Previous in Forum: Claiming Damages from Your Local Utility   Next in Forum: Amazing Cell Phone
Prime Numbers
08/03/2009 4:52 PM
Some of you may have noticed that certain items are made using the prime number 7. I have noticed things like automobile wheels and sheriff's badges having 7 points or spokes. Why would anyone choose to divide a circle into 7 equal parts? Take gears for example. The number of teeth is never a prime number. 360° ÷ 7 will never come out even.
Mr.Ron from South Ms.
Pathfinder Tags: mathematics
Good Answers: 101
Re: Prime numbers
08/03/2009 5:51 PM
Because 7 is just a good friendly number (despite all those nasty rumors).
This response was brought to you today by the letters "R", "V", and "Z" and the numbers "1" and "7".
Re: Prime numbers
08/03/2009 6:20 PM
Japanese bloke I worked with not long after the introduction of the 50p coin in the UK asked similar questions. "How do they get the angles correct - there's no geometric construction ...?" and "Why ...?"
Good Answers: 143
Re: Prime numbers
08/03/2009 8:07 PM
There's a weird math story about that coin. Now if I could only remember... it's something like those weird triangular manhole covers (in San Francisco, I think). I'll search for my memory neuron (I think I saw it at the bass fishing tournament being used as bait, so..) and will get back to you, provided I remember to do that.
Hobbies - Musician - guitar fan Greece - Member - Engineering Fields - Software Engineering -
Good Answers: 18
Re: Prime numbers
08/04/2009 2:27 AM
I once had the same question myself. The explanation is easy: This shape has constant width! Therefore, it can fit precisely in a slot (e.g. at an electricity meter) no matter the orientation.
Check this link for more similar constant width shapes:
http://www.cut-the-knot.org/do_you_know/cwidth.shtml
tkot
Re: Prime numbers
08/04/2009 3:42 AM
That's all very well, though most other coins, apart from the 20p piece, are circular.
It must waste a lot of metal at the stamping operation.
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
Re: Prime numbers
08/06/2009 4:45 AM
There are a number of reasons why coins are the shape they are, with lots of geometric construction! This is in order to meet requirements from two main constituencies:
1 Coin Operated Machines
As has been stated, coins need to be constant diameter in order for coin operated machinery to accept them. The geometries that make this work are the odd-side polygons with a circular arc on each side.
As an aside, that these shapes are indeed constant diameter can be demonstrated by putting them on axles, and running a flat plank over a series of the (think stones over rollers); the plank will stay level. They can't be used as conventional wheels as the radii are not constant.
2. Coin Identification by the Blind
This is the second major driver in coin design. A number of parameters are used:
Weight, thickness, milled or smooth edges, and shape.
The seeing population also use these parameters, probably without noticing. I know I find "foreign" coinage difficult to identify quickly as they are all circular. In the case of the Euro-cent coins, these have different numbers of "flutes" around the edges. If I used them more often, I'd probably be familiar; it's just not as obvious as British coinage.
Chaos always wins because it's better organised.
Good Answers: 101
Re: Prime numbers
08/03/2009 6:52 PM
[edit] Chemistry
[edit] Astronomy
[edit] In technology
(yep... I copy and pasted that right from Wiki.)
Good Answers: 11
Re: Prime numbers
08/04/2009 8:34 AM
I once asked someone about the recurring numbers of 7 and 12 in the bible. He gave me an answer that really made since (to me at least).
When you think about the first few numbers, 1 and 2 cannot support a structure. Numbers 3 and 4 have long been considered the first two stable numbers (a triangle or rectangle base). These numbers can support structures. 3+4=7. 3*4=12. So 7 and 12 were considered perfect numbers. If I remember right, mankind was typically represented with a number 6 for imperfection.
I'm not trying to bring religion (I'm sure there's similar reasoning for all religions) into this thread but if this is true then it would mankind's fixation on the number 7.
