Previous in Forum: Three-Phase Mitsubishi Servo Drive   Next in Forum: USB to Serial Converters
9 comments
Good Answers: 247
AAXA Pico Projector
07/08/2009 4:21 PM
Recently, I tried out a pico projector (aka pocket projector), which I used to give a talk to about 25 people in a restaurant setting, with ordinary, not-too-dark not-too-bright restaurant lighting -- i.e., we did not dim the lights for the presentation. I knew the resolution limitations of the projector, so made the text large, etc to keep everything readable. I used a 20" x 30" sheet of white foam core as a screen, and aimed this tiny projector at it, and amazingly, it worked fine -- 12 lumens is enough to provide a surprisingly good image under subdued lighting. In a pretty dark room, these pico projectors can project a 60" diagonal image.
The projector I tried out for the presentation had no memory (whereas the AAXA does), so any video to be displayed had to come in through a composite video port. For my presentation, this meant carrying a laptop, plus a scan converter (from VGA to composite), and the projector -- still a light load, but a pocket projector would be much cooler with some memory, so that it can play a presentation (or a video, or slides, etc.) directly from the projector, without the need for any other hardware.
That experience lead me to buy a similar projector from AAXA, who gave me a discount, because I told them I would report on my experience for you people. The AAXA has 1 GB internal memory as supports micro sd cards for additional memory. It has built-in players for mpg (and other) videos, jpeg, bmp, mp3, etc. and has a built-in speaker -- so you can play most common media types directly from memory, while running on the internal battery.
If you haven't seen these things, they are surprisingly small -- about the size of a large cell phone:
The AAXA uses LCoS technology (rather than, for example, DLP) which is, in itself, is pretty interesting. The light is an LED and as a result never needs to be replaced (30,000 hour life). This is quite a departure from the average projector bulb which last about 2000 hours and costs hundreds of dollars to replace. Of course the average projector bulb is many times brighter.
Overall, a pretty cool little device that could be used to give an on-the-spot presentation to a potential client, potential investor, etc. (You could be on a plane and project a 12-15" image on the back of the seat in front of you.) The picture quality and brightness is not sufficient to gave a polished presentation for a large gathering, but there are all sorts of other uses that could make this a valuable thing to have. (Real estate agents could load images of all their properties, and could run through those anywhere there is a wall.) Obviously, my kids would live to have one, because it would allow them to share their cell phone pics and videos at large size, on any wall.
Using the device is simple and very straightforward. It is treated as another drive on your computer when you connect through USB. Just copy the files you want to show or hear. It does not have a built-in PPT player, so PowerPoint slides first have to be saved as jpg.
The price, $239, is very attractive.
As you'd guess, there are three real issues: brightness, optics, and resolution. Below, I'll address each. Also if you been considering using one of these, and have other questions, please ask.
Pathfinder Tags: AAXA pico projector
Good Answers: 247
Re: My AAXA pico projector
07/08/2009 4:32 PM
Brightness
12 Lumens is not a lot of light, but surprisingly, it is enough for many purposes. I just projected a 6' wide image (over 84" diagonally) on a pair of white closet doors, in a room well-enough lit that I can work at the computer, or could read (although I'd want more light to read for long). The image was washed out but viewable. In a dark room, even at this size, the image would be adequately bright. (The spec is 50" max diagonal.)
At 24" diagonal, the image would be bright enough for typical office light, as long as there is not direct sunlight coming in a window.
So brightness is not a deal-stopper, unless you are planning to show 50" diagonal images in a well-lit office. Chances are that in a well-lit office you'll have access to a larger projector, and you'll have your laptop, cables etc. It's not a replacement for a large projector, and will be used in different settings.
Good Answers: 247
07/08/2009 4:45 PM
Optics:
The optics (i.e., the lens system and alignment of same with the image generator) are OK, but not great. This is an area which could be improved with more precise quality control, I'd think. On my projector, if I focused the left side of the image (using a resolution chart of alternating black and white lines) I'd have to move the projector back about a foot (from about 3' feet to about 4') to put the right side in good focus. In playing a video this might not be noticeable, and you would put the center in best focus, so the sides would be slightly out (in one way on one side and the other way on the other).
The optics could be fixed, I think with little to no additional production cost -- it's just a matter of keeping tolerances tighter, which could be as easy as riding herd on a supplier, for example.
But again, not a deal stopper, and not a major problem, given the unit's resolution and likely usage pattern. If you are a serious photographer, using this to show sample to potential clients, you will be disappointed. But again, that's probably not the market.
Edge to edge brightness is OK, but again not great. The corners are dimmer than the center.
Good Answers: 247
Re: AAXA Pico Projector
07/08/2009 5:43 PM
Resolution
This one could be a deal stopper, but again not for my purposes, and probably not for the purposes of a lot of users.
