Previous in Forum: Flange Manufacturing   Next in Forum: electrode for fuel pipe
Circumferential Distance Between Bolts
07/06/2009 10:03 AM
What is importance of circumferential distance between bolts ?
If thickness of flange is safe for given temperature & pressure.
Bolting area is also safe but circumferential distance between bolts is more
than required as per Tema Metric Bolting Data Table D-5M
In such case, flange will remain leakproof ?
Good Answers: 51
Re: Circumferential Distance Between Bolts
07/06/2009 12:47 PM
The circ. distance between bolts is important for 2 reasons:
  1. Minimum - you can not practically tighten/loosen/work on the bolts/nuts. You can't physically work a wrench/hyraulic tensioner/socket ......
  2. Maximum - the flange between the bolts bends and you loose gasket seating and have a leak.
If designed per ASME VIII-1 Appendix 2, you will be fine with particular note from Taylor Forge Modern Flange Design Bull 502 (which the ASME appendix is based on).
"If bolt spacing exceeds 2a+t, multiply mo and mg by: ([bolt spacing]/(2a+t))1/2"
Note that TEMA Table D-5M is for the minimum spacing, that is, you should have a greater distance as per 1. above.
A little knowledge is a dangerous thing.
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
07/06/2009 1:30 PM
"In such case, flange will remain leakproof ?"
Hmmm...
Adequate flange design is only one small waypoint on the path to leak-free integrity. I believe that you have a long way to go. Good luck in your journey!
Best regards, HeviiGuy
07/07/2009 4:50 PM
Per TEMA standard, there is a max. recommended bolt spacing Bmax = 2 d B + 6 t / (m + 0.5), and there is a min. bolt spacing depends on the bolt size (see the following part of Table D-5 of TEMA).
Min. bolt spacing, B for bolt size 3/4"
1.75Inch
Min. bolt spacing, B for bolt size 7/8"
2.0625Inch
Min. bolt spacing, B for bolt size 1"
2.25Inch
Min. bolt spacing, B for bolt size 1-1/8"
2.5Inch
And the flange will remain leakproof if you kept your bolt spacing between the min. and max. values as stated by the TEMA code.
Good Answers: 27
07/07/2009 5:11 PM
" And the flange will remain leakproof if you kept your bolt spacing between the min. and max. values as stated by the TEMA code. "
What about:
  • bolt specs??
  • gasket specs??
  • assembly procedures??
  • QA control??
Just because a flange has been designed properly does not ensure leak-free integrity of the joint!
07/07/2009 6:14 PM
You are right BoltIntegrity.
And I'd like to add that while we proceed a design calculations for a flange, as per ASME code in conjunction with TEMA, these calculations -at the same time- have to cover the design of stud bolts, nuts and gaskets. And all flange dimensions and thickness will be affected by (in addition to design pressure and design temperature) size (width and thickness), type and material of gasket. Also the number and size of stud bolts will be depends on the type of bolt material and its allowable tensile strength at design temp. and so on.
And the ASME code states that the flange thickness and its dimensions with bolts and gaskets have to be calculated at two scenarios called gasket condition and design condition and you will select the results with the greater dimensions to withstand the worst condition. (The design calculation will be printed out through 10 pages at least per flange to cover the design of all prescribed items).
Abdel Halim Galala (2); BoltIntegrity (2); XMech (1)
You might be interested in: Bolts, Flange Protectors, Distance Meters
