Previous in Forum: Digital Amnesia   Next in Forum: Expanding Foam Insulation
58 comments
Mysterious Object
04/27/2009 7:58 AM
About 20 years ago I went on holiday to Spain. Whilst I was there I visited a nearby town with a castle (I think it was Alicante). In the castle they were dismantling some kind of exhibition: I have no idea what the exhibition was. About the only thing left (probably because it was so heavy) was this thing:-
This is my first attempt to draw anything with proper 3D CAD.
There was nothing in any language left to say what it was and no one around to ask. Now that I've tried to draw it it looks just like a medieval pin ball machine but it had never struck me that way until I tried to draw it so I guess I've got some of the relative sizes a bit wrong. It was a very sturdy bench, the "working" surface looked very much like a butcher's bench. At one end hung from springs by bits of chain was a huge piece of stone which must have weighed between 200 and 500 pounds. The stone was a bit like a tomb stone upside down but it was brought to a rough "point" or "edge" from the flat sides as well as the edges. Underneath the stone the bench was very battered and worn away into quite a deep depression.
I can't remember if the stone had some sort of handle which would have enabled someone to "bounce" it up and down.
There may well be parts of the drawing which are wrong, and, are obviously wrong to someone who knows what it is.
I haven't tried to draw the chains from the springs to the piece of stone.
I think the springs were made from flat pieces of metal like old suspension springs (not round as shown).
I can't remember if the vertical pillars supporting the springs were wooden or metal.
I can't remember how the legs were attached to the bench (someone told me it could help date the thing).
The bench may have extended a bit further behind the stone.
Re: Mysterious object (warning I haven't a clue).
04/27/2009 8:06 AM
Another piece from PlbMak's junk collection!
04/27/2009 9:15 AM
Except that he seems to know what all his items are.
04/27/2009 11:00 AM
Er, oh yes.
04/27/2009 8:50 AM
It's obviously a Cat flap trainer...
04/27/2009 9:16 AM
Ouch!
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
04/27/2009 9:01 AM
With Alicante's reputation for granite and sculptures, it could have been anything from a sample display to a demo kitchen. Any idea what sort of exhibition it was.
Or it could be just a fold-away bed - one push on the bottom of the hanging granite and away it goes!
04/27/2009 9:26 AM
From the wear to the "work surface" it had obviously been used quite a lot.
None at all. The thing looked very old but I guess the use of springs would make it a lot more recent (I'm not sure what the earliest date could be).
That's a good point: I guess the way I've drawn it it would be a bit unstable. Maybe the "back legs" were a bit further "back".
04/27/2009 9:22 AM
Maybe it was Art
04/27/2009 9:30 AM
I don't think so. My crummy drawing skills appear to have made it look far more aesthetically pleasing than it was. In any case it had clearly been extensively "used".
04/27/2009 9:55 AM
So the stone could be bounced up and down on the bench top...?
maybe it was used for crushing or cutting something on the bench?
If the stone weighed as much as you suggest, could it have been used for stamping metal parts? or did it look more for food use??
04/27/2009 10:10 AM
Not stamping metal parts (far too crude).
Food seems a much more likely possibility. I've wondered about getting marrow out of bones (although I'm sure there would be simpler ways).
04/30/2009 4:09 AM
And how long have you been having these thoughts......
Good Answers: 16
04/27/2009 10:06 AM
It looks like it could have been used to crush the stems of flax or hemp for textiles. Someone sitting on the bench feeding the material, while another bounced the springs. Prior to rollers or a hammer mill, it would have been a very sweaty job indeed.
De gustibus non est dispudandum.
04/27/2009 10:16 AM
That sounds like a possibility: it's close to the way I'd envisaged it being used, but I hadn't thought of textiles. How woody is flax of hemp?
Good Answers: 16
04/27/2009 10:49 AM
Having some intimate knowledge of hemp in my early years, it's pretty woody. I have a stem that I kept to use as a fish bat! Milkweed is about the softest stem for useable fibers as such.
04/27/2009 11:58 AM
I doubt it, flax stems that were made into linen were soaked in water, the husk or meat of the stem rots away leaving the fibers more manageable. I think the same or similar processes were used for hemp stems to make rope. Binder twine was made from thistles. (Scotland's national flower) I think.
I also am not sure what this could be but an actual picture would be so much more helpful.
~Good Judgement comes from experience... and a lot of that comes from Bad Judgement! ~The Early bird may get the worm.. But the second mouse gets the cheese!
