Previous in Forum: loading transformer   Next in Forum: Transformers - Short Circuits and Open Circuits
12 comments
Calculating Cable Diameter
04/29/2009 9:51 PM
what is the diameter of a cable with a marking of 95sq.mm. Kindly extend me cable size table/ conversion
Re: Cable table conversion
04/29/2009 9:54 PM
If 95 sqmm is the area of the cable I am sure you can calculate the diameter.
04/29/2009 11:46 PM
Why don't you use a Veiner caliber to check the diameter of your cable. See ... it so simple.
04/30/2009 1:46 AM
you can use the formula ( Area = .7854×d² )
04/30/2009 3:02 AM
05/01/2009 3:46 AM
JohnDG provided me with my last avatar:-
http://cr4.globalspec.com/comment/302244/Re-CR4-Spellchecker-What-s-Happened
I think I might have to change it. Thanks.
Re: Calculating Cable Diameter
04/30/2009 5:09 PM
Australia - Member - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Electromechanical Engineering - New Member
04/30/2009 11:51 PM
The cable area refers to the conductive area and will depend on the type of cable, number and size of strands, and if the strands are circular, or if it is a compressed style of cable. Best way is to go to the cable manufacturers specifictaions and look it up. Most do have web sites.
tooz
05/01/2009 12:12 AM
Diameter = 11 mm
A=pi(d squared)/4, 95=pi(d squared)/4,d=SQRT of 380/pi or d=SQRT of 120.957
d= 10.998 or 11mm
Gerry
GerryPen
05/01/2009 12:43 AM
Out of the book for one manufacturer:
95mm² Compacted Cu PVC Insulated, 0.6/1kV V90 - nom overall is 15.2mm with nom insulation of 1.6mm thickness
95mm² Compacted Cu SDI as above - nom dia 18.2mm.
Need more details on the cable, 95mm² marking on the cable does not provide enough info on if it is a 4 core and earth, 3 core and earth, SDI (Single Double Insulated). Could even be some of that quad style aluminium solid cable that can be found at odd times.
Trevor.
tooz
05/01/2009 3:40 AM
05/03/2009 2:10 AM
-if this cable is stranded (i.e 7 wire)
overall diam.= 3*wire diam.
-if this cable flexible
overall diam= 1.16*wire diam*√no wires
05/04/2009 11:15 AM
Felix, I assume this is an electrical cable? I the US we use the circular mil sizing system. If this is what you are interested in, this may help. One inch is equal to 1000 mils. So a cable that this 1/4 inch in diameter is 250 mils x 250 mils = 62,500 circular mils which makes is fall between a #3 and a #2 AWG (American Wire Gauge). I think the size you have listed falls between 3/0 and 4/0 AWG. Striker
Register to Reply 12 comments
Anonymous Poster (1); Baloch (1); elabd_110 (1); GerryPen (1); PWSlack (1); Randall (2); Simon Wan (1); tooz (2); wareagle (2)
