Previous in Forum: Pipe Dia Calculation   Next in Forum: Power Plant Condenser
06/22/2009 2:19 AM
Dear friends let me no how to calculate the pipe for water are any services send me any example .
Thanks
Re: Pipe Dia Calculation
06/22/2009 3:05 AM
For a liquid, just keep the average velocity between 1 and 3m/s. That's it.
06/22/2009 3:27 AM
i am asking pipe dia calculation for different fluid's.
06/22/2009 3:31 AM
The answer for liquids has been stated above.
For gases, limit the velocity to 10m/s. If it's below about 3m/s, the pipe is too large.
06/22/2009 4:06 AM
For flammable, non-ionic liquids, keep the velocity below 1m/s so that there is a lower tendency for static electrical charges to build up in the liquid.
06/24/2009 10:25 AM
Re pipe size calculation;
1. volume flow rate is required ie, Q lts/s
2. limiting flow velocity, ie; v/m/s
calculation would be Find area of bore = Q/v = Qx0.001/v = area ( m* )
therefore pipe diameter d = sq root of 4xa/pi = diameter in meters
example. Q is 12.6l/s and velocity is 2.44m/s
Area of bore 12.6 x 0.001/ 2.44 = 5.16 x 0.001m*
Diameter of bore sqr root of 4 x 5.16 x 0.001/3.142 = 0.081m = 81mm
use 80mm nominal bore pipe.
Hope this is helpful
06/25/2009 12:49 AM
hi,
Thanks for your help but we now the volume 12l/m and preasure 3.5kg this situ how to calculate the pipe dia Please help me.
Register to Reply 6 comments
Anonymous Poster (2); GreyeTech (1); PWSlack (3)
