Previous in Forum: Solar Panel Interference   Next in Forum: to skeptics on man made climate change
Cagefan Windrive Electric
07/21/2009 1:05 PM
when the vehicles move at maximum velocity, air flows/pressure againts the body is greater, if I install a CAGEFAN againts the air flow, that will drive an alternator-responsible for the charging of the battery, HOW IT WILL AFFECTS THE VEHICLE EFFECIENCY as aerodynamic resistance. CAN WE APPLY THIS IDEA FOR THE HYBRID ELECTRIC VEHICLES?
This discussion was "closed" on 07/22/2009 10:51 AM. No new comments are allowed.
Re: cagefan windrive electric
07/21/2009 1:26 PM
Not a useful idea:
The energy required to overcome the additional drag/aerfodynamic resistance will be more than what you will get back from the fan-generator.
Re: Cagefan Windrive Electric
07/21/2009 8:58 PM
It will reduce it.
This has been covered in great depth in previous CR4 threads including the following
http://cr4.globalspec.com/thread/35021#newcomments
07/22/2009 4:53 AM
At least two correct answers........do you need more?
Remember, in this world there is no free lunch - EVER!!!
07/22/2009 6:55 AM
Conventional wisdom: the energy required to overcome the additional drag/resistance will be more than what you will get back in energy produced, blah, blah, no free lunch, blah, blah...could it be that no one has yet designed the proper wind turbine devise that could actually produce more energy than any resistance produced. Buying into the assumptions of the day you are defeated even before you even start because you will never start to address the problem.
I just so happen to have such a concept/design, CAD design proven, patent pending and prototype soon to be constructed that I plan to drive across the country with limited batteries on-board and no stops for re-charging in a full sized SUV.
Now guys make all the comments you want, but beware, when my design is proven your words might taste mighty rancid. FYI, when eventually in production, will not cost any more than today's standard internal combustion engine systems.
Hey, I'll keep you all posted...
Register to Reply 4 comments
Andy Germany (1); Anonymous Poster (1); jack of all trades (1); maxig (1)