Good Answers: 18
Re: Prime numbers
08/04/2009 8:43 AM
Additionally, something that is not mentioned, is that you can compact 7 circles (or cylinders, eggs, etc) with each circle touching all its neighbors. The empty space is minimized. No wonder that they use this configuration in cable construction.
tkot
Re: Prime numbers
08/04/2009 4:06 PM
This phenomenon is espontaneously reproduced by bees while constructing honeycombs, which lead "scientists" to believe that bees had some type of "sense of geometry"
L.O.L... I mean, Yahlasit
Good Answers: 75
Re: Prime numbers
08/06/2009 5:15 AM
It's this rather than any "magic" or religion that makes numbers special. The Magi (wise men rather than magicians) were chemists, physicists, mathematicians and engineers. Their successors were the Masons' Guilds, as distinct from Masonic Lodges which are a mutated descendant of the Guilds.
All of them sought to hide the knowledge so that it carried a price to it - like the recipe for CocaCola! If you could find it hiden in plain view, you were an adept and therefore worthy of having and using it. I think they's be astonished at how freely we bandy it about.
What they did was considered magic (just the noun/adjective from magus) only because people didn't understand how they did it. Heck, I have problems understanding how Lincoln Cathedral, York Minster, Chartres Cathedral and all the other Gothic masterpieces were built in the 12th Century without cranes! Or why in the 21st century we can't build anything as magnificent and beautiful!
There are stories that certain monks worked night by a steady light that wasn't candlelight, there are the Baghdad Batteries. Our Ancestors knew and understood a lot more than we give them credit for - and much of which was lost during the Dark Ages. Perhaps the Knights Templar's "treasure" was knowledge rather than gold?!
Re: Prime numbers
09/30/2011 3:47 AM
"Heck, I have problems understanding how ... all the ... Gothic masterpieces were built in the 12th Century without cranes!" - Should've asked Tricky Dicky - sure he'd've pointed you in the wrong direction!
Re: Prime numbers
08/06/2009 6:50 AM
OK, so why do egg boxes contain 6 eggs?
Good Answers: 75
Re: Prime numbers
08/06/2009 8:35 AM
Because that's half a dozen, of course
Oh, alright, it's because [traditionally] one doesn't eat breakfast on Sundays, so there was a need for 6*e eggs per person each week (where e = number of eggs eaten in each breakfast).
Either that or it makes a convenient sized box. Five (5) would be a silly number of a box...as I said earlier, it's a nasty number! Seven would mean one left over to go off.
#98
Re: Prime numbers
08/13/2009 9:05 AM
Re: "...why do egg boxes contain 6 eggs?" ...
'round these parts, it would ONLY be because somebody already consumed either 6 or 12 of them. All our grocery shelves are loaded with boxes of either a dozen or 18!
Re: Prime numbers
09/22/2009 5:13 AM
there is some more to relate this problem to other prime numbers and even to the periodic table and the structure of condensed matter .. try to google the title 'Primes, Geometry and Condensed Matter'.
#113
Re: Prime numbers
09/28/2011 11:48 PM
yup ... with 6 or 8 circles you can't make the circles touching each other as you make with 7 circles
Beelzebub has the devil put aside for me ... (Bohemian Rhapsody - Queen)
Re: Prime numbers
09/30/2011 2:47 AM
You forgot to put the basic condition that all circles should be of equal diameter.
Re: Prime numbers
08/04/2009 4:01 PM
You forgot to copy from somewhere else that there are only 7 basic crystaline configurations.
Yahlasit
Good Answers: 75
Re: Prime numbers
08/06/2009 5:00 AM
Seven days?
Re: Prime numbers
08/06/2009 5:40 AM
Sorry, I disagree with all those who have given you GA.
Your long list is not an answer to original question.
Good Answers: 75
Re: Prime numbers
08/06/2009 8:23 AM
Did you hit the "Rate" button and de-rate the answer? CR4 is a benign autocracy, with pseudo-democratic features. Rating GAs in one of those features.
Don't tell CL I said that!
Re: Prime numbers
08/06/2009 8:43 AM
No I did not do that. When I posted my views, there were 3GAs and still those are three.
I just expressed my views.
In fact, there is no answer to original post yet from anybody. All are putting something related to various numbers.
Good Answers: 75
In reply to #64
Re: Prime numbers
08/06/2009 9:05 AM
Just letting you know that you can do that...see! You're now only 4 points off topic, not 5.
