Previous in Forum: Just For Fun   Next in Forum: qualifications
78 comments
home made wave height sensor
04/17/2009 9:11 PM
hi all;
i have this long channel where i create waves using a paddle at one end of the channel. now to accurately measure the wave heights (and period) in this channel, i need a submersible pressure transducer which costs heaps. what i have done is put together a design as shown below.
i drilled into a solid steel rod of 1" diameter to build a underwater pressure tap and connected it to the manometer. also i ensured that there is no air trapped in the tube from the underwater tap to the manometer, so that the water runs continuous into the u tube. my problem is that even though the water density is the same, the height of the water column in the manometer is very small compared to the wave height?...the elevation difference should not matter since i am looking at the change in height value to capture the amplitudes of the waves on a camera. any suggestions for improvements ?
Good Answers: 62
Re: home made wave height sensor
04/17/2009 9:58 PM
Way cool piece of equipment you've built!
Just taking a swag here, but I suspect if you want more differential movement at the indicating end, you need to allow more total volume movement. So increase the diameter all the way from the base of the pressure tap through the manometer.
But don't start drilling until one of our specialists comes along and confirm.
A lever would be easier to adjust, as cool as this rig is, how about a wave following float with an indicator at the other end?
04/23/2009 7:48 AM
no boss .. it wil work like that ..increase in dia wil not solve the problem
Good Answers: 16
04/17/2009 10:01 PM
Wow! Who'd a thunk it. I don't know where your research is going, but it looks like fun, Onliest thing I can think of is using a venturi in place of your carefully machined receptor, with seperate inputs above and below the choke point. Mebbe someone in EE&C can advise on better sensors. It is a speciality of boat designers to pay particular attention to waveform mechanics. I hope you have opened up a new way of looking at it.
Best regards, Carl
De gustibus non est dispudandum.
Good Answers: 918
04/17/2009 10:23 PM
Clever, but it will not work. Water has mass and essentially you have a spring attached to a weight. The weight will bob up and down, but it will not be phased to the wavefront you wish to measure due to inertia. Your measurement will affect your experiment.
Additionally, your pressure transducer will not be able to resolve the delta in your waves for the very reason you cited. You have a problem with discrimination.
Ask yourself how might you take advantage of the refractive index of the boundary between air and water?
04/17/2009 11:07 PM
I agree with the AH. That's as in Hero.
Slow, fuzzy, useless response, at best!
I must be really thick. Are you trying to predict the amplitude to trigger the camera?
04/18/2009 5:22 AM
Just look at your picture...
If you want to see the wave height...then just look at it.
A glass/perspex/whatever panel in the side of the tank and an optical sensor.
Alternatively a vertial row of stainless steel pins and sense the conductivity between each pin and a common rod which runs up alongside them all.
Alternatively just have big bore tube hanging down into the water, closed at the top with a pressure sensor mounted in the top, ok the level in tube won't actually follow the level in the tank, so you will need to make calibration adjustments, these can be acheived by using a stick... the wet bit gives the max wave height (This is very much like what you have already done, but aviods the long thin pipe, mass of water etc.
Blimey, this is too easy, A float with a stick attached and an optical sensor, or a felt tipped pen and a roll of moving paper....can we all come play?
Or just simplify what you have done and calibrate it.
04/18/2009 8:25 AM
I work in a hydraulics laboratory and for wave height measurement we would usually use a capacitive wave height sensor, which you could make yourself if you have some electronics knowledge.
Earlier commentors are correct in saying that it is an inertia problem and also the thin diameter of the tubing. Due to the thin tubing, the velocity in the tube will be high and will be subject to friction which will slow down the movement of the water. Try 12mm hose and see how it works. make sure the pressure tapping hole is big enough as well.
Frankston
Frankston
Good Answers: 62
04/18/2009 8:25 AM
I like Del's suggestions
For simple school demos a fish tank cleaner with rare earth magnets and a bigger float over an indicator/scale (red inside attached to float):
or more adjustable for finer measurements, a float with a pivot and lever arrangement:
And since there WILL be lag in either system, how do we quantify it in an analog world?
Or are we off on our own tear and missing the point of what you wanted it to do?
I wanna come play too, obviously!
