What is the fastest and most efficient way to remove condensed water droplets from an enclosed and defined air mass? The air mass will be decompressed to 500 mbs and we would like to remove a majority of the water from the air. Removing all the water will lead to diminishing returns and cost more than the benefit created. The water droplets will not have enough weight for gravity to pull them down, rather the water droplets will be suspended in the air and look like fog. If I could turn the majority of floating water droplets (fog) into a pool in the bottom of the chamber that would be sufficient for my purposes. The constraints are as follows:
I do not want to contaminate the water, so it needs to remain clean.
I would like to remove the water as fast as possible ideally less than 10 seconds and hopefully in just 1 second.
I plan to use the water later so the water needs to be readily accessible.
I assume that the majority of answers will be electrostatics, desiccants, cold temperatures, and highly fibrous materials like fiber glass. I am not an expert on any of these and will consider any supporting data to justify why one technology is better than another. All of these technologies were created to solve a different problem than mine, and therefore will not be perfect for my use. What I am hoping is that one of you UBER smart Guru's will point out something that is simple and elegant.
Thanks for the help.