Ronseto has said somewhere (post # in the 50s) that he's now answered his own question - based on the various gear related answers that there have been.
In reply to #64
Re: Prime numbers
08/13/2009 9:09 AM
be surprise where the answer is hidden.......it may not be where you think.
Good Answers: 204
Re: Prime numbers
08/06/2009 10:45 AM
The original question as I read it was about the prime number 7, and the gear thing was just an example and therefore all things relating to the prime number 7 is an answer.. although the OP was not very specific in his inquiry. Perhaps he could be asked to clarify?
Chris
Good Answers: 19
#81
Re: Prime numbers
08/10/2009 8:57 AM
Re: Prime numbers
08/10/2009 2:19 PM
you brought up a point, I would like to add. iwhen I was in college we had a class in spc and was cover a bit about Demming.
In which it was brought up when you are document processes say on a chart, at the time it was said the which things were going up rarely did it go up 7 times in a row, or down 7 times in a row. and I believe it was the number 7 anyways. We were discussing this and looking at ways to apply it. Flipping a coin, rolling of dice.
An example, if you were to flip a coin, it would not get 7 heads in a row.
I suggested 21 (blackjack) later I found out that this was a proceedure called progressive gambling.
I did a quick google search and looked for with this using number 7, but did not com up with a definitive answer but this one was close on what we talked about called the Bernoulli Process.
http://books.google.com/books?id=IuS3o5Eq5rgC&pg=PA253&lpg=PA253&dq=statistic+process+control+and+the+number+7&source=bl&ots=ONwclNpDcE&sig=kvq1CZlgOIACmtm_xOb_AMro-rI&hl=en&ei=YWKASqqDGMOGtgfii_jkAQ&sa=X&oi=book_result&ct=result&resnum=1#v=onepage&q=&f=false
phoenix911
just noticed.....black jack (21) 7 goes into 21,,,3 times.
Could this just be simuliar to 6 degrees of separation.....wait 6 degrees that one less than 7.
get my point....
Good Answers: 75
#92
In reply to #82
Re: Prime numbers
08/13/2009 4:19 AM
Could this just be similiar to 6 degrees of separation.....wait 6 degrees that one less than 7.
Would that be Six Degrees of Bergerac ???
Good Answers: 50
#101
In reply to #92
Re: Prime numbers
08/13/2009 10:28 PM
What if you start counting from zero?
Good Answers: 75
#107
In reply to #101
Re: Prime numbers
08/20/2009 11:52 AM
But you do! It's the links that counted, so if you're first person is counted as zero, the the link between him/her and the next person is link one. boing!
Good Answers: 50
#83
Re: Prime numbers
08/11/2009 3:37 AM
This of course has everything to do with the Illuminati and the Masons.
In reply to #83
Re: Prime numbers
08/11/2009 12:02 PM
Don't forget Peter, Janet, Jack, Colin, George, Pam and Barbara.
In reply to #84
Re: Prime numbers
08/11/2009 6:27 PM
JUST CAN'T KEEP A BL**DY SECRET, CAN YOU!!!!!!!!!
In reply to #85
Re: Prime numbers
08/12/2009 4:31 AM
LOL - It's only so I can ease thing back toward the merits of 5 as a much better number
Good Answers: 50
#88
In reply to #86
Re: Prime numbers
08/12/2009 10:37 PM
See, this is why bigots never go after the English... It's just no fun shooting fish in barrels.
Good Answers: 75
#93
In reply to #88
Re: Prime numbers
08/13/2009 4:26 AM
Chris Adams, Chico, Harry Luck, Vin, Bernardo O'Reilly, Britt and Lee. They were good at shooting....
In reply to #88
Re: Prime numbers
08/13/2009 8:41 AM
Shoot away - if you think you can.
Good Answers: 143
Re: Prime numbers
08/03/2009 8:19 PM
The sheriff's badge can be 5, 6, or 7 points. But 7 is magic; it comes from the old Celtic: the Sun, the Forest, the Sea, Magick, the Moon, the Wind and Spirit. See, Shire Reifs used to ride around in the dark forests where there were all manners of goblins and witches and they used Celtic magic against the haints.
