I have come across the following requirement of Client related to Centrifugal pumps : -
"For all Centrifugal pumps, NPSHA at 80 % of Normal Operating flow rate shall be equal or be greater than NPSHR required to meet the 40,000 hours life criteria"
I have never come across such requirements.
How diff. of NPSH is related to Pump life criteria and How can we get assurance from vendor for compliance to Client requirements.
Is there any specific parameters like SSS (Suction specific speed) we can cross-check for compliance.
Is this requirement is related to SSS ??? I do not think so. as in spec. vendor has not mentioned limitation on SSS Value.
For your info. : - One of the Client spec. ask for - " NPSHA shall exceed NPSHR by atleast 1 meter throughout the entire range from Minimum stable flow to 120 % of BEP (Best efficiency point)". If I comply with this requirement, I understand, requirement highlighted in "BOLD-BLACK" above is automatically fuiifilled and no need to confuse Pump vendor by highlighting BOTH the points.
Looking for your expert view on this matter.
