/1786574.pdf (but you have to create an account and log in first).
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
03/04/2009 6:46 AM
Hi hazman,
That Viscometer has some remarkable breeding. Its inventor was GA Michell, the same person who invented the Michell thrust bearing around 1905 and used on most ship drive shafts. He was an Australian, born 1870 and The Institution of Engineers, Australia has an annual award of his name for outstanding engineering achievements.
There is a little more, and longer story of info below which may be useful in keeping close to your device for future generation's knowledge. Also, have a look at http://www.adb.online.anu.edu.au/biogs/A100480b.htm
George Anthony Michell was born in 1870 when his parents were visiting England. The family returned to Australia and Anthony Michell enrolled at the University of Melbourne, graduating with a BSc in 1887, gaining first place in civil engineering and second place in mining engineering. He obtained his Master of Civil Engineering degree from Melbourne University later. Michell had emerged from his educational environment as a man with excellent mathematical ability and a bias towards using this ability in the solution of engineering problems. Professor Osborne Reynolds of Manchester University, whose work forms the basis of much of our knowledge of fluids in engineering, had written, in 1886, a paper describing the twodimensional behaviour of a film of lubricant. He drew attention to the need for the thickness of the film to decrease in the direction of the motion of the surface if there were to be a build-up of pressure within the film. Michell had worked with pumps and turbines, had encountered the necessity to accommodate thrust in the axial direction and recognising the value of Reynolds' findings, he undertook fundamental research in 1902-1904 to generalise that work for application in engineering. Michell displayed versatility in his contributions to engineering knowledge. He published some early work on frame-structures, moved into hydraulics, then into fluid mechanics and lubrication. His thrust bearing received international recognition and adoption. This was his most successful achievement and by 1915 these bearings were being installed on almost every ship. His journal bearing using the same principle was an engineering success but, since there were in existence good alternative bearings, there was no demand for it. The crankless engine followed. In this design a collar was set obliquely to the shaft, which upon rotation imparted reciprocating motion, parallel to the shaft, on a number of pistons arranged in a circular array. when the shaft was driven, this mechanism provided a pumping action; the swashplate pump, using this principle, has found many useful applications. Alternatively, the mechanism could be operated as an engine, by using the pistons as the source of power. A wide range of internal combustion engines and compressors were built to his design. It is regrettable that Michell's renowned engineering ability was not matched by business acumen, which could have resulted in much greater financial rewards for his outstanding work. Michell's versatility is evident in the 48 patents bearing his name. His approach to problem solving was well described by Professor A. Robertson who, in comnenting on a viscometer produced by Michell said '... a typical Michell invention: a mathematical analysis and then a clever device to effect the desired end. Hope this may be helpful and interesting AussieBob
Anonymous Poster (3); AussieBob (1); hazman (1)