04/18/2009 12:59 PM
Oooh, Yes, I like your idea too, prrrr prrrr... nice, a horizontal lever attached to a potentiometer with the other end of the lever bent down and a float attached..........arm must be long relative to vertical deflection, but it's all simple geometry.
Good Answers: 918
04/18/2009 4:21 PM
Between the pot's mechanical resistance and the mass of the buoy the resulting data will not be very accurate.
Additionally, pots generally have a rotation of about 300°, so small deflections will be very hard to resolve.
Of course the original poster did not discuss what the requirements are for the measurement. We don't know the range of period, the range of amplitude, nor the degree of accuracy that is required.
The best mechanical solution that incorporates that design concept I can see is as shown below. If the magnet is the pivot point and a small radial diameter is chosen for the magnet, then the amount of radial momentum will be minimized. The system still has mass, so it will be mechanically inductive.
The pivot point also shold be at the neutral position and teh distance between the bobbin float and the pivot point should be close to each other to minimize mass of the wire.
Using a precision instrument amp you can boost the small magnitude of change in the Hall sensor to a range that is sufficient for measurement discrimination.
So, how do we eliminate the mass problem. One way we can virtually eliminate it is by the following method:
The trick here is to size the volume of air in the narrow column and the wide column at the top so that the maximum displacement by the wave will not cause the microphone element to reach maximum or minimum excursion.
The downside with this approach is that the wavefront can not be stationary (i.e., a node or an antinode) since the mic has a lower frequency limit. If the test frequency range is above 5 to 10 Hz, this system will work quite well and is cheap. The mic must be sealed into the column, too.
If the system must function down to DC, then a very sensitive pressure sensor in place of the mic element would be the next choice. In fact it may the best choice, but I just don't have experience with sensors that would be extremely sensitive to very small pressure changes.
04/18/2009 4:44 PM
I disagree, it's a simple matter of designing the geometry to suit the application, one could always add in a gear if necessary and a multiturn pot. The mass of the float would by it's very definition be very similar to that of the water, and thus would be likely to have a similar frequency response to the mass of water supporting it.
Anyhow, whatever...this isn't my field of expertise and I'm quite willing to be wrong...it has happened before...although I could be mistaken.
It was an idea not a full blown design.
I thought we were all throwing ideas in to the ring, I have no wish to argue the point anyway, I'm sure Ram44 will sort the wheat from the chaff.
Del <I shall go and sulk in my secretest cat nest now>
Good Answers: 918
04/18/2009 9:16 PM
I work in electrical systems daily and pots do have a pretty significant rotary resistance. Gearing only exasberates the problem because you are amplifying the torque at the input end. If you think about it you are doing more mechanical work when you take 5° rotation and step it up to 300° rotation. Not only do you do 300° of work, but you add the mechanical friction of the gears and bearings into the system.
04/19/2009 4:11 AM
Yes indeed...
But water has big coefficient of floatiness.
This can support vast heavy loads which have even more inertia than a pot, things called 'ships' rely on this property I believe.
Anyhow I do indeed take your point as there would be backlash too, and to maintain linearity you'd want to use a small angular deflection, which would reduce resolution...and you still need an AtoD, unless you used a rotary encoder in the first place...I can think of a million reasons to not do lots of stuff.
This is why I believe in WAQAPTM (Wrong As Quick As Possible) as a design and development tool.....
Maybe I won't bother going to shoot my longbow today...I'm just too depressed...I've got this terrible pain in the diodes all down my left side.
Good Answers: 62
04/19/2009 7:26 AM
Is that abbreviated CoF?
Good Answers: 918
04/19/2009 7:41 AM
Poor Marvin.
Good Answers: 62
04/19/2009 7:48 AM
Marvin?
04/19/2009 9:38 AM
Marvin...the paranoid android from 'The Hitchhiker's guide to the galaxy' he was always complaining that he was given mundane tasks to perform and yet he had a brain the size of a planet, and a pain all down the diodes in his left side...
Good Answers: 62
04/19/2009 9:51 AM
Ahhh, I'd forgotten - thanks
04/18/2009 5:09 PM
Actually, any system measuring the pressure generated by the rise and fall of the water will effect the rise and fall noticeably due to the damping effect of the trapped air.
