Previous in Forum: How to Design a Pump Impeller   Next in Forum: Straight Runs for Pumps
How to Test Offshore Winches
03/31/2009 2:40 AM
hi all
Can anyone provide me information about how to conduct winches test in Offshore air winch.
More what are the ways to test the winches.
Pathfinder Tags: oil winch
Location: Currently on break at home in Houston, Texas USA
Re: How to Test Offshore Winches
03/31/2009 11:32 PM
The best way to test marine air winches is to load them up using a piezoelectric strain-gauge block made for this purpose. One end of the gauge is attached to the tugger's spool of cable and the other end to something that you are not about to rip off the deck or gunnels. Run up the air to the specified psi of the tugger, slowly take-up the slack, and then stall it. Read the gauge and you got the max pull of the tugger. You can also have a service company come in and certify those tuggers for you. Hope this helps.
04/01/2009 12:14 AM
thank you sir...
04/01/2009 2:34 AM
You can also use loaded water bags which have a calibrated tonnage then you can do running load tests rather than static, this will load all of the cable to its max operating loads. Your cables need to be proof tested at intervals required by US coast guard or Loyd's, Norske Veritas etc these should be done by shore side certifiers
04/01/2009 4:36 PM
GA, too Garth. I've read about this technique but never seen it done. Working in the Caribbean and GOM, everything is usually done Quick and Dirty. And Yes, a Load Cell is to be used in either technique. A Strain Gauge - I must have been deluded!
04/02/2009 2:12 PM
Testing the Tension on a cable partly depends on how accurate you need to be and the size of the winches and cables. If you were on a sail boot you would check and adjust the standing rigging with a deflection gauge that you can get any sailboat shop.
Having fun,
Mike
04/01/2009 8:36 AM
Typically we would normally do a load test, using a waterweight and load cell to ensure that the prescribed Safe working load is not exceeded. you may also want to do NDT on the wire rope connection, shackles, swivels.
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
04/01/2009 1:00 PM
When I tests me winches, I likes ter gettem good un drunk farst. ARRRGH!~!
If necessity is the mother of invention then is laziness the mother of necessity?
Register to Reply 7 comments
Anonymous Poster (2); double_j_b (1); garth (1); shivarajs (1); tropicalspeed (2)
