Previous in Forum: How To Obtain Actual Weight of Stairway   Next in Forum: Counter Weight for crude oil storage tank
Indonesia - Member - Member from Indonesia Engineering Fields - Mechanical Engineering - Mechanical Engineer Popular Science - Weaponology - Weapon Fan Safety - Hazmat - Safety First! Hobbies - Automotive Performance - Tuner Wannabe Hobbies - Target Shooting - I'm a good shooter
Davit for 24" Vertical Opening
03/21/2009 7:11 AM
Dear CR4 Master..
Can anyone know or predict, how much is the weight of davit for 24" vertical openings? Including davit arm, sleeve, stiffening, U-bar, eye bolt, opening handle, etc.
This is to help me to fill in my project bill of quantity (BoQ).
Thank you very much..
Please give respectful & positive answer than insulting! Respect each other ok..
Re: Davit for 24" Vertical Opening
03/21/2009 8:54 AM
For your info, the material is carbon steel A36. Thank you..
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
03/21/2009 11:55 PM
Hi Premium
You will probably find that no one will be arsed to do the sums for you even given the info so.......why don't you do it!
Rough out the volume of materials in meters cubed and then multiply by 7806 = kg!
Go for your life!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
Good Answers: 51
03/22/2009 12:25 AM
If you are at a lose you can refer to a "standardized" davit assembly within Process Industries Practices (PIP) PIP VEFV1100:
http://www.pip.org/practices/vessels/index.asp#VEFV1100
http://engineers.ihs.com/document/abstract/JZEVIBAAAAAAAAAA
Here is an example contained within:
A little knowledge is a dangerous thing.
06/21/2023 3:10 AM
...and if all that fails, try phoning the supplier, and asking directly.
Invitation declined.
Register to Reply 4 comments
Beej50 (1); Premium (1); PWSlack (1); XMech (1)