04/27/2009 1:37 PM
Thanks for the information. Sorry no chance of a real picture unless (until?) someone tells me what it is.
Good Answers: 25
04/28/2009 3:41 AM
Hammer mill!
Good one.
Good Answers: 62
Re: Mysterious Object
04/27/2009 11:31 AM
Witch squisher?
Good Answers: 62
04/27/2009 12:02 PM
I'm sorry - tried to resist
No one EXPECTS the Spanish Inquisition!
04/27/2009 12:07 PM
Python power - irresistible.
04/27/2009 12:09 PM
Is that the answer to global warming? New source of green energy...I dread to think where you plug one in.
04/27/2009 1:39 PM
LMHO
Good Answers: 38
04/28/2009 12:06 AM
That was my first ideas, Spain, Crushing stone, Inquisition, Torquemada!
Good Answers: 43
04/28/2009 12:27 AM
and the deluxe version had a sharp scalpel-like knife edge embedded in the lower granite edge- "The pain in Spain falls mainly on the lower edge"
04/28/2009 2:09 AM
Looks a little like a gong as in oriental ceremonies where they would have a bronze bell in lieu of the stone, and presumably the groove was worn by the action of the log being hefted towards the gong. Alternatively it could be a Peruvian skull reducer.
duikerbok
Good Answers: 38
04/28/2009 4:16 AM
Thai, i mean Spanish Massage table
04/28/2009 6:28 AM
Semi automatic shove ha'penny board?
04/28/2009 7:51 AM
Nut cracker!
Coconut cracker?
04/28/2009 7:56 AM
Possibilities. The trouble with all these type of suggestions is that there always seems to be a much simpler way of achieving the goal.
United States - Member - Technical Fields - Education - Hobbies - Hunting - Popular Science - Weaponology -
04/28/2009 9:20 AM
How big was it? Could you stand at it? How long? Did it have bindings of any sort, say to secure something such as a prisoner to be tortured or material to be processed?
David A Goodman
04/28/2009 10:07 AM
It's a long time ago, but, I'd guess that the bench top was between 2½ feet and 4 feet (¾m to 1¼m) off the ground. You could have stood on it easily, but, I don't think any one would except maybe for maintenance.
The very top would have been between six and ten feet (2 to 3 m) high.
I don't remember any bindings.
Good Answers: 125
04/28/2009 12:48 PM
Was there an emblem either mounted or etched into the bottom of the stone. This thing looks like a machine for stamping an emblem into metal or wood objects.
04/29/2009 5:21 AM
No emblem there, and, no may of mounting one that I can remember. The whole thing was a bit courser/cruder than I think you're imagining.
Good Answers: 25
04/28/2009 8:15 AM
I know this is off message, but what CAD program did you use? I'm impressed with your first attempt.
Goodness has nothing to do with it.
04/28/2009 9:49 AM
TurboCad version 15
You can get a very old (version 4) 2D Learning Edition copy free here:-
http://selectfreeware.com/node/269
IMSI who make TurboCad also do a much more comprehensive 2D package for free which I understand has the same user interface as AutoCad (and some of the features of TurboCad). It's called DoubleCAD, and you can get it here:-
http://www.cadcourse.net/index.asp?PageAction=VIEWPROD&ProdID=488
I don't know why it's $1 with a $1 dollar discount (you don't have to give them your credit card details or anything).
Rhinoceros is another 3D CAD package with an incredibly intuitive user interface: if you download the trial version you can save 50 times I think before you have to buy.
http://www.rhino3d.com/cad.htm
I've done a few simple drawings, then just done a screen capture to avoid saving at all. I think I've invested too much time in learning the 2D version of TurboCAD to start with another package now, but, for 3D Rhino might be a better place to start. Something like this was easy:-
Good Answers: 25
04/28/2009 1:18 PM
Thanks for the links. I'll dig into it.
Popular Science - Cosmology - New Member United States - Member - New Member
04/29/2009 1:55 PM
It costs a dollar with a dollar discount because most ecommerce systems will not allow a zero cost item to be posted. Hence I have had to use one cent sales, free but as above with the MSRP discounted by the equal amount, or the item priced at the shipping cost but then allow with free shipping.
04/30/2009 4:06 AM
Aaah thanks Stubby .
Good Answers: 38
04/28/2009 11:10 AM
Ancient meat chopper for hamburgers? I'm hungry already.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
04/28/2009 10:02 PM
It could be a stone dresser's work table. A rough hewn stone would be laid flat on the work surface, trimmed to fit, polished if needed, maybe also have artistic engraving done. Then the stone is hung up at the end for washing away the dust and debris from the stone and the bench. The stone is left hanging to dry.