Actually, you can sorta get gears to work out if you use an epicycle planetary drive. You can get all kinds of weird ratios.
Otherwise, I'd bet on the Book of Revelations for the popularity of the number 7.
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
Re: Prime numbers
08/03/2009 8:32 PM
Seven days to the week, 7 branches on the menorah. Seven is a very symbolic number in Judeo-Christian tradition.
1 + 6 = 7
One represents God, 6 represents man.
2 + 5 = 7
Two represents witness, 5 represents grace.
3 + 4 = 7
Three is another number associated with God, 4 is associated with the Gospel.
Seven is also the largest single digit prime. Pi is roughly 22/7.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
Good Answers: 11
Re: Prime numbers
08/04/2009 4:04 AM
Any explanation why 2 represents witness and 5; grace or indeed one for God and six for man. How about 4 for elephant and three for diode?
horsepower measures work, ponypower measures pleasure!
Good Answers: 75
Re: Prime numbers
08/06/2009 5:26 AM
Not sure if the ancient Hebrews knew about elephants...pretty sure they didn't have diodes
1 = God: presumably because there's one one (Abrahamic) God
6 = Mankind: someone else said imperfection, perhaps because we surround God (back to the 7 circles), most probably just to make the sums work! Also the day on which Mankind was created according to Genesis.
As to the rest, the number associations in themselves aren't important, the list as a whole acts as a form of mnemonic - vital in an illiterate culture.
Have you never listened to Deck of Cards?
Good Answers: 11
Re: Prime numbers
08/06/2009 5:58 AM
Am I missing something? Is this really a valid answer?
Is all knowledge based on what ancient Hebrews knew?
If the numbers aren't important, just a mnemonic, how do we know what is important. What you think is the mnemeonic could be the message and vice versa.
And this is a good answer because it makes my sums work.
Simon
ps I have heard the deck of cards song but I have no desire to libel rich singers and richer record companies by saying what I think of it.
I just wish fewer kids were sent out to die in God's name, whichever God.
Good Answers: 75
Re: Prime numbers
08/06/2009 8:32 AM
Possibly a sense of humour (or at least of the ridiculous) and No.
Of course not, but since the original comments about numerology came from a Hebrew source (if it didn't, then my apologies and darn it, just substitute the correct civilization and the joke will work) I was linking back to that. It was a coded but humorous (at least that was the intention) way of answering your why not question.
how do we know what is important?
I think that is the basis of all religions and philosophical schools
Good answer!
ROFLMAO
Amen to that - no disagreements here.
Pax ~ Peace ~ Shalom ~ Salaam
Good Answers: 103
Re: Prime numbers
08/03/2009 10:16 PM
Mechanically there is a reason (I don't know if the God had the same thing in mind)
The prime numbers mage a good anti-resonator (natural harmonics are never a round figure )
Eg in our gear boxes always our ratios are like (95/7, 67/4, 31/11, 79/7 to name a few)
Same things usually goes with number of rollers in a roller bearing.
Good Answers: 120
Re: Prime numbers
08/03/2009 11:17 PM
if the cogs are two primes you have the maximum time period before the same tooth strikes the same tooth again, which spread wear.
wheels have odd numbers of spokes/staves so you do not have a flexure axis = weaker spot.
Per Ardua Ad Astra
Re: Prime numbers
08/06/2009 6:13 AM
You quoted the examples, but did not really gave the reason behind odd gear ratios. Anti resonance... I am not aware or sure.
But simple reason to have odd gear ratios is to minimise the contact of same gear teeth again and again. This protects gears from damage of particular gears due to any possible hard spots on some singular gear.
Good Answers: 103
Re: Prime numbers
08/06/2009 7:53 AM
Explanation in #15 I think
Re: Prime numbers
08/03/2009 11:42 PM
I am sure that in the catalog literature you can find many examples of sprockets, gears, screw compressor rotors, and the like with prime numbers of teeth or lobes. One advantage is that on successive revolutions, the same teeth or lobes do not always mesh with the same teeth or lobes. This spreads out wear and can reduce vibration and drive-chain whip. Also, such gear ratios are useful in lathe cutting of screw threads, for instance. (Or if not prime numbers, pairs of numbers that are relatively prime to each other.)
