Previous in Forum: Armature Brake for Band Saw   Next in Forum: Books
45 comments
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Challenge for The Long Weekend
07/02/2009 2:12 AM
Here's a device I found while cleaning out an old workshop. I knew what is was because I've seen it used many times. It's a very cleaver machine!
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Re: Challenge for the long weekend
07/02/2009 3:10 AM
Someone has been rummaging in PlbMak's carrot shed...
07/02/2009 3:29 AM
...it is an old nut cracker...
Dreams are the blue print for reality.
07/02/2009 3:35 AM
Pipe bender?
07/02/2009 4:19 AM
You told us in your OP, it's a machine for cleaving.
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
07/02/2009 8:27 AM
My first suggestion is a device for doing silkscreen printing.
My second suggestion is .......................
We don't have a long weekend down in this winter part of the world but
Happy 4th July and enjoy your celebration.
Bob
07/02/2009 10:23 AM
Looks like a marble cutting machine as I can see a marble slab below... or it etches the marble... or its just a simple wood cutter. Am not sure its just a random guess...
Re: Challenge for The Long Weekend
07/02/2009 10:47 AM
Glass Cutter?
Good Answers: 266
07/02/2009 12:41 PM
Ornamental iron scrolling tool
07/02/2009 12:52 PM
Have you got the scrolls?
No I always walk like this...
I was doing some wiring with my Daught' on her car...
I asked...
'Have you got the crimps?' and she fell about laughing
Good Answers: 62
07/03/2009 12:51 PM
Genetic - I knew it
United States - Member - Technical Fields - Education - Hobbies - Hunting - Popular Science - Weaponology -
07/06/2009 3:15 PM
indeed!
David A Goodman
07/02/2009 1:57 PM
It's a pizza dough spreader. Does away with having to toss the pie into the air to thin it.
07/03/2009 12:15 AM
Flange Gasket Cutter !
07/03/2009 1:02 AM
"Scribe" for circles of all sorts of sizes.. but mainly just one shape (since it's for circles). Antique bench mounted scribe, etc.
Did I win anything?
JL Mealer
Mealer Companies LLC
http://mealercompanies.com
We have the Italian-designed concept MEALER on wordpress now.
07/06/2009 3:23 PM
Nice concepts! I like the first one. The holes instead of a grill is very unique.
David A Goodman
07/07/2009 11:56 AM
<...Did I win anything?...>
Ask Hendrik for a GOOZ card.
07/03/2009 2:23 AM
It's for gauging or creating flatness/consistent thickness, but, why does the whole base section rotate (look at the position of the blue box in both pictures).
Good Answers: 247
07/03/2009 3:27 AM
This is used in formication.
Formication is the sensation of insects (especially ants) crawling on or under the skin. Formic acid is the acid that causes the stinging sensation in insect bites. This device is used to sweep ants along the newspaper, which causes them to sting the newspaper. The formic acid can then be collected from the newpaper, and later spread on the skin of a victim, often as a prank. The victim will often then scream "Don't touch me you dang sinning formicator!"
07/03/2009 5:28 AM
Looks like it is a device for cutting circles out of glass or ceramic sheets. The top handle rotates the lower arm, the circlular plate below the top handle screws down the cutter arm onto the glass and the lower arm with the glass cutter can be adjusted to give different diameter circles.
There doesn't seem to be any way of attaching a blade onto the lower arm so I'm assuming the cutting tool is set into the underside of this arm.
The newspaper gives something to read while someone brings the tea and more glass.
United Kingdom - Member - Member
07/03/2009 6:09 AM
The newspaper actually says volunteers needed, so perhaps there isn't anyone to bring tea or more glass
Al
If you remain calm while all those around you are losing their heads, then you haven't realised the seriousness of the situation
07/03/2009 7:17 AM
There is a lot about the device that seems unnecessary, the adjusting screws across the front, machines disk and spring? The news paper is that a clue or hiding a clue? in the top picture, top right, there is a lever that suggests some action? the rotating arm is square, why? is something else included? a lot of questions and a bit more thought needed.
Regards JD.
07/08/2009 1:48 AM
And, why is the length of the handle arm adjustable?
Good Answers: 43
07/03/2009 7:46 AM
It looks like the sort of thing you could use in screeding off the plaster in a mould for ceiling roses or that style of thing. But if it it was a kitchen tool and I needed to do some large plaster mould work, it is probably a good device to lump down to the workshop to do the job.
Or maybe its just the first robotic croupier in an early casino!
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
07/03/2009 8:50 AM
I would guess a circular glass cutter, but if so I can't see what purpose the friction pads/brake would serve.
