Previous in Forum: Thermomechanical Control Process (TMCP)   Next in Forum: Material Hardness
11 comments
Hobbies - Musician - dadbob
Solvent Fumes and Explosive Limits
04/13/2009 11:01 PM
What would one experience upon walking into a room containing an explosive limit of the vapors of most flammable solvents ...in terms of detecting the danger?
Good Answers: 1693
Re: solvent fumes
04/13/2009 11:30 PM
New here? Have you done any preliminary work, like Google?
In the broadest of terms, generally enough discomfort to want to immediately leave the room. Nose, eyes, lungs, throat will all tell you something is wrong.
Explosive limits vary greatly: Google LEL/UEL of flammable solvents to see this.
Google physical effects of solvent exposure.
Welcome. There are some really smart dudes here, present company excepted.
Good Answers: 93
Re: solvent fumes
04/13/2009 11:33 PM
typically you will get a sinus headache.
You don't get wise because you got old, you get old because you were wise.
Re: solvent fumes
04/14/2009 2:23 AM
The long arm of the Health & Safety Executive upon one's shoulder.
Good Answers: 101
Re: solvent fumes
04/14/2009 4:54 AM
One vital hint: don't try this while smoking .
Good Answers: 196
Re: solvent fumes
04/14/2009 11:33 PM
Also avoid the instinct to switch the lights on. Unless they are all explosion proof electrical fixtures.
Ed Weldon
Re: solvent fumes
04/15/2009 8:28 AM
...or if they are already on, do not switch them off either!
Nor any other equipment either......
Its best to get away from the fumes, find the switchbox and power off the whole house immediately, provided of course that the fumes are 100% not in the area of that said box!
Re: solvent fumes
04/14/2009 7:23 AM
And under what circumstances would a room contain an LEL of flammable solvent vapour?
Wouldn't this indicate a material containment problem that needed to be corrected and prevented to recur before a random source of ignition came floating by?
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: solvent fumes
04/14/2009 7:34 AM
I strongly suggest a device such as this:
http://www.indsci.com/products/portable/m40.aspx?id=344 - sorry, link no longer available
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Good Answers: 120
Re: solvent fumes
04/14/2009 11:29 PM
Many of the hydrocarbon gasses are anaesthetic at these levels and you may pass out. In addition, some are toxic and can kill you. You can also be suffocated if there is no longer enough oxygen to support life, but this is an extreme case.
You should consider the density of the gas that leaks into the room. Some sink, and some float in air. Ceilings can get filled with light gasses, climb a ladder and fall off.
CO2 can fill basements, go down the stairs and never climb up.
Another thing, tanks of Kerosine/gasoline are very dangerous if you fall in, because you will sink in the light liquid right to the bottom. A 200 pouns man will feel a weight of about 40-50 pounds dragging him down. All such tanks have guides on the bottom, so close eyes, and follow the guide to the wall with your feet and a ladder will be there. Workers are trained in this and as long as you do not aspirate any hydrocarbons, you can get out.
Per Ardua Ad Astra
Re: Solvent Fumes and Explosive Limits
04/15/2009 2:23 AM
With an oxygen plant I installed, we had a situation where birds would roost on the outlet, which was exhausting pure N2.
The area around frequently had dead birds. They had simply gone to sleep from oxygen starvation and never woke up.
Not the action of a solvent of course, but the action of most chemical vapors is similar - a displacement of oxygen.
There have been numerous cases where a worker entered an incompletely ventilated tank, passed out and his mate jumped in to save him, also passed out, etc. Usually the third or fourth worker wakes up and races off to get breathing apparatus or similar.
While many solvents are also toxic, O2 displacement will knock you out faster than the toxic effect. One lung full is normally enough.
The gases being within the flammable range has little bearing, unless it is right down near the lower flammability limit (you may then get enough O2 to realize something is wrong and get yourself out). You will certainly feel woozy, possibly also start to hallucinate, if the O2 is reduced but still enough to survive for a while.
The vapor itself will probably also make you nauseous.
If you break your safety lamp and it shorts while you are in there, you may leave considerably faster than you would like, although you have a good chance of being beyond caring by the time you are out.
Good Answers: 243
04/15/2009 11:00 AM
If one drags their feet or wears garments that creates static, as others have suggested, a large noise, being knocked down, and sudden onset of burns and loss of exposed hair where one's skin is exposed, would be the experience that would inform one - too late, but clues nonetheless.
milo
Register to Reply 11 comments
Andy Germany (1); aurizon (1); Bricktop (1); DVader1000 (1); Ed Weldon (1); lyn (1); Milo (1); PWSlack (2); sceptic (1); Transcendian (1)
You might be interested in: Solvents, Fume Hoods, Vacuum Traps, Getters and Filters
