I am considering making a geodesic dome (20' dia, 5/8 dome) with concrete panels.
The current plans are to make 1" thick panels with 2x4 equivalents cast in around the parimeter. Using monofilimant nylon, no re-bar, and a fair number of 'chemicals' to enhance the properties and make it 'greener'.
There are 30 pentigon panels, and 74 hexagon panels to make the structure. Some of the Hexagon pannels with be removed or cut for a door after the structure passes that point vertically.
The 2x4 will really be a trapezoid shape with a 7 degree slant on both sides, and the top 1.5" wide. Holes will be cast in at appropriate angle to allow 2 bolts along each side to hold the structure together.
1. Is this reasonable? Do I have to many forces that really need more in the panel?
2. What size bolts are minimally needed (Yes, I want to know, then go larger. Suggestions on the bolts to use is appreciated too.)
This is for a 'workshop' or shed, and is not a 'residential structure'. But I do plan on it holding my 'toys'.