An alternative approach may be to have a vertical pipe (say 1" diameter), the lower end being always submerged, a flowmeter of the type used for measuring respiratory function could be placed in the top of the pipe.
Such a flow meter has very little resistance to flow and as such would have very little effect on the waves being measured.
These flowmeters typically have either a rotating element with an optical or magnetic sensor, or are a series of parallel tubes (think bundle of drinking straws about 2-3" long) to laminarise the flow with a differential pressure sensor measuring the pressure drop either side of the tube bundle (this type is known as a Fleisch Pneumotachograph).
There are some relativley cheap instruments of the rotating vane type on the market with computer interfaces, I would think that the frequency respons used in human respiratory function would be eminently suitable for this task. I was for many years employed designing such instruments.
This is becoming a very interesting thread, be sure to let us know how get on with your project.
Good Answers: 62
04/18/2009 5:31 PM
Good to see your sulk ended
Good Answers: 39
04/18/2009 11:34 PM
A blood pressure and pulse meter used by thousands of peopel pretty much fit the criteria for period interval and the variantions of pressure can't be much different .
I would think such an instrument can be cannibalized for the necessary transducer bits and pieces. Even new it only cost around $89.95 at the pharmacy.
Elnav
Good Answers: 123
04/21/2009 2:04 PM
If you are going to push for measuring wave action with pressure readings, I am going to make a statement for chilling the water and exposing the interior wall to a heat lamp. Then it becomes a simple matter of recording the changes in temperature of the wall of the container. No friction involved. No back-lash in the linkage. And no wear concerns.
Bob
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
04/18/2009 11:36 PM
Several rough concepts popped into my head, don't know how valid they could be, so I'll wait for and learn from the responses.
First, I thought of lasers used by police to listen in on suspects' conversations. The police point the laser at a window. The window acts like a microphone diaphragm and presents varying resistance to the laser. Electronics measure the resistance, and convert the pattern back into sound. At least, that's how they explained it on TV show a long time ago.
Because we are dealing with homemade system, a "laser tape measure" might be used instead. If that's not feasible, then a photoelectric system might work, but then I can see problems with resolution.
I also wondered about the relationship between the surface waves and sound waves. If they propagate through the water the same, then an underwater mic feeding into an oscilloscope might work.
My final thought is to use a timer. The float triggers the timer to start at the first crest, and stops at the next crest. Then a little math should get you the wave height.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
04/19/2009 3:58 AM
There are cheap acoustic reflected Doppler devices used to automatically open doors for people walking towards the door. Pointing such a device vertically downwards and reading the analog output should do the trick. The signal will be proportional to velocity, easy to integrate or differentiate. Other cheap acoustic distance meters are available at hobby suppliers. Water reflects near ultrasound well enough.
Constant change is here to stay!
Good Answers: 37
04/20/2009 11:51 AM
dovy is correct; I read down through the list to see if anyone had thought of this. Here's an example: http://www.hobbyengineering.com/H2951.html. Some of these grew from the camera industry, where automatic focus required knowing the distance; they've become so common that costs dropped. Here's one offering software to deal with the outputs, and capable of readings at 5ms intervals: http://www.senix.com/family_ts.htm. There's a nice comparison chart set at http://zuff.info/RangeFindersComp_E.html that is worth some time: it gives price approximations, method of operation, links to web sites, etc.
" Ignorance and arrogance have more in common than their last four letters. "
04/20/2009 12:33 PM
Thanks for kick starting my memory...
There are several practical examples, but I'm referring to projects carried out a long time ago so that I don't remember the Doppler maker's name. The device was actually used to measure sea wave height in a harbour where calibrating a sunken pressure gauge was a requisite.
The distance measuring acoustic device was made by Proxxon in either Germany or Austria. It worked very well but it had no direct electrical analog output signal. When this kind of a device is pointed directly down it will receive the reflected sound wave only from the top of a wave, top being defined by the beam width. A nice exercise in Geometry.
Piezo sound generators and receivers are cheap and can even be used to measure wind speed by comparing peak delays upwind and downwind.
Good Answers: 97
04/19/2009 8:26 AM
Long ago we had to measure the height of waves in a model of a channel in real time.