It is true that for most primes, there is no (and certainly no easy) geometric construction. However, CAD programs can accurately do these subdivisions. This certainly beats using dividers to lay out 97 pins in a circle to engage with a 1" pitch 16-tooth sprocket, say.
Re: Prime numbers
08/04/2009 10:27 AM
"CAD programs can accurately do these subdivisions." I tried a layout on Autocad and using the polar array command and 7 divisions within a 360° circle, came up with an even numbered angular value as long as the number of decimal points accuracy was set at 1. When I set the accuracy to 8 decimal points, I got 51.42857143°.
Re: Prime numbers
08/04/2009 12:18 PM
" ... came up with an even numbered angular value as long as the number of decimal points accuracy was set at 1."
Don't understand. Are you talking about the dimensioning accuracy?
Re: Prime numbers
08/04/2009 1:23 PM
The accuracy is not the point. How for example would you layout 51.4285143°? You could round down to 51.43 or even 51.4, but it would not be exact.
Re: Prime numbers
08/04/2009 4:08 PM
How do you know when you layout 10.0 deg its exact?
Pineapple
Re: Prime numbers
08/04/2009 7:52 PM
Ah! - I see what you're getting at. That was the sort of thing that my Japanese friend was fretting about (see #2). [When you said "even numbered", I assumed you meant divisible by 2 without remainder].
You can choose almost any angle you like between two lines - whether or not the numeric representation is an integral number of degrees - and it can be (theoretically) made exactly provided that there's a geometric construction that will give that angle.
If you try to make something with two lines at an angle which cannot be geometrically constructed, then (theoretically, again) it can never be made exactly - there will always be a more precise result.
(I've generalized here a bit to any initial angle to be subdivided - not just 360°. If the angle between the two lines was 360 ÷ (4 x √2), which is "about" 63.639610306789277196075992589436°, it can still be bisected exactly - never mind how many decimal places are used).
<keeping my head down now coz it's late and I don't want to wait for the ricochet>
Good Answers: 75
Re: Prime numbers
08/06/2009 5:30 AM
Ah! Now I see what you meant in the early post - and apologise for not getting it then. WRT coins and machines, I think the level of accuracy required is low enough that it doesn't become an issue.
I can't see the site, but I presume you're dodging flying lead and tryong to lead us to considering why time is divided into base 60 divisions (that's them Aztecs) Sweet!
Good Answers: 88
Re: Prime numbers
08/06/2009 6:49 PM
"...why time is divided into base 60 divisions (that's them Aztecs)..."
The Babylonians & Sumerians used a base-60 number system. The Aztecs, Mayans, Celts and Basques used a base-20 system.
Good Answers: 75
In reply to #72
Re: Prime numbers
08/07/2009 4:24 AM
My bad. I thought the Aztecs and Mayans used base 60 in the sun wheel calendar. Off to redo my research.
Good to have you back checking my work !
In reply to #73
Re: Prime numbers
08/07/2009 1:01 PM
All you need do is check europium's home page. Briiliant site....answers for almost any subject you can think of
Good Answers: 75
#89
In reply to #75
Re: Prime numbers
08/13/2009 4:08 AM
europium, Transcendia....when would I have time to read CR4 ?!
Or type up as-yet unread episodes of an E in P...
Good Answers: 103
Re: Prime numbers
08/04/2009 12:44 AM
Did you google 7 ?
The properties of 7 looks to be unique as a prime number. It is a member of too many groups of prime numbers
http://en.wikipedia.org/wiki/7_(number)
  • Seven is the fourth prime number. It is not only a Mersenne prime (since 23 − 1 = 7) but also a double Mersenne prime since it is itself the exponent for another Mersenne prime (127). It is also a Newman-Shanks-Williams prime, a Woodall prime, a factorial prime, a lucky prime, a happy number and a safe prime. http://en.wikipedia.org/wiki/Mersenne_prime Quite a few of these look to be very very interesting. I am not sure when they took up seven, then they thought about these or simply by trial and error they 7 did fit? BTW - there are a few numbers in the common subset, but 7 is the first one. So may be as you start trial and error, the 7 being the smallest stuck. Another interesting part from wiki
  • A seven-sided shape is a heptagon. The regular n-gons for n ≤ 6 can be constructed by compass and straightedge alone, but the regular heptagon cannot. Figurate numbers representing heptagons (including seven) are called heptagonal numbers. Seven is also a centered hexagonal number.
