Previous in Forum: What's the Best Damper Coating for Water Pipes?   Next in Forum: Pipeline Integrity
10 comments
Standard Colors for Pipe Lines?
03/17/2009 11:43 PM
can you help me to know Standard colours for following pipe line used in industrials.
01. Normal water
02. Hot water
03. Diesal (for genarator)
04. Compresed air
05. Hydraulic oil
Good Answers: 51
Re: standard colour for pipe lines
03/18/2009 1:17 AM
If you don't have any company standards, country/local requirements, nor Occupational Health and Safety regulations to follow, you could go with ASME A13.1:
A little knowledge is a dangerous thing.
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
03/19/2009 2:41 AM
GA, XMech!
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
03/19/2009 10:22 PM
thank you. my country is Dominican Republic. what are the standard colour for pipe line.
Good Answers: 51
03/19/2009 10:56 PM
I do not know - you will have to check with your local government/agency/regulator/insurer - it should be in an "Occupational Health and Safety" (or similarly titled standard) regulation.
Good Answers: 58
03/18/2009 2:05 AM
Good advice from XMech (as usual).
Guest, we do not know your location, but if you were in South Africa the following could be appropriate. http://www.neutron.co.za/pipes.htm
These colours are not too different from those I have seen in other parts of the world, but note the disclaimer and take into account your own country's laws and requirements if applicable.
NOSA = the South African National Occupational Safety Association
Good Answers: 51
03/18/2009 2:04 PM
Thank-you
03/18/2009 4:13 AM
Following on from above, it is unneccessary to paint the pipes throughout, as self-adhesive tapes with the colour and lettering already printed are readily available. The tapes simply stick onto the pipe, or indeed, over its insulation cladding. Arrows are also available to indicate the direction of flow.
In the case of plastic pipes in particular, one is far better off with self-adhesive tape banding. One wouldn't want to affect the plastic structure underneath in any way.....
Re: Standard Colors for Pipe Lines?
03/19/2009 2:48 AM
for the UK
You can always tell the pioneers - they are the ones with arrows in their backs.
03/19/2009 8:28 AM
If you will use in Argentina, IRAM code indicates the following:
07/03/2009 2:08 AM
And what about background color in case when pipe color is the same as marking colour? Is it white? In ISO_14726 there is NO information or reconendations about it.
Anonymous Poster (2); ernesto1962 (1); hazman (1); langyaw (1); PWSlack (1); The Prof (1); XMech (3)