Engineering Fields - Nuclear Engineering - New Member Engineering Fields - Power Engineering - New Member
Location: From going to and fro on the peninsula and walking up and down on it
07/03/2009 8:57 AM
Just some stream of consciousness , the handle on top doesn't seem to offer much mechanical advantage compared to lever underneath. Guesses are wheel rim trueness gauge or beer barrel top groove cleaner .
oderint dum metuant
Good Answers: 25
07/03/2009 11:21 AM
It looks useful, so I'll buy it!
(got a shed full of useful things I've never used.)
jt.
Good Answers: 40
07/03/2009 11:45 AM
Re: "...knew what is was because I've seen it used many times." Yeah, but... with just 2 slight improvements, it serves as a hands-down winner of a goalie for beating all comers at foosball...! Happy 4th ~
07/03/2009 1:35 PM
The newspaper looks like a section of continuous strip that hasn't been cut into pages yet. Does the 'thing' get used for trimming the sides of a roll of <something> coming off a printing press ? The wheel that's centred does the cutting, and the angled wheel on the handle separates the cut strip. It can't cut that bit of newspaper horizontally, but maybe the paper is just a hint. Maybe it's the kind of thing they use for making copies of Harry Potter - a continuous stream of page n & page (n+1) come of the press and needs cutting in two. Somebody with scissors finishes cutting the strips into individual pages. I dunno, they must do it somehow.
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
07/03/2009 3:27 PM
You might be onto something, skwirl. I think it's a device to checking to see if newspaper columns and comic strip panels are lined up straight.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
07/03/2009 7:47 PM
With respect, dat souns like Bolix.
Credits:
  • Greene King,
  • Whoever-made-the-cheap-n-nasty-pseudoScotch-wot-I-got-from-the-corner-shop.
07/04/2009 2:06 AM
ROFL !!
Good Answers: 43
07/04/2009 2:47 AM
and then Bricktop will ask "tabloid" or "broadsheet" ?
Good Answers: 38
07/03/2009 10:51 PM
Naughty schoolboy spanker?
Good Answers: 25
07/04/2009 7:33 AM
I guess - glass cutter for circles and curves.
jt.
Sometimes I can conquer the world, then I regain consciousness.
07/04/2009 10:16 AM
"It's a very cleaver machine!"
You gave it away, it's a cleaver, bit which one?
Obviously it holds down the newspaper so the wind doesn't blow it away when the garage door is open, duh! The crank gives you more spring tension.
Good Answers: 68
07/04/2009 7:32 PM
Hello Bricky,
how are you?
Is it a thing to ream short lengths of metal or plastic pipe up to about 4" (100 mm)?
Good Answers: 12
07/06/2009 1:55 AM
It looks like a paster. May be some sort of gum or glue paster on to papers to join or increase tickness by adding layers!
Subramanyam
Good Answers: 68
07/06/2009 5:14 AM
Hello Bricky,
Looks like a jointing, or joint jig to me?
07/06/2009 8:33 AM
It is a circle cutter for glass I have two of them.They are obsolete now everthing went CNC.
07/06/2009 9:33 AM
That's what I would have guessed as I have a couple circle glass cutters that have a suction cup in the middle to hold it to the piece of glass you are cutting.
~Good Judgement comes from experience... and a lot of that comes from Bad Judgement! ~The Early bird may get the worm.. But the second mouse gets the cheese!
07/07/2009 5:38 AM
So why does the bed rotate as well as the cutting arm?
07/07/2009 6:02 AM
Bricktop's dun a runner - hasn't posted anything since starting the thread.
I suspect he just turned the whole thing round to get a shot from another angle - but he's not here to confirm or deny.
07/07/2009 6:49 AM
Long week end?
Regards JD.
Good Answers: 43
07/07/2009 6:50 AM
How about a windscreen wiper for a Sherman tank??
Bricktop where are you?
Good Answers: 73
11/17/2009 6:07 AM
Sorry, I got a chance to go to Europe earlier than planned, so I left a few loose ends.
It is an elliptical glass cutter, used for stained glass. It's not quite obsolete, it still works just fine, and perfect for the home glass workshop. I have some examples at home, and will post later.
Register to Reply 45 comments
3Doug (1); Anonymous Poster (2); artisteroi (1); AussieBob (4); babybear (2); Blink (1); Bolton_Alan (1); Bricktop (1); Chankley (1); DAG (2); edignan (1); Epke (1); Glassman (1); jdretired (2); JLMEALER (1); JohnDG (3); jt (2); Kris (2); kvsubramanyam (1); lyn (1); ndt-tom (1); ozzb (1); packrat561 (1); Part time thinker (1); PWSlack (2); Quobaldt (1); Randall (3); StandardsGuy (1); tom (1); user-deleted-1105 (2)