Re: Prime numbers
08/04/2009 3:47 AM
Reducing gear wear is the best answer given.
More generally, prime numbers are regarded as the building blocks of all numbers. Elemental freaks that pop up without pattern for ever and ever and ever.
Sorry, Ron, but I don't see anything extra special about 7.
5 - now there's a number to be reckoned with !
Good Answers: 103
Re: Prime numbers
08/04/2009 4:20 AM
Gear wear can be reduced (or in fact increased?) by any non integer ratio.
The increased is because of the fact - let us say a gear tooth always comes in contact with the same tooth of the other gear, then the two tooth carry out the so called self correction (a bit like lapping) to take out the minor inaccuracies. But if it contacts all of them, then all these have to be corrected by it, and then the second tooth (behind it) does the same thing all over and so on.
The fundamental (or natural harmonic) of the gear engagement when the ratio is something like /7 then becomes a non integer and then the mechanical resonance requires too much of an design effort to match so thet the equipment self destructs in operation. And I am sure no engineers are upto the task.
For this purpose, 5 is not a good number and 3 is OK but it gets affected by that 120 number in the synch speed of the motor (making the RPM 3600 or 3000) so 7 is the first in the list, followed by 11.
That's what I said in #7 (without explanations) and based on our gear boxes.
Re: Prime numbers
08/04/2009 5:13 AM
....and thank you for the elaboration on harmonics, sb ! I shall give you a GA as well, in part for combing #7 with your 7-related information, but mainly for the information.
Good Answers: 103
Re: Prime numbers
08/04/2009 7:15 AM
part of the life . I have been in the gear boxes (both ways as mfr as well as you know what ) for a quarter of century or so, with speed ranging from 10s of K to meagre 20 RPM for various equipments- of course different gear boxes. (The gear box as usual has to be a part of the equipment for any mechanical OEM )
the statement was one of the basic one for us being day in and out in gears and seen so many wear patterns, failures... especially in a few rare cases where the multiplication is an integer number.
BTW: our a few ratios as I mentioned were 79/7, 34/11 and in one large case 222/28 (and that too comes out a bit of 7 effect.
Re: Prime numbers
08/04/2009 7:54 AM
Oops, forget to give you the GA earlier !
You can't have a second one for more info on gears, but you will get an extra card in my card-index file
Good Answers: 15
Re: Prime numbers
08/04/2009 7:55 AM
Hey Kris. Now your 2nd pic is what I would call a PRIME #.
scotchdrnkr
Re: Prime numbers
08/04/2009 7:57 AM
Doubly so, because 2 is a prime as well
Good Answers: 75
Re: Prime numbers
08/06/2009 7:50 AM
5 is a very nasty number. 4 is much more cuddly.
2 and 3 are too close together and too similar for my liking.
Synesthesia anyone?
Re: Prime numbers
08/06/2009 9:09 AM
Oooooooooh, yes!
Cuisenaire rods!
Good Answers: 75
In reply to #66
Re: Prime numbers
08/06/2009 9:31 AM
Nope, never encountered them...but was taught lots of maths before I started school, so would have ignored them anyway, in that I would have found they took longer to use than I would to work it out. I did that a lot in maths...
I did love using the SRA boxes at junior (7* - 11 yo) school - yes even in the UK. Stupid Education Departments for dropping them
*See still on-topic!
Good Answers: 75
In reply to #66
Re: Prime numbers
08/06/2009 10:29 AM
They're still making SRA Boxes...and they're more funky that when we used them and subject specific.
Re: Prime numbers
08/04/2009 1:33 PM
I think many of you have missed the point. Let me present it in an example. Most lug arrangements on automobile wheels are a 4, 5, 6 or 8 lug pattern. I have never seen a 7 lug pattern nor has anyone else. There must be a reason why you would not choose 7. Truck wheels have 10 and 12 lug patterns, but never 11. Lug patterns are always a number divided into 360 that comes up even.
