Previous in Forum: Calculating the Design Life Cycle of Pressure Vessels   Next in Forum: welding procedure
11 comments
patent/ company search
07/11/2009 11:46 PM
Does anyone know how to find out a company that uses a certain patent to make wire?
Good Answers: 1693
Re: patent/ company search
07/12/2009 5:43 AM
Assuming you know the patent #, you could Google it and see if any wire pullers come up as a result. If the patent gives a company a competitive advantage in the market, chances are they will talk about it somewhere in their literature.
You could also select likely candidates and ask if they use this patented process, whatever it is.
Good Answers: 27
07/12/2009 11:14 PM
As the other responder indicated, if you know the patent number the best place to start is the uspto or even freepatents. The patent abstract will show the patent holder and to whom the patent was assigned (if an assignment was made). If the patent was assigned, it would usually be to a company. That company may or may not have licensed other companies to use the technology covered by the patent.
Good Answers: 243
07/12/2009 11:20 PM
If it is steel wire please contact me offline by hitting my name/link above and i will try to assist. dependiing on what it is, I may know the former company.
milo
07/12/2009 11:47 PM
Contact the patent holder. They would benefit whether they use it or if it is licensed, usually with a royalty, so they would gladly give you the information.
Good Answers: 68
07/13/2009 1:51 AM
Hello Indydog,
If you know the Patent number you can enter a search and the company will probably com up. It will also help if you know the origin and Country of the Patent, or whether it was patented on-line?
If you have tried all that, you can search for "Patent Lawyers", I think they are called. They have inside knowledge of the system and that may speed things up a little.
Good luck...............And do not forget, if the patent is still current, you will have to pay for either a Licence or a percentage of the item you want to make to the Inventor.
07/13/2009 8:24 AM
Google this and you will find good number of patents I will send you one is WIRE DRAWING United States Patent 3670588
Masyood
07/13/2009 8:36 AM
In many cases, the USPTO would have as part of their public records the name of the entity that the patent is licensed to. Also the patent has the name of the inventor or inventors. Why not contact them. They would know who the patent is licensed to at least at inception.
Everything I know about opera I learned from Bugs Bunny
07/13/2009 9:15 AM
I-dog, there are several choices to search in the U.S. patent literature, depending upon the data you have.
If you have a particular company and you want to see its patent portfolio, you can do an assignee search in any of Googlepatents, freepatentsonline.com, or the USPTO site. I suggest just going to the USPTO search page at http://patft.uspto.gov/. Click the Advanced Search link in the Issued Patents box. If the company's name is Wireco Inc., enter an/wireco into the Query box and search it. That will give you all patents assigned to any companies with "Wireco" in their names. If you get too many hits, narrow it - say by entering an/"wireco Inc". Or narrow it with a keyword - enter an/wireco AND spec/wire. There are many other search fields as shown on the page, and you can also search published applications the same way.
If you have a patent number, and you want to see if a certain company owns it or has licensed it, you can search the Assignment records at http://assignments.uspto.gov/assignments/q?db=pat. Enter in the patent number and hit Search. You will get the Abstact of Title to the patent - who owns it, any licensees of the patent, whether it has been used as collateral in a loan, whether it has any liens on it, everything. Just like a house - it's a piece of property.
Other than that, just do your typical Google searches with keywords, including just the patent number if you have it. Hope this helps.
Chow
jhammond
__________________________
www.patent-innovations.com
My aspect ratio is 2.28.
07/13/2009 12:08 PM
I was not aware of the assignment search utility. I played around with it and wow, what a powerful tool!
GA for sure!
Good Answers: 68
07/13/2009 6:54 PM
Hello jhammond,
GA to you Sir for your clear explanation.
07/13/2009 9:48 AM
I hold a few...what kind of wire?
"I had not anticipated that the work would present any great difficulites" SHACKLETON
Register to Reply 11 comments
babybear (2); Bluestone (1); DaveB (2); jhammond (1); lyn (1); Masyood (1); Milo (1); NiCrMoNoMore (1); rcapper (1)
