Previous in Forum: Calculating Resistance for Slip-Ring Induction Motors   Next in Forum: Who Makes the Best Switchgear Motor Controls?
9 comments
Vector Groups for Transformers
04/16/2009 10:30 AM
How we decide a vector group for a tranformer ?
suppose a 2.5 Mva 6.6/415v transformer then which type of vector group is suitable for this?
Good Answers: 244
Re: vector group
04/16/2009 11:28 AM
Please search for 'Vector Group' in this forum and you will find lot of valuable information which will help you to find the answer. The most recent posting for Vector Group is http://cr4.globalspec.com/thread/35957#comment374937
- MS
Re: vector group
04/16/2009 11:26 PM
Dear Sir,
I think, these are the common vector group of power transformer.
Yy6, Yy0, YNyn8, YNyn2, YNyn10, YNyn4, YNyn6, YNyn0 ,Yy0, Yy6, YNyn2, YNyn8 ,YNyn4, YNyn1,YNyn0, YNyn6, Yd1, Yd7, YNd1, YNd7, Yd5, Yd11, YNd5, YNd11, Yd7, Yd1, YNd7, YNd1, Yd11, Yd5, YNd11, YNd5, Dd6, Dd0, Dd0, Dd6, Dy1, Dy7, Dyn1, Dyn7, Dy5, Dy11, Dyn5, Dyn11, Dy7, Dy1, Dyn7, Dyn1, Dy11, Dy5, Dyn11, Dyn5, YNzn1, YNzn7, YNzn5, YNzn11, YNzn7, YNzn1, YNzn11, YNzn5, Dzn0, Dzn6, Dzn2, Dzn8, Dzn4, Dzn10, Dzn6, Dzn0, Dzn8, Dzn2, Dzn10, Dzn4.
I want to know about main difference between these vector group transformers (construction wise, winding wise, advantage wise and cost wise)
Somebody is using Dyn11 for low voltage distribution but somebody is using Ynd5 for same purpose.
I got confused that what is the advantage over there by using different vector group transformer for the same purpose.
Please clarfy.
Best Regards
U. Elambarithi
Re: Vector Groups for Transformers
04/17/2009 2:57 AM
Dear all,
Probably, Dyn11. But make sure what is the standard in your area or country.
Regards
Akihito Shigeno @ JGC-Indonesia
04/17/2009 9:52 AM
@ akihito
how u decide Dyn11.
Good Answers: 244
04/17/2009 4:56 PM
I agree to Akihito' selection of Dyn11.
I think by 6.6/415v you meant 6.6KV/415V
From this voltage system, it seems you may not have neutral in HT side but have it in LT side (for single phase use). So in 6.6KV side Δ should be fine but in 415V side, you must need Y with neutral. So Dyn is your selection. The phase lagging (last numerical digits) doesn't matter to you if you don't use it in parallel but 11 is most common. So, Dyn11 is ok on this basis.
If you would like to use it in parallel with any existing transformer, you must select it with the same vector group of the existing one.
Hope you understand.
- MS
04/17/2009 9:34 PM
@ msamad
If i want to use it in parallel then how phase lagging affect it?
Good Answers: 244
04/17/2009 9:48 PM
Then, there will be a voltage difference between the same secondary phases of the parallel transformers and both transfomers will be damaged (or tripped by the protection as soon as it is energized).
-MS
04/18/2009 9:46 AM
How voltage difference B/w the same secondary if they have same vector group t.i
Dyn1?
01/07/2012 5:47 AM
Boss, its wont affect if the vector group is same for both transformers connected in parallel....
He has discussed the case if the transformers are of different vector groups.
Register to Reply 9 comments
Akihito Shigeno (1); Anonymous Poster (1); lalit_nawada (3); msamad (3); Vinodh (1)
You might be interested in: Transformers, Power Transformers, Telecom Transformers
