Previous in Forum: 2003 Ford Mondeo - Engine Troubles   Next in Forum: Rear-Mounted Turbocharger
18 comments
United States - Member - Proud to be a part of this Great Nation
Auto Repair Question
05/07/2009 9:59 AM
I have a 1995 Mustang coupe w/ 3.5 litre 6 cylinder, car has 164K miles on it. Have problem w/ steering fluid leaking out of the steering gear boot. What is the most likely problem to check first?
~Research Is Something I Do When I Don't Know What I'm Doing~ Wernher Von Braun
Good Answers: 16
Re: Auto Repair Question
05/07/2009 11:30 AM
The gasket at the bottom of the unit. Fill the fluid resivior, take the retaining nut and washer off the bottom. High idle the engine and crank the steering wheel hard over untill the gasket pops out. (Oil absorbent under.) Replace gasket. 15 minutes and you're done.
De gustibus non est dispudandum.
05/07/2009 11:41 AM
The fluid appears to be coming out of the boot that covers the steering link (sp?)
Good Answers: 16
05/07/2009 12:38 PM
Ahhh! You have exposed my ignorance of Fords, since I have never worked on one. My solution was based on other makes, where the steering (sic) box itself is the culprit. My only suggestion to you now is get a Chevy. Sorry about that.
05/07/2009 12:41 PM
Not good advice since GM is going down the drain, like Chrysler. Hmm, Ford didn't ask for any bailout $......go figure.
Good Answers: 16
05/07/2009 1:10 PM
Aahh. Ya see how dumb I am? Oh well, there will allways (?) be Toyotas.
Good Answers: 97
05/08/2009 1:08 AM
Proofs in the pudding
Location: united states, california san francisco bay area native
05/07/2009 10:43 PM
the boot is just a dust cover.... so.. losen or remove the boot.. then you will find the leaking seal..
give the hardest job to the laziest person & they'll find the easiest way to do it
Good Answers: 101
05/07/2009 1:21 PM
Well, We haven't Solved anything, But the Commentary is delightful.
I drive a Chrysler... (Jeep Wrangler) But have always been a Chevy Truck kind of guy.
Good Answers: 11
05/07/2009 11:54 PM
these are rack and pinion units
the only practical cure is replacement
www.rockauto.com/
05/08/2009 12:18 AM
the body of the unit is its reservoir..then.. cracks or somethin` else i dont need goin on.. yeap.. remove and replace..seams so simple...sometimes the equation reads :... KISS
Good Answers: 97
05/08/2009 1:05 AM
GA
05/08/2009 8:22 AM
The hydraulic seal on that end of the steering rack is worn. The boot will continue to fill with fluid. The only solution is to replace the entire steering rack with a new or reman unit. Then you have to have the front end realigned.
Greg
05/08/2009 8:16 PM
If indeed it is a rack and pinion unit, I rebuilt one on a Nissan about 15 years ago. Did it outside on a piece of plastic. Bought a rebuild kit and was told by the nissan dealer it couldn't be done. "in 17 years, we've never rebuilt one that didn't leak". I did it and it worked fine. As I told my sons when working on automotive products, cleanliness is next to Godliness. Works every time. Son replaced a hydraulic clutch cylinder and it leaked. My first question was did you clean everything. Answer no! He pulled it out, cleaned everything and put it back together. Voila, it works fine, no leaks. Do your self or pay someone to do it, but get it done.
Good Answers: 16
05/08/2009 9:09 PM
Yeah, there is nothing like the satisfying sheen of bare metal. Many industries would be kaput if it were not for a cadre that likes to keep thier hands clean when we put it back together. Clean parts, well organized, invariably leads to sucess.
05/11/2009 10:25 AM
You're absolutely correct about the cleanliness thing! I used to have to go through rebuilding any of the hydraulic stuff on my 1965 MGB as a kid, i.e. slave cylinder, master cylinder, wheel cylinders.............but, I learned early on, cleaning the parts before putting it back together just about always worked ! thanks!
05/08/2009 9:37 PM
You have a rack and pinion type steering system .
As descibed by other comments , you can either rebuild the rack yourself with a kit .
Or , replace the rack with a rebuilt one .
Concidering the age of the car , i would suggest replacing the rack with a rebuild as it would not be too expensive.
If your handy , go for the kit.
What dosent kill you makes you stronger , lifes a trip so sit back and try to enjoy the nice scenery.
Good Answers: 97
05/09/2009 5:23 AM
A new one is the better route
05/13/2009 11:54 AM
After doing some price checking, you're absolutely correct. Here in Kearney, NE (we call it 'Corney'), the cost for a seal re-build kit is $60, then the boot for $20 and for a NEW unit $167. New sounds much better all the way round!
Thanks!
Register to Reply 18 comments
ahuha (2); Anonymous Poster (2); bwire (3); holmesg (1); mach1gtx (3); machine head (1); RVZ717 (1); Tippycanoe (4); Yosemit3 (1)
