Hi,
Just yesterday we were having a discussion in office and were explaining to a new batch of embedded engineers the various methods of AC motor control. While explaining the pwm control (by generating a 3Ph Sinusoidal Alternating current from 310 V DC) we were unable to explain certain phenomenon to them. (Things that could be measured and were sure happening, but we couldn't explain how in mathematical or even conceptual terms.)
Consider the case where the three coils are powered using the basic drive setup of 6 switches 3 top and 3 bottom. (I have not detailed the connection as it is most general. but will present it need arises. the top side switch driver is powered throug a Boot Strap Capacitor arrangement.) When we produce a 50% duty cycle switching pwm for the three phases A, B and C without any phase difference, we find that the voltage between the points A and N, B and N and C and N is 155. But since at any given time either only the top 3 switches are open or the bottom 3 switches are open There is no apparent closed loop for the current to flow. But still the voltage exists. We understood that the inductor's (motor coil) property was responsible for the current flow to happen but were not able to mathematically pen that down or derive an equation to show what was happening as we did not have the requisite details at hand.
I have put forth my hypothesis based on my understanding. Please correct me if my understanding is wrong. Also if there exists an existing explanation please direct me towards the same. hopefully which explains what is happening with help of maths.
I am attaching the image herewith. And the explaination follows suit.
In the case depicted above the terminals A, B and C are the end terminals of a 3 Phase AC Induction Motor. When A PWM switching is done at a frequency of 16 KHz (time period 64us) with a centrally alligned pulse train with 50% duty cycle All three terminals are together switched to connect with the 310V DC Bus or with the 0V line.
This effectively means that no current flow happens in the Bus. But a voltage of 155 is generated between the points A and N, B and N and C and N, as stated earlier in the post. My theory is as follows.
As per the diagram in State 1, when the motor/system is not powered ON ideally the motor is in off state but the potential on the coils is disputable but all the terminals would be at the same potential, represented as 'x' V DC (ideally should be at 0 V DC but to avoid this being the centre of argument we take it as some potential 'x').
State2: The Top side switches are conducting and the terminals A,B,C are subjected to 310 V DC supply. At this time instant of time the voltage at the coil junction N is at the previous state of 'x' V DC. The coils being inductive in nature cause a delay in the change of potential at that point N to attain 310 V DC during that time a charging current (choosing the conventional representation of current, flow of curent from higher potential to lower potential, though actual flow of electrons occur from lower potential to higher potential) would flow from A to N, B to N and C to N, causing the three coils of the motor to charge in the process until the potential at the point N reaches 310 V DC. This flow of current is internal to the coils only and a flow of current does not actually occur in the bus system (Gustav Robert Kirchhoff (12 March 1824 – 17 October 1887) would be really angry with my assumption)
Please remember the time taken for the switching is 64us/2 = 32 us.
State 3: The potential in the coils is stabilised to 310 V DC, i.e., potential at points A,B,C and N is the same, 310 V DC. And well no current flow happens inside the coils even.
State 4: The top side switches are all turned off and the bottom side switches are turned ON, connecting the 3 motor terminals A, B and C to the 0V DC bus line. At this instant the potential at the point N is still 310 V DC and hence the current flow occurs in the coils with direction N to A, N to B, N to C discharging the coils in the process until the potential at the point N drops down to 0 V DC.
State5: The potential in the coils is stabilised to 0 V DC, i.e., potential at points A,B,C and N is the same, 0 V DC. And well no current flow happens inside the coils as in State 3.
State 6: This state is simillar to State 1, but for the difference that the potential at N is defined as 0V DC and no more as 'x'. (But that really depends as to whether the coils are able to charge and discharge within the said 32us and less.)
The states 7, 8 and 9 are the continuation of the cycle.
We probably see 155 V DC as the averaged out value of the result of this switching.
Question 1: Is my understanding and my hypothesis correct?? If so is there a mathematical model or an explaination based on a set of equations available?? If so please provide the link.
Question 2: If my understanding is wrong please correct me. and provide the links to the mathematical or equation based models of the system.
I have no doubt about the result of the switching as it is available as proof to see on a practical front. The question is how does it happen.....
And another question:
This point was raised by a new colleague.
Take a battery of some 'X' V DC. Now if a wire A is connected to the positive terminal of the battery with its other end still being open and a wire B is connected to the negative terminal of the battery with its other end still being open.
What will the potential on the wires A and B?
Does a current flow from the battery terminals to the wires A and B until the potential is raised or lowered in the wires to the same as at the respective terminals of the battery that they are connected to?
What is the potential at the Battery terminals?
My answers are: The potential at the +ve terminal is X V DC higher than at the negative terminal
The potential at the wire A connected to the +ve terminal becomes the same as the potential at the positive terminal of the battery, in this case X VDC higher than at wire B connected to the negative terminal.
Yes, some current would have flowed in the wires A and B before they stabilised to the terminal potentials, may be for a nano second or less. but in one of the wires the current fow may have been into the battery terminal and in one it would have been out of the terminal and into the wire (asuming the wires were at simillar potentials)
My friend/colleague disagrees with me. He accepts that the potential on the wires is same as the potential at the terminal but disagrees with the opinion that a potential of 'X' V DC exists at either the terminal or on the wire A and likewise a lower potential at the other terminal and wire B.
Please advise.
