Previous in Forum: What If America Had Free University?   Next in Forum: What Reading List Would Enable the Rebuilding of Civilization?
Von Mises and Tresca SCL Results
05/08/2009 7:48 AM
I am M.tech Student from India doing Dissertation work on ASME VIII-2 ED.2007.
I have visited
http://www.pveng.com/documents/content_205.pdf
[ nuts and bolts of stress linearisation ]
and found that Von mises SCL results are lower than Tresca SCL results about 85 to 100%.
why this happens? I have also done FEA and obtain SCL for both the theory of failure .
and found the in the same manner means von mises are 85 to 100% of tresca... as given in the paper or guide in http://www.pveng.com/documents/content_205.pdf
Please give me reason why this is ? because generally Von mises results are always higher than the tresca's resulst...
Paresh B. Gujarati
Good Answers: 51
Re: Von Mises and Tresca SCL Results
05/08/2009 2:43 PM
What you are seeing is normal.
  • Generally using the von Mises criterion overestimates burst pressure and provides an upper bound. (in other words, has lower stress)
  • Generally the Tresca criterion underestimates burst pressure and provides a lower bound. (gives stresses that are higher than reality)
This can be seen by the fundamental definitions of the two criteria:
Tresca:
von Mises:
where σ0 is the yield strength in tension.
Which leads to the yield criterion of failure :
Tresca: (σ13)/σ0 = 1
von Mises: (σ13)/σ0 = 2/[√(3+μ2]
where μ is the Lode stress parameter = (2σ213)/(σ13)
A little knowledge is a dangerous thing.
05/09/2009 12:16 AM
Thank you very much for your kind answer....
Paresh B. Gujarati
Good Answers: 51
05/09/2009 12:32 AM
You are welcome, here is a simple example/derivation:
Which is in agreement with the failure map of the two theories:
05/09/2009 2:45 AM
very good example given...this has make this more clear........thank you once again....
Paresh B. Gujarati
Register to Reply 4 comments
You might be interested in: Nuts, Eye Nuts, Finite Element Analysis Software