We ended up with a double sided (gold) pc board as the probe. The one side had a pair of parallel electrodes while the other side the pair was flaring out at the bottom.
We recorded on a multi pen XY plotter or a 6 Chanel ultraviolet galvanometer device.
As far as I remember it was rather accurate and neat.
One problem was that we had to control the PH of the water otherwise the readings would be way out. That was hard because we used a lot of cement in the models.
04/20/2009 9:55 AM
A homebrew twin wire wave recorder shouldn't be too hard to knock up (works on resistance, BTW). I used to (co-)make a version of these many years ago when I was at J&P Engineering. Major customer was the Hydrological Research Establishment at Wallingford.
04/20/2009 11:47 AM
At last
(GA)n
04/20/2009 1:30 PM
There's something very like that, but a bit more home-build, on google images. Can't remember where.
Anyway, how about some madness ; What's wrong with reflecting a laser ? Angle it down at, say, 45o . A shrouded receiver could be angled down at the same angle. The receiver is on a track, and gets moved along the length of the tank until it catches the reflection from trough or crest. Don't ask me about the splarty light that gets reflected at other angles, I dunno. That's why the receiver is shrouded. Maybe you can check the intensity of received light. It worked on a glass of water when I checked it just now - the nice little dot went up and down the kitchen wall. On no account be stupid enough to ask for a diagram of what I mean. I'm off to the opticians, anyway.
04/20/2009 1:36 PM
So it was you!
I've been chasing that dot all afternoon (well between naps)
04/21/2009 5:18 AM
I think it's shameful Del, you went to all that effort to be witty and your excellent poast has been ignored by that selfserving sycophantic sonambulistic squirrel.
I think you deserve a GA at least.
errr... Anon
04/21/2009 5:50 AM
Reading it again and again should be pleasure enough You can have a half GA, for wit.
Sooty doesn't fall for that trick (too lazy), but the dog hasn't figured it out.
04/20/2009 6:50 PM
So the fishermen were innocent. I hope you're ashamed of yourself.
04/21/2009 2:33 AM
Blimey, what a pair of dorks. A bit like the ****** who got nicked last year for shining lasers at pilots. My kitchen sink experiment was conducted under rigorous safety procedures ().
It works fine, though I'd have to set up a proper tank to do more. When the light bounces off a peak or trough, you get a nice dot appear on a 45o surface. When the light hits any other part of the wave, it's smudged into an ellipse. If I glued smartie tubes to the receiving surface, it could be moved (horizontally), at the same hight as the source. As I move the receiver horizontally, I should be able to find 2 sweet spots. Distance + angle → wave hight.......The setup can be 'zeroed'/calibrated on water with no wave. Is there any flaw in this ?
04/21/2009 3:11 AM
Are you talking standing waves?
04/21/2009 3:30 AM
Nope.
The reflected spot of light is not exactly circular, but it will only bounce off at 45o when there is a peak or trough (ie flat surface). Only those light beams will be collected by a cylindrical 'filter' ; Set the thing up with no water waves, and adjust separation of source and collector until the beam is detected. Source and collector are at same height. When you have a steady wave pattern, the receiver must be moved horizontally nearer to the emitter to sense a peak, and further away to sense a trough. Light hitting anywhere other than peak or trough won't bounce of at the same angle to vertical. By moving the receiver to detect the beam, you're measuring water level where the beam hits. The tubular filter would have to be small enough for the precision required. Shall I doodle to clarify ?
04/21/2009 4:05 AM
"Shall I doodle to clarify ?" - no thanks, I get the picture. But is the OP looking at standing wave patterns?
04/21/2009 4:16 AM
But John, I've gone to so much trouble.......
I doubt the OP wants a standing wave if he's think about wave power (he mentioned limpet), but you never know !
It's clever, but I've not yet thought of a use.
04/21/2009 5:36 AM
If you mount the laser & receiver on a beam fixed to vertical and horizontal (fast!) linear actuators, you could couple up a servo system to track a peak (or trough) as it travels along the tank, giving the height & propagation rate .
(There must be an easier way! How about a twin-wire wave recorder?)
04/21/2009 5:53 AM
I reckon the easiest answer would be to slow down that action - use custard !