Or it could be a pedestal for a medieval go-go dancer.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
04/29/2009 5:37 AM
I'm pretty sure the stone was part of the "tool" rather than the object being worked on. Any way I can't imagine a use for such a piece of stone; except of course in this thing whatever it is.
Good Answers: 25
04/29/2009 8:11 AM
Well, if some maiden came to me with her apron full of hickory nuts and asked if I would help her I think that "ye old nut cruncher" would be where we would head. Was the bench long enough to lie down on afterward?
04/29/2009 9:39 AM
Probably.
How similar are hickory nuts to walnuts?
Good Answers: 25
04/29/2009 9:59 AM
A little smaller with a harder shell to crack. They wouldn't leave as much of a stain as walnuts. But I can see this being used for most any tough nut.
04/29/2009 11:00 AM
There is a possibility of it being used by a Blacksmith who made body armor. The point may have allowed him to curve or round the plate steel for helmets, shoulders and so on.
Or perhaps the cobbler for softening up tough old leather for shoes or even bindings for horses / saddles etc.
Perhaps some research down this avenue will get some answers.
Josh
04/29/2009 11:55 AM
Worth looking into: thanks. I'm a bit unsure on dates here: steel only became readily available around the middle of the 19th century: spring steel (used to hold up the stone) was probably later; I'd have thought that traditional (knight type) armour went out of use long before that.
04/29/2009 12:24 PM
OK, well then how about the cook? Bone marrow is full of flavor and very hard to get out, perhaps it was a "Bone Crusher" to assist the cook preparing meals?
04/30/2009 3:47 AM
I thought I'd said that: maybe just to colleagues. It seems like a possibility but I'm sure there would be easier ways.
EDIT:-
see post #11
http://cr4.globalspec.com/comment/384058/Re-Mysterious-object-warning-I-haven-t-a-clue
I guess that means we've both though of the same thing: which may be some kind of pointer.
Good Answers: 204
04/29/2009 1:28 PM
maybe for making wooden pipe? how wide was the stone arch on the bottom? I think if you had a half-log, and 2 men feeding the wood into the stone pendulum, and 2 men with ropes making the pendulum swing, then the stone could cut wood from the middle of a tree trunk. ?? that would explain the wear also on the 'bench', plus the stone having attachments near the tip (for swinging it with ropes)
just an idea.
Chris
04/30/2009 4:02 AM
It's certainly possible that the stone could have been swung in the "along the bench" direction, but, I think that the wear under the stone was too localised for this suggestion.
Good Answers: 123
04/29/2009 1:56 PM
I know what that is. It is an early square. Large stones were put on the table (which was level) the sides of the stone were chipped away with hammers and chisels, until the stone being worked on fit flat against the hanging stone. The result was a 90* angle on the stone.
I have three of them in my old workshop.
Bob
04/30/2009 4:12 AM
No the stone was too convex in all directions from about 1 to 1½ feet from the bottom.
But, then: you were joking weren't you?
04/29/2009 4:55 PM
A day bed. I recall hearing that the Victorians slept sitting up.
Nothing exceeds like excess.
04/30/2009 4:21 AM
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
05/01/2009 5:26 PM
I seem to recall a show that I saw years back and something like this was in it. It was a butchers table with a hanging piece of granite much like the picture you have drawn.
If memory serves I believe the stone was use for putting an edge on the cleaver an the table for the various carving of meats.
If necessity is the mother of invention then is laziness the mother of necessity?
05/05/2009 4:38 AM
This piece of stone was about 3 or 4 feet by maybe 2 feet by about 3 inches. How big was the one in the programme you saw?
Location: united states, california san francisco bay area native
05/04/2009 4:12 AM
i don't know what this object is.. : my guess: some sort of device used in obtaining a confession from some sinner....
give the hardest job to the laziest person & they'll find the easiest way to do it
Register to Reply 58 comments
3Doug (1); ahuha (1); AussieBob (2); beriberi (4); bob c (1); charsley99 (1); chrisg288 (1); DAG (1); DGCYS (1); double_j_b (1); duikerbok (1); edignan (2); Electroman (1); Epke (2); Jaguar (1); JohnDG (2); Kris (1); kudukdweller9 (1); Part time thinker (3); PWSlack (2); Randall (21); Stubby (1); Tippycanoe (2); user-deleted-1105 (3); WJMFIRE (1)
You might be interested in: Flat Springs
