Previous in Forum: Windows XP Pro - Access Denied   Next in Forum: Threading Symbols for AutoCAD 2007
25 comments
Engineering Fields - Piping Design Engineering - New Member
Renaming Worksheet Tabs in an Excel Workbook
04/02/2009 2:28 AM
Hi All,
At the bottom of the each worksheet in the excel document window is a small tab that indicates the name of the worksheets. In my workbook, sheet names are named like sheet1, sheet2, sheet3, sheet4 and upto sheet25. I want to rename the sheet1, sheet2..... to Proposal1, Proposal2, Proposal3,....upto Proposal25. That means I want to replace "sheet" with "budget". I hope all of you know renaming the sheet names individually is time consuming. Is there any way to use replace all features to change the sheetnames in sheet tab of a workbook. Or any quick way to rename the sheetnames will help.
Advance Thanks
User-tagged by 1 user
Re: Replacing the name of the worksheet in excel workbook
04/02/2009 4:25 AM
  1. right click on the sheet label
  2. left click on "rename" in the drop-down box
  3. type away
  4. press return
  5. "Robert is your mother's brother."
04/02/2009 11:31 PM
Hi, If you are familiar with Visual Basic you could write a short code in order to rename each tab.
If you don´t know you are proficient in VB, just press F11 and you will know.
Thanks and luck.
Re: Renaming Worksheet Tabs in an Excel Workbook
04/02/2009 11:02 PM
seems that there is no way to make it as a lot , finish one time.
just change it one by one .
Jason~Zen
04/02/2009 11:19 PM
You can select multiple sheets by holding Ctrl button then go through the process PW gave you. I can't remember if it will automatically sequence... to unselect when you finish, single click on an unselected tab.
Good Answers: 204
04/03/2009 3:16 AM
no clicking necessary.. just hit enter, after typing, and the ctrl-pgdn to go to the next sheet, or ctrl-pgup to go to the previous one.
and you can do anything in vba that you can do manually, so don't listen to those who say it can only be done manually. you are ten generations into excel here.. it is the most powerful calculator application on the planet... and has that reputation for a reason.
Chris
Good Answers: 204
04/02/2009 11:22 PM
the answer is: VBA!
http://excel.tips.net/Pages/T002145_Dynamic_Worksheet_Tab_Names.html
this is just one hit.. you can find more
if you need more help.. just yell
Chris
04/03/2009 1:14 AM
Thanks Chris, It worked.
Canada - Member - BC Born, Alberta Raised, Quebec (poutine) crazed... Engineering Fields - Aerospace Engineering - An airplane is just a bunch of beams... Hobbies - Model Rocketry - Had fun as a kid...fun stuff Hobbies - CNC - dreaming of cutting Engineering Fields - Control Engineering - PID ME!
04/03/2009 7:22 AM
I wrote an inverse to this...dynamically naming a cell the same thing as the sheet!
i.e. So in sheet Budget 234 you can have a title saying Budget 234
Add this in your vb editor:
Function sheetname() As String
sheetname = ActiveSheet.Name
End Function
and then just put =sheetname() in the cell you want the title to show up in and hit enter. tada! The most used one-liner in my arsenal.
So now copy as many of the template sheet as you want...name them whatever you want and have their contents customized a bit automatically! I use this whenever I have loadcase specific calculations (I do stress engineering) or dated data...anything with repetitive sheets and very similar contents.
kkjensen
08/31/2009 7:21 AM
Hi Chris..
I also used ur "ONE HIT" vba .. BUT......
it is usfull for a new and only one worksheet. If a user has already created more than 30 workbooks with various names. Now He wants to rename all sheets as Product1~Product30..... in this situation how can we use this VBA..
u can email me at tiputhelord@gmail.com
thanks
Adil
Good Answers: 204
08/31/2009 12:59 PM
the following will help to flip through the collection of tabs in a sheet.
Sub NextSheet()
Dim lCount As Long
lCount = Sheets.Count
If ActiveSheet.Index = lCount Then
Sheets(1).Select
Else
Sheets(ActiveSheet.Index + 1).Select
End If
End Sub
source discussion:
http://www.ozgrid.com/forum/showthread.php?t=55989
Chris
09/01/2009 2:18 AM
Hi chris
Thanks 4 ur quick reply
I copy this If Then Else Statement ditto.. after pressing Alt+F11. and when I run Macro.. It' doesn't work....