04/21/2009 2:15 PM
Clever!
Why did you mark yourself OT????
04/21/2009 3:17 PM
Bit like the hex nut thing - it just amuses me to make people look for stuff. If people don't look in the (reply) boxes, they might miss a chance to think outside the box. Something like that. So far, you're the only person who's shown the slightest comprehension of what I mean ! I can see I'm going to have to rig something up to show the rest of 'em. Doh...
04/21/2009 5:39 PM
Your idea is clever because its also simple and probably easy to implement.
I cannot fathom out why nobody else appears to understand JUST how simple....
My only suggestion is to not measure the waves in the same axis as the wave movement, but at 90° to them.
Then you only get two reflections, one at the top and one at the bottom and the sender and receiver can be right next to each other aimed vertically down...tell me if you need a diagram....
04/22/2009 2:37 AM
There would have to be some offset of source/receiver. The original 45o was just to make the thing clearer, though I don't think it helped ! How much you move the receiver depends on the wave/ripple height, but so long as it catches light coming back at the same angle as sent it doesn't matter.Once the waves are coming, the receiver just need to be move along +/- mm/cm to find the reflection again. Light hitting the sloping surface of the water bounces off at couldn't-care-less degrees, it'll never get through the smarty tube. Adding an audible beep isn't needed, but would be fun.
A nice long section of gutter would work for this, but I don't have one handy. Yet !
In reply to #63
04/22/2009 4:07 AM
If the sender and receiver sensors are next to each other, you only need to angle them a tiny amount to allow the Rx to receive the signal when a "flat" part of the wave goes by. This will only be at the top and the bottom of the wave. The rest of the wave will either reflect the laser beam either towards the oncoming waves, or to the retreating wave.....
Having the angle in your diagram means that you need to have the receiver at different distances away, depending upon the height of the waves.....you show several Rx positions in your diagram for that reason:-
My version, you only need on TX and one RX, basically bolted to each other, but its still basically your idea....I have shown 4 of them for clarity, but in fact only a single one (Tx/Rx pair) is needed......
Here is a simplified diagram of your/our idea:- (my waves are crude, but I hope you get the idea!)
Only Tx/Rx 1 and 3 will get a signal return, on the front or back of the wave, the signal will be reflected away from the Rx/Tx pair.....
When viewed from the direction of the blue arrow, it should look something like this:-
The distance between Tx/Rx and the tops of the waves, should be as great a distance as possible, to allow the focus on the bottom of the wave to still be achieved easily (angle to each other).
In reply to #64
04/22/2009 4:23 AM
Unless I'm missing something, your setup with the RX & TX adjacent will tell you that there is an extremum - but not how far it is from the RX/TX (unless you use pulse timing, and at 300mm/ns you need some fancy stuff).
In reply to #65
04/22/2009 6:10 AM
I actually wasn't quite that far along, but you are perfectly correct. I suspect that pulse timing may be easier.....hopefully Kris will tell us exactly how we need to do that part....
In reply to #66
04/22/2009 6:54 AM
Don't know whether Kris wants to go that way - but if he does, I don't think he'll be able to do it with a 555 timer .
In reply to #64
04/22/2009 7:30 AM
I much appreciate the drawing, Andy, but.........
"Here is a simplified diagram"
That's done it - I'm going to finish the remaining Pringles and Smarties. The model shall be built ! Prepare for some hideous Blue-Peter style modelling !! It's only a couple of days to the weekend...........
In reply to #68
04/22/2009 7:57 AM
Can't wait!!
In reply to #69
04/22/2009 8:00 AM
In reply to #69
04/25/2009 8:15 AM
With no expense spared.......
First of all the laser is angled down at about 45o (why ? I just felt like it !)toward a flat surface representing the water (sans waves);
(I tilted the wave so you can see the reflected light better, but it makes the marks on the plank look to be in the wrong place)
Next, the wave has move along, and the smartie tube is shown. Remember that only flat surface will reflect up at 45o ;
Ideally, there would be a horizontal attachment to the smartie tube, to screen out none-45o beams. No problem, those hitting the wave slope go miles away.
