Previous in Forum: GSM Home Automation   Next in Forum: Hydrochloric Acid Removes SMD Components from PCB
26 comments
Hard Drive Partition
05/04/2009 8:44 AM
Hi to all
I have a brand new 250 GB hard drive, and Windows XP.
I would like to do three partitions to the hard disk.
Shall I do the partitions before installing Windows XP or after installation.
Thanks for help.
United Kingdom - Member - British
Re: Hard Drive partition
05/04/2009 8:46 AM
I do them before... Don't know why
bondy111
Location: Next to the Prime Merridian (51°29'34.50"N 0°13'32.85"W)
05/05/2009 4:01 AM
Don't know why...but his right!
Making mistake is part of learning.
Good Answers: 73
Re: Hard Drive Partition
05/04/2009 12:42 PM
If you decide to partition after installing software, be sure to DeFrag a couple of times before you do it. It helps to keep the "seek time" down for the read/write head.
05/04/2009 3:51 PM
I'd do it before, that way you avoid any drive letter change issues that can come up.
Charlie don't surf.
05/04/2009 7:07 PM
Well, if Windows XP was installed before doing the partitions , what is the procedures to follow to do three partitions using Windows XP ?
05/05/2009 1:42 AM
You can use OEM partitioning programs, for example the Norton Partition Magic
Aged man is not old man...
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Manufacturing Engineering - Member
Location: Honeydew, South Africa, 26° 04' 50" Lat, 27° 54' 59" Long
05/05/2009 2:54 AM
Jó reggelt kivánok a barátom
Make The Most Of It.
05/05/2009 1:34 AM
Hi Zacky. I could be wrong and I am sure I will be slapped on my fingers for writing it if I am wrong. You do the partitions before you load XP. Your primary drive (C:) cannot be partitioned once you have formatted it and loaded it with XP. Go to Control panel, Admin tools, Computer management, Disk management. If you right click on your primary drive you will find that partition is blanked out, meaning you cannot change it. You can however delete a partition of a secondary (D:) drive and re-partition it with XP. So, (if it is your primary drive) you Fdisk the drive and setup the partitions. Then load XP.
Good Answers: 97
08/27/2009 2:31 PM
Actually during the setup portion of XP install you're given the opportunity to partition the disc(s)
05/05/2009 4:44 AM
You can do it before or after using proprietary software, I like Partition Magic and usually install the OS, then partition immediately afterwards.....
The "before" method needs a running PC that you can attach each drive to and the Partition Software is already installed on.
Do what you want......your choice.
05/05/2009 6:23 AM
I always partition before os installation. I have a stash of W98 bootable floppies loaded with fdisk. I also have a stash of floppy drives and cables for those PCs without an installed floppy drive.
I have not loaded an os in almost a year, but isn't there an option to partition the drive during os installation?
05/05/2009 6:31 AM
I always used NTFS as I believe it is far better that FAT32.
Win98 can only use FAT....
Using XP to partition is possible, but slow.....but 3 partitions are not possible using XP I believe, only 2.
05/05/2009 7:33 AM
I have never partitioned it before and have never had a problem. I have 3 different OS on one drive and always intalled one at a time. I use the Grub boot loader for my OS boot choice.
Steve
Good Answers: 97
05/05/2009 12:52 PM
You can do before or after, before is simpler for some but since changing drive letters is simple in XP why it's simpler is a personal issue
If you do before be alert when installing XP and insure XP assigns the correct drive to boot to.
Go here for info.
05/05/2009 2:39 PM
What i do is when installing XP on a large disk, I create & format a small partition 20G using XP installation. Then i make & format the remainder of the disk. after i know what i will be storing (mp3, avi etc.) i re-partition the large on to my best estimate.
Nothing worse than having 48 movies on 1 part. and 6 on the other!
On the 20G section i use only for the operating system. If you need to re-install it you have very little to lose.
05/06/2009 11:14 PM
You can partition it after with GParted, a free partitioner from Sourceforge.net. If XP has been in use for awhile, you may need to un-fragment. Even then, the files may be scattered. I would do it before if at all possible.
05/06/2009 11:22 PM
I already installed Windows xp on my hard drive .
How I can remove windows Xp and re-format the drive?
Good Answers: 97
05/07/2009 1:34 AM
Go to start / computer / right click the drive to be formatted and select format
05/07/2009 5:24 AM
Just do a format on another PC with the drive connected temporarily....but the logic of "why?" escapes me.......
May I also suggest that you use NTFS format, its supposedly "safer" than any FAT format.....
05/07/2009 1:32 AM
You don't have to remove anything. Set the parameter in the Cmos to boot of the CDrom. Boot with the XP cd. Don't choose repair. Choose new installation. Follow instructions untill you get to the stage where you can delete partition. Then you can delete the partition and re-setup the partitions. XP will also format the drive for you and it will re-install. That should be about the easiest way.
The hard way would be is to Fdisk the hard drive and create partitions by using a boot stiffy with fdisk.exe. In Fdisk you would choose how to setup and delete the partitions. You will then still boot with a XP cd and setup from there. Formatting the drive and install XP.
05/07/2009 9:58 PM
I have a question regarding "computer name" :
When Windows installed into a computer, after installation it gives it a name " computer name".
Is that name based on the processor code number or on Windows key number ?
Good Answers: 97
05/07/2009 10:28 PM
It's generic only, and is your prerogative to personalize it.
05/08/2009 1:44 AM
You can call it anything you want, as long as it isn't too long
bondy111
05/08/2009 8:16 AM
How can i change the computer name ?
05/08/2009 8:30 AM
In XP, click Start, Control Panel, System and then look for the Computer Name tab at the top. Click it. Change the name.
05/08/2009 8:34 AM
Or, if it is the Login name you are talking about, then Start, Control Panel, User Accounts, now edit your account or create a new user account.
Register to Reply 26 comments
Andy Germany (3); Anonymous Poster (1); Bondy111 (2); bwire (4); Conrads (5); DGCYS (1); Isti80 (1); millerwm2002 (1); NotUrOrdinaryJoe (1); Qqberci (1); StandardsGuy (1); stevem (1); zacky (4)
