Previous in Forum: Calculate of filler for counterflow packer cooling tower   Next in Forum: mechanics of materials
maintenance factor "m" & minimum design seating stress
05/30/2009 12:55 AM
Good Morning to all
i want to know what will be affect on flange thikness of "m" & "y" value and why?
is there any fixed relation between them?
Good Answers: 51
Re: maintenance factor "m" & minimum design seating stress
05/30/2009 2:39 AM
Good (very early) morning, in my part of the world.
For in-depth details you should look to Appendix 2 in ASME Section VIII Div 1.
But in general, the flange thickness will need to increase with increasing "m" and "y" values. I say "in general", because it depends on 2 conditions: 1. Operating 2. Gasket seating. Whereas the operating condition is usual the larger value of the two (refer Wm1 in App.2 VIII-1) and governs the joint and only depends on "m" and not "y"; however, this detail is most likely a moot point because an increase in either "m" or "y" almost always means an increase in the other.
The reason is due to the moment created across the gasket surface:
(picture just for illustration taken from another source, so the nomenclature does not match VIII-1)
So you can see that when you increase "m" and "y", you require a larger bolt load, which causes a greater moment, and thusly requires a thicker flange to keep the stress levels within allowable.
  • The thickness is more simple with a blind flange, see UG-34:
    • t = d(CP/SE + 1.9WhG/SEd3)1/2
      • where the value of 'W' is directly related to "m" and "y", so you can see that if you increase "m" and "y", you increase W, and consequently 't' must be increased.
  • The thickness of regular flanges is a little more involved so you should refer to App. 2 VIII-1; but the general principle is the same:
    • increase "m" and "y" → require a larger bolt load → create a larger moment → require a thicker flange
A little knowledge is a dangerous thing.
05/31/2009 3:11 PM
My dear XMech you derived a good reply with my "Good Answer".
And I recommend for sandeeppandey0789 to do such a calculations by himself (manually or by using ready made software) using different values for "m" and "y" to see their effect on flange thickness.
Good Answers: 51
05/31/2009 9:01 PM
Thanks Abdel!!
Register to Reply 3 comments
You might be interested in: Seating, Flange Protectors, Flange Mounted Bearings