As the wave rolls along, I move the smartie tube along to find another 'sweet spot' where light is coming up at a 45o angle. Ignoring the first pic with the demo flat surface, there are only 2 places on the plank where light can reach via the tube. The second being the valley part of the wave;
The pencil marks on the plank are about 5cm apart. The wave is about 3cm (peak to trough). What can I say.....it's only a slight error for such a set-up.
In case anybody wonders about water reflecting the light;
Admittedly, there are a few () problems to this being a practical solution. Moving a bit of green card is not the same as a wave etc etc, but it sort of works.
In reply to #73
04/25/2009 12:04 PM
mmmmmmm smarties.....
In reply to #74
04/25/2009 7:17 PM
Shhh - they'll discover my real motive ! Did you notice how they've changed the tubes into hexagonal profile ? That's even more outrageous than than the shrinking Cadbury Cream Eggs, and don't even get me started on the quality of Midget Gems !
In reply to #73
04/26/2009 2:33 AM
I just realised that we both have the same (cheap) laser system with tripod (or at least mine has with a nice carrying box!)
Great minds........?
In reply to #76
04/26/2009 2:56 AM
Ha ! Yes indeed . Can't recall how much it was, but it was dirt cheap. Too much fun to pass by. The tripod's a heap of junk, and the case isn't a whole lot better, but I can never resist a plaything. I think it was from Woolies, where I also got a funky little silver one (with tripod) for about £3 ! Mrs K gets very nervous if I go to the shops alone !
04/21/2009 6:05 AM
<...kitchen sink experiment...>
What's the next step in process scale-up then? A cast-iron bath?
04/21/2009 1:02 PM
I could weld a long line of tubs together or something.
Nobody believes my genius idea will work If I cut a toilet roll holder* in half, join one bit alongside the other, cover in tin foil, I'll have an imitation wave to test my theory. Smarty-tube shroud and laser can be stuck on the wall. As I move my wave along, I can see how far I have to move the smarty tube in order to catch the reflected light. Tin foil might be a bit too crinkly, so 2 halves of pipe may be needed. It's a bit early in the week for this sort of thing, but I'm getting tempted......I need to know if it's worth the effort. People can say yes by giving me a GA here. 10 votes and I'll think about it. 20 will get you photographic proof.
* At my discretion, I may use a pringle tube to maximize effect. The silvery inside will also save me time.
Good Answers: 37
04/21/2009 2:37 PM
The links in my earlier post (#34) include optical coincidence detectors [reflected light spot] ready-made, from a variety of sources. Already optimized for some purpose, most likely, and so it would be a simple matter of choosing appropriate one(s). The ultrasonic sensors in same post will provide 200 readings per second, and do not depend upon perfect repetition of standing waves, or indeed, upon either repetition or "standing" properties. No backlash, no wearing parts, no contact; effectively continuous readings, and software available to interpret results - and all off-the-shelf at low cost. I can't see anything else except the immersion conductivity probes as even in contention at this point, unless there are circumstances not described.
04/21/2009 2:51 PM
Also: 2 electrodes stuck to the inside of a plastic tube (bottom plugged) and the tube perpendicularly immersed. The electrodes connected so that capacity can be measured.
04/21/2009 3:08 PM
...as I suggested in Post #29? With highly skilled drawing!
04/21/2009 3:18 PM
Right!
Good Answers: 37
04/21/2009 3:10 PM
Dovy - point taken: if this can be built into the wall, as the immersion probes can, then yes, it's still in contention. If it presents even a relatively small obstacle to the waves, I'd drop it a notch in the rankings. Personal opinion, true, but anything that potentially can disturb the system reduces accuracy and confidence in results, to my way of thinking.
Following that line of thought: ideally, initial testing would find information on wave patterns for various input conditions, and then the tests would be repeated with the proposed means of extracting energy installed, and comparisons made. If the amount of mechanical energy obtained is also recorded, even better.
04/21/2009 3:33 PM
At least some of the disagreement among proponents of various methods appears to be caused by the imagined sizes of the system. My personal bias comes from having done that in the wild with a real sea (also from being too lazy to look at all posts and see that capacity HAS been proposed!)
