Previous in Forum: Gear Pump Designs   Next in Forum: Oil Tank Size
Tips Speeds and Centrifugal Compressors, Blowers and Fans
07/06/2009 7:03 AM
Any one can tell me what is the importance of Tip speed for the selection of subject items !! (Diff. vendors have diff. Tip speed respect to Operating speed, Impeller diameter) Tip speed - Centrifugal Compressor/Blower/Fans.
Is it an important factor to be considered while selecting Centrifugal Compressor/Blower/Fans.
What is the max. Tip speed limit allowed for Centrifugal blower/Fans.
With regards,
Nilesh.
Engineering Fields - Electromechanical Engineering - Graduate Mechatronic engineer Engineering Fields - Control Engineering - Enthusiast
Re: Tip speed - Centrifugal Compressor/Blower/Fans.
07/06/2009 7:46 AM
Hello Nilesh,
It is my understanding that 'tip speed' refers to the linear velocity of the impeller blade tips (as in the edge radial extremity of each blade). The speed of the impeller tip is proportional to the flow-rate at which your impeller will begin to cavitate. Cavitation will result in excessive wear on the blades. Basically, the higher maximum tip speed that a manufacturer may quote in a spec-sheet, the higher RPM you'll be able to safely operate your impeller (i.e. higher flow rate).
Hope that helps
TinTin
Reply Score 1 for Off Topic
India - Member - New Member
07/08/2009 3:39 AM
How it is related to Flow rate ??
Tip speed is direcly proportional to Diameter and Speed. Where flow comes in pictrure.
Could you please elaborate your view.
I agree with the suggestion of Mr. Steve and Mr. The Prof.
07/08/2009 10:00 AM
Hi Nilesh,
It does seem like my post was off-topic. After re-reading your initial question, I realised that you're obviously intending to move a volume of gas, not liquid - so disregard my tangential about cavitation. As I, (and even yourself!) alluded to; flow rate is propotional to tip speed : V(tip speed) = θ(blade RPM) x R (radial distance). Higher RPM gives you a higher volumetric flow rate, as does increasing the diameter (though you'll need more torque). When you're pumping gases as opposed to liquids, the tip speed becomes significant for different reasons -one of them, as 'The Prof' pointed out is that you dont want your blades to fail under their own centrifugal forces (due to the higher RPM's involved).
In summary; listen to the Prof - he knows what he's talking about
Regards,
TinTin
Good Answers: 58
Re: Tips Speeds and Centrifugal Compressors, Blowers and Fans
07/07/2009 5:04 AM
You need to be concerned about the centrifugal forces at these tip speeds and the limits of the materials of construction of the impeller. Maximum allowable Tip speed will therefore depend on the temperature of the gas, the corrosivity of the gas, the yield of the impeller material etc.
Also one of the important characteristic numbers for a centrifugal compressor is the Mach number. This is given by M = u2/(kZRT)^0.5
Where u 2 is impeller tip speed, k = isentropic exponent , Z=compressibility factor, R = gas constant, T = temperature
For industrial gases this may vary between 0,2 and 1,2 approximately.
Nilesh (1); The Prof (1); TinTin (2)