Re: Prime numbers
08/04/2009 2:59 PM
Maybe it's even numbers so you can tighten opposite pairs without forgetting any. 5 is OK, because it's easy enough not to forget, but a larger odd number might lead a person to miss some. 5 is readily seen, but 7 is not as readily noted by the brain ? On the other hand, it might be superstition.
Re: Prime numbers
08/04/2009 4:08 PM
Actually some Ford vans and light duty F250's use a 7 lug pattern
Re: Prime numbers
08/06/2009 6:53 AM
Not so for the 1980 VW Passat, which had 7 lugs to hold its hub caps on.
Re: Prime numbers
08/06/2009 12:19 PM
Hmm... I will have to find my 7 lug wheel hub I found in the scrap yard then and post a picture! Once I figure out how to do that.
I kept it just because its a unusual odd numbered lug system. Good bet winner too!
In reply to #71
Re: Prime numbers
08/09/2009 12:29 PM
I checked with a wheel company and a 7-lug pattern was used on heavy duty Ford F-150's and F-250's around 2000-2002. I still don't understand why they didn't go to an 8-lug pattern like the more recent trucks use. Was it cost consideration (1 less stud/lug per wheel)? Granted, a 7-lug pattern can be lay-ed out pretty accurately, but never perfectly (as an even divisor into 360), but why use 7 which complicates a normally simple layout? If there is a perfectly simple answer why, I'd like to know. Sorry for kicking this dead dog around for so long.
In reply to #79
Re: Prime numbers
08/09/2009 1:52 PM
Its surprising the savings that could happen with just one lug per wheel.
They must have taken the que from the airline industry.
http://www.nytimes.com/2005/06/10/business/worldbusiness/10iht-air.html
That dog isn't dead...its resting....you see it moved. (a skit from Monty Python dead parrot skit) http://www.youtube.com/watch?v=4vuW6tQ0218
phoenix911
Good Answers: 75
#91
In reply to #80
Re: Prime numbers
08/13/2009 4:11 AM
cue...as in stage cue....
Sorry, sometimes I can't help myself. think of it not so much as a correction as a teaching point for non-native English speakers...
In reply to #91
Re: Prime numbers
08/13/2009 6:58 AM
better brush up on my english to english translation then to speak to you brits....
phoenix911
In reply to #94
Re: Prime numbers
08/13/2009 7:04 AM
¿que?
Good Answers: 75
#96
In reply to #95
Re: Prime numbers
08/13/2009 7:12 AM
che? and chi?
Good Answers: 50
#103
In reply to #96
Re: Prime numbers
08/13/2009 11:30 PM
kay!
In reply to #95
Re: Prime numbers
08/13/2009 10:42 PM
You lost me at ¿, wheres my English dictionary........no, not that one, the other one.
Good Answers: 19
#104
Re: Prime numbers
08/20/2009 10:20 AM
could it be a legacy from indexed dividing heads / rotary table when these things were (initially at least) done by hand in the toolroom?
(I remember being introduced to the intricacies of the dividing head by Dennis Ingram at ATG Aylesbury when producing a graduated dial for my lathe).
Perhaps this has already been suggested and I've missed it in the thread.
Re: Prime numbers
08/04/2009 4:50 PM
Have you guys noticed that any whole number divided by 7 and which result is not a whole number, will always have a mantissa repeating 428571 apparently endlessly (depending on what number you divide the mantissa will start from 4 or 2 or 8 etc.)?.
Just throw the chalk to my head, not good at math anyway.
Yahlasit
Good Answers: 103
Re: Prime numbers
08/05/2009 4:08 AM
You will get this repetitive patterns on any prime numbers (provided they are not multiples) the only exceptions I find is 2 and 5.
3: repeats continuously
7: every 7th
11: every 3rd
13: Every 7th
17: Every 17th
19: Every 19th
23: Every 23rd
29: every 29th and so on
(Could not go on using calculator and that too has a limit to the decimal places)
But again repeatibility is not the issue here.
