Previous in Forum: Reusing Ammonium Nitrate Process Condensate in Nitric Acid Absorption Column   Next in Forum: Converting Chemistry Units of Measure
16 comments
What are Some Uses for Crude Glycerine?
06/26/2009 2:39 AM
Good Day Everybody
Can I chemically convert glycerine into something that can be used for agricultural purposes? What chemical compound(s) would you get when reacting glycerine with ozone? Crude Glycerin is a byproduct of bio-diesel production.
Barryl
Re: Uses for crude glycerine (by-product of bio-diesel production)
06/26/2009 3:16 AM
Glycerine + ozone → carbon dioxide + water vapour. The reaction is exothermic.
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: Uses for Crude Glycerine (by-product of bio-diesel production)
06/26/2009 8:57 AM
You could always try a nitration reaction....<chuckle, splutter>
Essex jobs for Essex yobs! <Burp>.
06/26/2009 9:41 AM
Stinky Pete,
Will you come and visit me in jail?
Barryl
Good Answers: 15
06/26/2009 11:31 PM
Visit you? Sounds like he might bust you out!
06/27/2009 12:39 AM
Yea and then we both might sit and spend some time!
Barryl
Popular Science - Weaponology - Cardio-7
06/29/2009 9:48 AM
Depends on what nitration Rx you use.... Conc Nitric + conc Sulfuric and you might not be around to go to jail. You might leave with a great impact, tho. At duPont, where we made nitroglycerine, the tech that carried the vials of NG to the analytical labs claimed that if there was no air bubble (void) in the sealed vial, the NG would be relatively impact resistant. As far as I know, he retired from there.
Re: What are Some Uses for Crude Glycerine?
06/26/2009 11:29 PM
we use it as a non-toxic control for fire ants. Just apply to the mound.
Good Answers: 213
06/27/2009 12:00 AM
A couple of years ago, the Seguro Social (Public Medical Services) of Panama bought what they thought was glycerine from a Spanish company that apparently sourced this from a Chinese Chemical Company that sort of disappeared. They made cough syrup from it. Several people died, and others had developed severe health problems, before they got around to determining that what had actually been delivered was diethylene glycol. Since that time, diethylene glycol contamination has been found in a number of consumer products (toothpaste is one that comes to mind). It seems that the same substitution has been made on a number of occasions in other countries, with similar deadly results. I would be very, VERY sure that you are dealing with glycerine and not just something that looks and tastes like glycerine, before using it for ANYTHING.
06/27/2009 8:04 AM
Thank you cwarner,
We are very sure it is glycerine! But we will not attempt to make anything from it to be used by a second or third person. What we would do, just to empty the containers(20l), is to compost it. That way we get the carbon back into the ground. Thank you for the advice/warning. It could also be used for making soap which is going to be too much for own use.
Thank you again.
Barryl
Good Answers: 19
06/27/2009 7:49 AM
First check the pH of your crude glycerin. It is probably highly alkaline from the lye used in biodiesel production. You should neutralize the pH to a more neutral range such as 5 to 8. Acetic acid(vinegar) would work well for this. It can be diluted and sprayed on dirt roads to reduce the dust clouds formed when people drive down them. It can also be sprayed on soil that needs a humectant to help it hold water longer. Archer Daniel is buying up a lot of it to use in animal feed. If you use KOH in the process instead of NaOH, and neutralize with phosphoric acid, it has nutritive value as a fertilizer when applied to soil.
...That's why we call it "Research"!
06/27/2009 8:11 AM
Hi wcfloyd,
Best advice sofar. I am using KOH as catalyst - so will neutralize with phosphoric acid and plough back (literally!)
Thank you.
Barryl
Good Answers: 68
06/27/2009 9:59 PM
Hello Barryleroux,
Try these sites out which indicate Glycerine could be used to make animal feed.
The search site is listed directly below.
http://www.google.com/search?client=safari&rls=en-us&q=What+use+is+Crude+Glycerin&ie=UTF-8&oe=UTF-8p .
[b[PDF] Use of crude glycerol in diets for sows File Format: PDF/Adobe Acrobat - View as HTML had no influence on water use or respiration rate of sows. Results of this study suggest that including up to 9% crude glycerol in diets for lactating sows ... www.extension.umn.edu/.../glycerol_sow_lactation_johnston.pdf - Similar
CaroDiesel - Crude Glycerine Crude Glycerine 80% is applicable in the industry as raw material to be refined further to produce BP/USP grade-refined glycerine. ... www.carodiesel.com/index/Our.../Crude_Glycerine.htm - Cached - Similar
Use of Biodiesel-Derived Crude Glycerol for Producing ... 6 Mar 2009 ... The results show that it is feasible to use crude glycerol for producing fungal biomass that can serve as EPA-fortified food or feed. ... pubs.acs.org/doi/abs/10.1021/jf803922w - Similar by SK Athalye - 2009 - All 2 versions
06/27/2009 10:38 PM
Hi babybear,
Thank you for the info on glycerine websites - will try it out.
Barryl
06/29/2009 8:30 AM
Soap - Homemade Soap http://waltonfeed.com/old/old/soaphome.html
When you add the lie to the oil/fat you get soap. It's just like they use to do back home when they rendered a hog. They took the ashes and ran water through them. That made the lie. The put the lie into the rendered fat and made soap. There are all kinds of products made from glycerine. Most they are mostly soaps, hand creams, makeup, and shampoos.
http://ezinearticles.com/?How-to-Make-Your-Very-Own-Homemade-Glycerine-Soap&id=2496632
Just think makeup is mostly made of dirt and fat ... kind of ironic isn't it?
06/29/2009 2:13 PM
Thank you jrpeck,
Yes it's world full of paradoxes. Maybe that is the real meaning of recycling-I used it, now you use it.
Thank you for the link.
Barryl
05/13/2014 10:10 AM
does anyone have tried to use it as animal feed and how to do it (simple) we making biodiesel and having quite a lot.
on google you find that you could use it as well on your driveway.. any one tries something like that before?
Register to Reply 16 comments
Anonymous Poster (1); babybear (1); Barryleroux (6); Cardio07 (1); cwarner7_11 (1); jrpeck (1); Mitsurati (1); PWSlack (1); Stinky Pete (1); TheGreenHouse Magaliesburg (1); wcfloyd (1)