Good Answers: 37
In reply to #59
04/21/2009 3:56 PM
Good observation. The OP (Ram44) merely says that his (?) test trough is "long". Given the cost issues, I'm guessing that this means no more than a few tens of feet (single-digit numbers of meters) rather than a model basin sort of setup like a major university or other large entity might own and operate. Being able to work in a "wild sea" doesn't square with the mention of a paddle to drive the waves. This person needs to find a way to gain access during off-hours at a large wave pool [http://en.wikipedia.org/wiki/Wave_pool] like some amusement parks have!
Good Answers: 109
04/19/2009 2:00 PM
Hi, your idea is great but needs some modification.
If wave is changing its height there is a moving water mass through a tube.
The tube acts as viscous damper. The mass-damper has a time constant τ = m/d
Damping constant to be measured in Force/velocity in N/(m/s) or N.s/m
So the time constant has the dimension <Kg.m/(N.s)> or s as necessary.
1/τ is ωc or cut-off-frequency. At ωc the amplitude response is 0.7 (first order system) and phase is 45°.
Above ωc the amplitude response is linear (approximately) with frequency, so at 10ωc you will have only an amplitude response of 0.07 and near 90° phase.
So shorten your tube and allow for a bigger diameter if shortening is not sufficient.
Bigger diameter is effective as long as there is no vorticity in the tube. Re near ? 40?
If laminar flow in the tube then mass is ~diameter2 and viscous friction = damping ~diameter4.
Remove any restrictor if you have some in connection of tube to U-tube.
RHABE
04/19/2009 5:36 PM
hi all;
thank you so much for your ideas.
i am trying to determine the wave height and period of the waves initially. my idea of setting up the instrument is to test energy losses of waves on inclined planes. my aim is basic, to find a relation between the wave parameters and energy transfered up a inclined duct. You could say that i am testing an inclined Osscilating water column to minimize energy loss by reflection. since in shallow water wave particles have velocity almost parralel to the bulk motion of waves towards the beach, an inclined chamber will cause waves to rush up,compress and push a bulk of air to a bi-directional turbine. i also have a new design in mind which requires calculation of the best incline angle for energy transfer from waves.
I cannot afford expensive transducers or PIV technology, so i started of making a series of intruments that will record the wave parameters. also at a few locations i need the transducer to be well below water. but for other locations i think the ideas you have given are better. I already bought a air pressure sensor which i placed on a pipe end. Then i placed the pipe in the water so that as the water rose up it pushes an air column up to the pressure sensor. this did not work so well with plenty damping in place.
I am still experimenting and i will update as soon as i get results. Thank you so much for your interest.
Cheers!
Ram
Good Answers: 918
04/19/2009 7:06 PM
I would use a simple film camera in a darkened room with a flash to capture the event.
The tank needs to have one side made of plexiglass so you can visually see the water. I would also use food coloring in the water to make observation easier.
You can directly measure the film after you develop it. If you have a digital camera, then print the picture.
You can also rent a high speed sports digital camera that can take pictures at 8 frames a second or find a friend that has one you can borrow.
A high speed film camera would be the cat's meow. You can capture lots of frames and see the propogation if you need that.
04/20/2009 2:35 AM
I'll thank you to leave my meow alone.
04/20/2009 4:39 AM
Hi Ram,
The easiest way to increase the sensitivity of a manometer is to incline it off the vertical.
If the measuring part of your manometer tube is say 10cm long but when in the vertical position you are getting say 1cm travel, then incling the manometer at an angle such that the top of the tube is only 1cm above the bottom you will be able to use the full scale of the manometer for your small (1cm) reading changes.
This should help you capture these small movements more easily on camera.
04/20/2009 6:03 AM
Someone mentioned capacitor, but that was it.
Have you thought about a sturdy metal rod (you already have something I believe), encased in say garden hose (as a dielectric) or similar, longer than the highest wave you want to measure and a similar rod, relatively close, but not touching, that is not encased. This would form a crude capacitor when both are in water. Using silicone as an excellent sealer. The water will be usually a conductor as long as you are not using distilled, of some degree or another. But even with distilled, the idea should work as then the water is a dielectric as well.....
It would need to be calibrated for the water type before usage......salt water conduction better than fresh for example.....
A small version could be built to test the viability of the system first.