I used a 640 x 480 BMP file, created in paintbrush with black lines one pixel wide separated by white lines, also one pixel wide. On my computer screen, this image uses up the appropriate part of the total the screen size (I think I have my screen set to 1024 x 768) and is crystal clear.
The resolution image is above. What it looks like, to you, will depend upon many things, but it may look like grey crosses, rather than crosses made of individual lines. When projected as a BMP, the AAXA software eliminates the center and lower right crosses entirely: those areas are pure white. The upper left and lower left cross are rendered as black horizontal lines. So only the upper right cross shows up as a cross, and it is solid black, not grey and completely without any hint that it is made up of lines. If you are familiar with pixel decimation to reduce image sizes, you can see that some pixels have been decimated in the software, in changing the 640 x 480 image size to 320 x 240.
Projecting the same image in jpg form looks better, and probably looks something like the image above, depending upon what your computer does with it. (I couldn't get the image above to stretch to 640 horizontally on my computer in the CR4 editor, but it shows up as 480 vertically.) The individual black lines are not all visible, with there apparently being about four smudgy grayish lines (h and v) per cross instead of the actual 8. The lines appear uneven in width (like a bar code).
I blew up the resolution chart, so that it had, effectively, 320 x 240 resolution. At this size, (with the lines now being 2 pixels thick at 640 x 480) the projected image is clearly recognizable as crosses made from 8 lines. The horizontal lines exhibit an annoying degree of "crawl" of the type that shows up on composite video under such tests.
So... in the BMP case, the software seems not to work correctly -- where there is something, it shows up as absolutely nothing. In the JPG case, the effective resolution is perhaps 320 x 240. In the BMP blown up to 320 x 240 resolution, things look OK, although the crawling would be annoying -- but that shows up noticeably only on test images.
If you look closely at the test image that projects OK at 320 x 240 resolution, you can clearly see the actual image generator pixels, and 2 are used for each line. So there seems to be the potential for 640 x 480 resolution. But nothing I have seen looks anywhere as crisp as a 640 x 480 image does on an ordinary computer monitor set to 640 x 480 resolution.
Consider, however, that back when I was shooting a lot of video (decades ago) broadcast standard was 330 lines wide, and beta, vhs, and 3/4" umatic were more like 250 lines wide. So this projector is about like ordinary TV, and most of these projectors operate in composite (also like ordinary TV) so the AAXA is like the others, I suspect (it is definitely similar to the Optoma I tried out). 3M makes one that advertises much higher resolutions, but I believe that these are input resolutions, not verifiable display resolutions.
07/09/2009 3:22 PM
I saw something similar at San Francisco Mac World last January. I was very impressed!
I have to admit, it was so impressive I assumed it had to be very expensive, and didn't even ask for a price. You've moved me to check it out further! Thanks!
Good Answers: 247
07/08/2009 6:07 PM
Summary:
Definitely a cool device.
It's been sitting here on my desk in adequate office lighting projecting a resolution image (the 320 x 240 one) for about half an hour, running on batteries -- so battery life is adequate for most uses, I'd think. The image is about 40" diagonal, and looks pretty good -- not exactly bright and crisp but usable. The optics are such that the bottom of one cross (there are only two on screen at this size) is clear, but the top is almost turning into grey, rather than showing distinct lines).
For a quick pitch to a client, or pitching some concept to a C Level guy who is basically on your side but only has a couple minutes to spare, selling a house, etc... this would work well. If you want to dazzle a potentially hostile crowd (like pitching to a VC firm) in a setting where you could use an full-sized projector, this is not the way to go. In a medical setting for projecting TV on the ceiling for someone who cannot lean forward to see a wall tv, this could be just the ticket. View a spreadsheet? Not a chance.
07/08/2009 6:17 PM
So let me get this right...you like the device?
Just teasing it does sound cool...
Great way to get seats in a crowded resteraunt just start doing a presentation on making longbows and watch the seats empty.
CAn't say I need one or could afford one, but I'd love to have a play with one...and open it up ...whoops...where does this bit go?
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
07/11/2009 4:59 AM
"whoops...where does this bit go?"
<LOL> I remember many years ago, we had a car mechanic fix my father's car, and after putting everything back, had 1 "extra" nut left in his hand. he just shrugged and said, it's always like that.
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
07/11/2009 6:17 AM
..Yeah, it's called a 'pocket' screw, nut etc, 'cos you just put it in your pocket.
07/09/2009 9:49 AM
Thanks for the disclaimer that you're doing the review as a result of a discount provided by the manufacturer. Not every reveiwer does that these days. I appreciate the honesty.
Register to Reply 9 comments
Blink (4); dkwarner (1); langyaw (1); Old Submarine Sailor (1); user-deleted-1105 (2)
