Previous in Forum: Two SATA Drives in the Same Computer   Next in Forum: IDE HDD
11 comments
Good Answers: 101
Hard Drive Backup and Formatting
05/28/2009 11:38 AM
I have an older Yamaha Recording Unit that writes data to an internal 2.5" IDE hard drive. I have filled the drive, and would like to dump the data onto another drive for backup. I recently bought a 2.5" IDE internal drive enclosure, which plugs in via USB. The issue (I think) appears to be in the formatting. When I plug in the drive, windows recognises the drive, make the "Da Ding" sound, installs software, and tells me the mass storage device is ready for use. The drive does not show up in my computer, and I cannot seem to get it to work. I have tried it in a Mac, and a PC with no success. Is anyone familiar with some software that will allow my computer to pull off the data from the HD, and allow me to store it on my computer, and further dump it into a much larger external HD? The recording Unit is the AW4416 by Yamaha, I have no idea how it formats the disk for use, and I'm not absolutely positive this is in fact the problem.
Any suggestions?
Re: Hard Drive Backup and Formatting
05/28/2009 10:48 PM
When I have installed a second drive it required me to flip a few dip switches to make it a 2nd drive. You may need to do that for your system to use it as a 2nd drive.
05/28/2009 11:45 PM
Unfortunately I know nothing of the Yamaha, but I bet you are right that it is a formatting problem. The dip switches mentioned by Guest, or jumper settings, do NOT normally have to be changed for the USB enclosures.
Have you tried the Disk Utility on the Mac (Applications/Utilities/Disk Utility), at least to see if it can tell you what method of formatting is used?
My fear is that the PC may have considered it a blank disk and installed a blank directory on it... To check that, put it back in the Yamaha and see if it still works there! Have you tried contacting Yamaha?
Good Answers: 38
05/28/2009 11:56 PM
Do you have a type number of the drive? try to google the issue, or is it possible to contact Yamaha?
Good Answers: 94
05/29/2009 4:48 AM
Visit the web site of the drive manufacturer, some of them will let you download software to check & format a new drive.
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
05/29/2009 8:04 AM
RVZ,
On the Windows machine you plugged the drive into, you need to look in Disk Management to see if the drive is showing up there. Sometimes, external drives will not show up in Windows Explorer until you go to the Disk Management console and assign it an available drive letter. I've had this happen on USB flash drives. To get to Disk Management (on XP anyway), right click on "My Computer", select "Manage", then under "Storage" you will see "Disk Management". The drive will show up the list as shown below, but it will not have a letter assigned. Right click on the drive information, and select "Change Drive Letter and Paths". You will probably need to be logged in as an Administrator to do this. It is still possible the drive is formatted as something Windows will not recognize. Disk Management will tell you how Windows thinks it's formatted, if at all. If you can find someone with a Linux system, it would be worth it to see if that might recognize it. It would be pretty easy to boot a Linux LiveCD to see you have any luck there. Let us know how it goes.
Tom
05/29/2009 9:31 AM
the above advice is excellent and on track also some thing else to consider is there may be some sort of propitiatory software for the boot sequence designed to work only with the unit it was installed in, again contact the maker and find that out, if so it may only work in the unit it was designed/programed for.
05/29/2009 3:12 PM
The "Recording Unit" could use its own file system to write to the HD. You can try HD imaging software to try make a raw copy.
A quick Google search: http://www.socialentropy.com/aw4416/
Pineapple
Good Answers: 101
05/29/2009 5:04 PM
Thank you all. I'll be working with it over the weekend. I'll update you when i have that moment of eureka!
Good Answers: 97
05/29/2009 7:16 PM
Question is why don't you transfer the files to Solid State Drive vis USB on the yamaha.
Your HD should be a 2.5-inch, 12.7GB IBM Travelstar drive.
The SCSI-2 interface should work with MO drives of 128 MB, 230 MB, 540 MB, 640 MB and 1.3 GB, hard disk drives and CD-RW drives. The CD-RW drive can be used to back up the hard drive, burn final masters in a disc or track-at-once mode, or import/export audio files and play your CDs. You can't directly record or playback audio signals in real time to/from external SCSI drives, which can only be used to store sessions or audio. To record, play or edit sessions, they must be on the main drive.
The AW4416 also includes an input/output and routing matrix with storable settings. Once you establish a favorite way of working, you can use these settings as a starting point for each project. In addition to the 16 tracks of HD, there's space on the drive for a separate stereo master. That means you can mix your project digitally right back to the drive, without the need for an outboard mastering machine. Hate setting up a recording session? The AW4416's Quick Rec button asks a few basic questions and can have you recording on all 16 tracks in seconds. Each of the 16 tracks has eight virtual tracks.
Good Answers: 101
05/29/2009 7:46 PM
The problem with backing up with CD, optical, (possibly tape if I can locate some 8mm 5/10GB tape backups), is Each one of my recording is well over 1GB, in some cases closer to 2GB. I record Live shows from various bands, and generate live albums, I have a method (via another computer interface) to get the separate 16 tracks into the computer which seems to work well (better than the .CFS to .WAV conversion anyway). Yesterday I went and picked up a couple more 40GB 2.5" IDE internal HD's to use which is nice, but I still haven't been able to backup properly, because of the large file sizes, and the temperamental CD burner. I can fill a 20GB drive in one weekend.
My goal is to have a 1TB+ External USB drive that I can have hooked to the dedicated music computer to dump the massive .CFS backup files onto right from the internal hard drive Via the drive dock into the computer. Unfortunately to do this I'll need to either invest in a SCSI/USB external, or figure out how to make the USB docking case work.
I was able to snag a few (nearly antique) small business server backup drives from work. I have 2 8mm tape drives, and a 2.3GB optical drive. Unfortunately they do me no good without the cartridges.
I'm tired and rambling now...... been a long week.
Hope you all have a brilliant weekend!
Good Answers: 97
05/30/2009 2:54 AM
I'd suggest this scenario because of expense and you gain little with a interface to software link in a computer workstation.
Up To 64-gigabyte 2.5" IDE Hard Disk Drives
The AW4416 comes with one 12-gigabyte hard disk drive that should be more than enough for most recording needs. If you need more recording capacity, the AW4416 will accept up to 64-gigabyte 2.5" IDE hard-disk drives. With optional HDD adapters you can have two or more drives ready to be conveniently swapped or moved to a different AW4416, essentially functioning as removable media for maximum data portability. A single song can occupy up to 6.4 gigabytes of hard-disk space, and a single disk can hold up to 30,000 songs.
* To prepare a hard disk drive yourself, use a model
in the compatibility list
I use Adobe Audition and prefer MOTU interface. You should be recording in a loss-less format .wma type for greater compression and scalability.
Register to Reply 11 comments
Anonymous Poster (2); bwire (2); dkwarner (1); Epke (1); Nigh (1); Pineapple (1); RVZ717 (2); tdesmit (1)