Use this in a circuit of a frequency generator/oscillator of some sort to alter the frequency in time with the variations of capacity. Generally speaking, the lower the wave, the lower the capacity and the higher the frequency and vice versa.
The timing circuit could be a relatively simple 2 transistor oscillator or just as simple a NE555 circuit......
To make the circuit even more exact, the rods could be made much longer and set at say 45° to allow a greater frequency range for the same wave heights......
You might even be abble to make a capacitance bridge and then the capacitance will be a function of the value of capacitance measured....
You then need to calibrate frequency against wave height.
Something along those lines will be relatively stable, no mechanical pieces bobbing about and it should not have any latency at all. The drops of water clinging to both posts would not affect the capacitance greatly, as they are tiny in relationship to the mass of water in a wave.....
This simple sketch may help to make the idea somewhat clearer.
The wires connecting the oscillator to the sensor should be as short as possible to stop extra capacitance.
I have never built anything along these lines I hasten to add.......but theoretically, it should work just fine (as all theories do!!!)
Anyway, it should give you a further few ideas to be getting on with......
Let us all know how you get on......
Good Answers: 97
04/20/2009 9:43 AM
Hi Andy Germany
I had someone do it before, we used a bridge to compare out differences caused by other factors. see my post 21.
I think it involved capacitance and not resistance as the surface of the PCB were laminated.
I will visit the lab soon to see if this 1972 "invention" still exist.
04/20/2009 2:53 PM
Good move, thanks.
04/20/2009 6:12 AM
Of all the suggestions so far, the Electrical Capacitance method by Frankston is be far the best. I have used this method for Hydrodynamics labs in the past with complete success. The sensing electrode can be very simple and if the tank is constructed of plastic, need only be a silver foil strip stuck to the tank wall and insulated with sticky tape. this would offer minimal effect to the wave motion. Capacitance Transducers are available giving an analogue output to feed a moving coil indicator or other device. The capacitance measured is that between the electrode and the electrically conducting water.
J.J.
04/21/2009 10:39 PM
Hi Ram44,
Freescale Semiconductor makes a variety of pressure sensors including differential and absolute. I believe they have DP sensors as low as 10 inH2O, with some having outputs of 0 - 5VDC. Feed this to a multimeter that can give max observed voltage, and there you have your answer. I don't know if the response time of the sensor would be satisfactory. Anyway, here is a link to the pressure sensors.
http://www.freescale.com/webapp/sps/site/taxonomy.jsp?nodeId=01126990368710
Oh, and did I mention that you can get free samples of some of the sensors?
Mike
Good Answers: 54
04/22/2009 9:26 AM
Simple graduation marks along the inside wall of the tank should give you your wave height. Alternatively, a plexiglass side with graduations will serve the same purpose without requiring you to bend over the tank.
For period, again, if the wave generator is fairly constant and you don't need high accuracy, a floating steel cylinder restrained in a guide can be used to trigger a timer with an inductive proximity sensor. Just position the sensor at the max height (or min. height - your choice) so that when the float reaches that high, it starts the timer. When it comes back up after making one cycle, the second pulse will stop the timer, and you can calculate your period.
If your wave generator keeps changing height and period, this idea won't work. But if it gives a fairly constant wave in terms of height and period, and you don't need super accurate figures, I think this one will do fine.
regards,
Vulcan
05/10/2009 7:39 PM
thanks to all of you!
i used a simple float inserted on a steel rod. i had marked the steel rod for measurements and just like you suggested i used a 20fps camera to capture the video. I used a software to get pics from the video at a rate less than half the predicted period of the wave. Also took advantage of slow replay of the video. 20fps camera did a good job. i got and plotted the readings to identify a significant wave height and peak period. the plotted wave gave indications of reflection from the walls of the wave tank. it was the most economical solution for me.
Thank you all.
Register to Reply 78 comments
3Doug (1); Andy Germany (9); Anonymous Hero (5); Anonymous Poster (2); bob c (1); dovy (5); edignan (6); elnav (1); Frankston (1); Hendrik (2); Ian (1); Jim Johnson (1); JohnDG (7); Kris (14); lyn (1); Mikerho (1); PWSlack (1); Ram44 (2); RHABE (1); Ron (4); Tippycanoe (1); user-deleted-1105 (10); Vulcan (1)