May be I m not familiar to this VBA Environment or there may be some other problem...
Good Answers: 204
09/01/2009 8:43 AM
Hi,
I'm out of province right now, and will be away for the next week, but if you want to send your sheet, or a reasonable sample to me at chrisg288@hotmail.com, I will look at it. Are you running on 2003 or 2007?
Chris
04/03/2009 12:30 AM
Hi ,
Try this . It'll work .
1. open the xls file .
2. Press Alt+F8.
3. Give a macro name .
4. Press create button . It will go to VB Editor.
5. Copy the following code before the end sub.
Const sBase As String = "Budget"
Dim i As Long
Dim sh As Object
For Each sh In ActiveWorkbook.Sheets
i = i + 1
sh.Name = sBase & i
Next sh
Save it .
Run the program by pressing ALT+F8.
The macro will rename all your sheets at once.
Regards
Earnest.
04/03/2009 12:51 AM
Earnest,
Hats off!
Thank you very much, it worked.
Nayek
01/24/2012 12:45 PM
Dear earnest
I used to work with a excel book contain 35 sheets at least.
I used to change all tabs name manually.
pls give me a way to come out from this
I am very new to VB
pls u can email me with attaching a sample excel file : CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
04/03/2009 2:30 AM
No there is only one way which you already know.....Bali
04/03/2009 8:22 AM
Right click on the tab and rename it.
04/03/2009 10:04 AM
If you right click on the tab it will give you the option to rename that tab you chose.
Good Answers: 75
04/03/2009 12:15 PM
#14. The reason ALL "Guest" answers get such short shrift. What an idiot!!
No understanding of the idea that we answer because we LIKE to offer information, in exchange for information. And Navek undoubtedly knows SOMETHING I will need to know, but don't even realize I will need to know it.
I came here to offer a solution to the problem. I still haven't seen MY solution offered, but I've found several so far ahead of it, I'm not even going to bother. I like your answers SO much better! ANd that, too, is a great reason we even bother.
The real question is, with an attitude like that, why does the "guest" even bother to breathe?
Micah
04/03/2009 12:58 PM
To guest / 'Blonde' commentor about free info. I've found the best answers happen when people Read the post properly before flying off the cuff.
Go back and re-read the post, the originator was looking for a way to do multiple sheet renames an with an incremental replacement rather than doing it the individual way - Not likely a "homewaork" problem. It's a question that has occurred to me while renaming sheets manually. The solutions offered here are fantastic, unique and I will use.
I appreciate the willingness of people to contribute and share, that's the way I prefer to advance the knowledge and experience of my staff. If you don't feel that sharing is appropriate and that people should be derided for asking questions or offering solutions, then perhaps this isn't the forum for you.
And if they are blonde, that's fine too.
Good Answers: 75
04/03/2009 1:24 PM
You and me both,. brother.
Bravo.
Micah
Good Answers: 12
04/05/2009 2:16 AM
I learned something out of this!! And I used to be blonde (before Excel was invented) and I even tried dancing around a hat naked, but it didn't get me any women... in fact they all ran away.
Bill
04/06/2009 3:29 AM
Dear Guest,
Please reread the question I posted. Everybody knows how to rename a sheet manually in excel. My question is how to rename multiple sheets quickly like using replace feature to replace value in multiple cells. This is not a homework project.
Everyone gives valuable answer in this forum for free. I appreciate everyone who given answers. This forum is for sharing knowledge. I think this forum is not for you.
YOU ARE GIVING NON-SENSE THINGS FOR FREE. THIS FORUM IS NOT FOR YOU.
WHAT KIIND OF HUMAN BEING (GUEST) ARE YOU
Nayek
09/01/2010 8:05 PM
I had 200+ sheets to rename and that little macro did it instantly.
Thanking you
Good Answers: 204
09/01/2010 11:09 PM
To whom are you speaking?
Register to Reply 25 comments
ad2ad79 (2); Anonymous Poster (4); Bali (1); chrisg288 (5); earnestpaul (1); FAHMED (1); jasonzen (1); JoseLuis (1); kkjensen (1); micahd02 (2); Nayek (3); PWSlack (1); rjyou (1); Sciesis2 (1)
