Previous in Forum: mechanical   Next in Forum: Stepper motor or ecentric bored sprocket
Cold Storage Insulation Panel
07/02/2009 11:20 AM
We plan to build a cold storage 8 meters high. Should we use insulation panels with cam locks or panels with tongue and grooves. The cold room will have a -25 deg C temperature.
Hobbies - CNC - New Member Canada - Member - Finaly got around to it.
Good Answers: 12
Re: Cold Storage Insulation Panel
07/04/2009 1:26 PM
I use cam locks all the time. The thicker the insulation, the better. Caulking the joints is very important as well as sealing all conduits that enter the freezer, other wise you will have moisture drawn into the electrical systems. Have you made provisions for isolating the floor?
07/06/2009 9:51 AM
Thanks Icarus, we install insulation and vapor barriers at the floor made of polyethylene sheet and install ventilator pipes.
Register to Reply 2 comments
