Previous in Forum: CAPACITOR CONNECTION TO VARIABLE-FREQUENCY DRIVE for Improving Power Factor.   Next in Forum: Standards for Power Transformer Protection
fundamental circuit design of ac drives
04/05/2009 11:20 AM
hello everybody this manoj .........
i am electrical engineer and have a keen interest in learning the modern control circuitry of motors............
i look forward to your help
Good Answers: 244
Re: fundamental circuit design of ac drives
04/05/2009 12:16 PM
If you are a beginner in this field, first try these links and it will help.
For VFD:
http://oee.nrcan.gc.ca/industrial/equipment/vfd/index.cfm?attr=24
http://www.joliettech.com/what_is_a_variable_frequency_drive.htm
If you have time, you can use this link for Soft Starter (I found it a good document for soft starter):
http://library.abb.com/global/scot/scot209.nsf/veritydisplay/2985284834bcff7fc1256f3a00274038/$file/1sfc132002m0201.pdf
-MS
04/07/2009 9:41 AM
thank you friend............
i went through the articles you recommended. now i want to know the circuit which are required to fire the igbts at regular or at desired angle as to control the voltage and frequency of the inverter output....
hoping to receive your co-operation
04/07/2009 3:46 AM
Hi this is FARRUKH ADNAN the recent problem which you are facing tell me that i have done specialization in the field of variable frequency drives D.C drives Servo drive but you suppose to tell me that which motor r u using then i will let you know that what will be you next action got it so do inform me as soon as u can.
NOYHING AS IT SEEMS AS IT APPEARS TO BE
Register to Reply 3 comments
farrukhst (1); mannbhel (1); msamad (1)
You might be interested in: AC Motor Drives, AC Motors, DC Motors
