Previous in Forum: Manufacturing Safety E-stop Challenge   Next in Forum: Process Instrumentation Benchmarking
Electroless Nickel Plating Thickness
11/28/2006 3:41 PM
What is the recommended/allowable thickness for Electroless Nickel Plating for corrosion resistance? Can anyone recommend anything other than Mil-Spec (Mil-A-8625) as a supplement? Thanks in advance.
Re: Electroless Nickel Plating Thickness
11/28/2006 11:36 PM
For 8 ~ 11 % phosphorus containing electroless nickel coating 04 ~ 06 micron coating can give you more than 1000 hrs of SST test life and Humidity test life.
Regards
Jitendra
j.singh@nrbbearings.co.in
11/29/2006 3:38 AM
The addition of phosphorus improves corrosion protection and you can have 25 micron thick coatings or more for added protection. For corrosion protection the coating must be 100% continous. The problem is, as with most coating, is always on or in the corners. The sharp features, particularily internal corners, don't get plated to the same consistancy and external corners are vulnerable to damage.
As for spec's. MIL-Spec's, DEF-Stan's etc are not supported, out of date and only good for guidance. Go to a number of processors/platers and get 'best industry practice' advice and write you own specification.
02/08/2007 6:13 AM
Dear Sir,
ZINC FILM COATING is key to plant corrosion & as such that construction steel are been coated with zinc oxide with ease.
Rgds
Sandeep Bhanushali
omegates@yahoo.com
india
Register to Reply 3 comments