PS:
Sorry missed the point - Yes you are right the cyclic pattern is shifting for 7 but that may be a part of the unique ness. But does it have any scientific use?
Again PS2:
17 also has that property and may be a few more primes too.
Re: Prime numbers
08/20/2009 10:38 AM
you may have had a boring day, but you were not alone.........I was doing something simuiar trying to find a pattern. It was on a tangent to a problem but for a reason the escapes me at the moment.
Good Answers: 204
Re: Prime Numbers
08/04/2009 7:10 PM
Apparently you can only fold a sheet of paper in half not more than seven times.
Good Answers: 101
Re: Prime Numbers
08/04/2009 7:30 PM
Hmmmm...... well... does that hold true for.. say a "D" size? or "E" size sheet of paper? we'll need some clarification.. or better yet some experimentation...
I just tried with an 11x17 sheet... definitely could not fold more than seven.. (in fact the bast i got is 6 folds in half.
Would that hold true even If the sheet was the size of a football field??
Re: Prime Numbers
08/04/2009 7:56 PM
Yup - try it if you think you're up to it .
<if you think you're 'ard enough - come an' 'ave a go ... >
Good Answers: 96
Re: Prime Numbers
08/04/2009 9:28 PM
Hi RVZ ... actually this Myth was BUSTED :-) "The television series MythBusters "busted the myth" of the 7 fold limit by folding taped-together sheets in half and turning 90 degrees each time, for a total of 11 folds. The first eight folds were completed by hand, while the rest were completed using both steam rollers and fork lifts. [2][3] This was accomplished using 17 large rolls of paper taped together to form a very large yet relatively thin "sheet."" Kind regards ....
"Just when I had all the answers, they changed all the questions"
Re: Prime Numbers
08/05/2009 2:09 AM
I'm not convinced that a 'true' fold could be done. Consider the friction between the sheets on the inner side of the curve as the paper is folded. When you get to the umpteenth fold, either the outer sheets must tear, or the inner sheets crumple up. Apart from the sheets not wanting to slide over each other, the outer sheet's curved over Pi.R compared to Pi.r on the inner.
If you let the sheets (or parts thereof) slide, then it's not truly folding them all as one piece. If thickness of paper is t, the inner sheet has curvature of Pi.t. The outer sheet would be stretched to Pi.211.
Good Answers: 11
Re: Prime Numbers
08/05/2009 3:48 AM
don't see why this is off topic so I tried to GA it, but all I can do is undo the off topic, I think. Still good valid and relevant to the number 7
Simon
Re: Prime Numbers
08/05/2009 4:18 AM
The original topic was about dividing a circle (360 degrees) into a prime number of equal sectors. As I pointed out before, there are several good reasons to do this. For a further example, check out cycloid gear speed reducers, in which prime numbers of lobes figure prominently (Sumitomo SM-Cyclo, for example).
The post about six wires in a cable surrounding a seventh central wire is interesting in its own right, but it isn't strictly relevant, because the circle is divided into six parts. Add 12 more wires and you get 19, another prime number and a common wire stranding pattern. Add 18 more wires for a total of 37, again prime and common. If you keep going, you get mostly prime numbers with a few composites from time to time. (These are all called "hexagonal numbers," by the way, and they are useful to know in laying out tube sheets for heat exchangers.)
The paper-folding exercise is completely off-topic, though it too has an unrelated component of interest. And I don't care about the Seven Samurai, or 7-Up, either.
Good Answers: 11
Re: Prime Numbers
08/05/2009 5:37 AM
The original post was generalised in that it included sherriff's badges, where the number was probably more relevant than the engineering.
I find it fascinating the directions that these discussions can go and I have learned a lot from this one, especially the odd number of spokes factor to avoid weakness, i am now going back through all my chariot reference works to see which civilisations used odd numbers of spokes.
We may do things for the oddest reasons, is it relevant that the number of days in the week or months in the year, or days in the year are not in the Fibonacci series?
I hadn't thought of the implications of paper folding in engineering terms and it starts to make sense after reading the post I gave a GA to.
Simon
Good Answers: 204
Re: Prime Numbers
08/05/2009 1:41 PM
"The original topic was about..." the prime number 7.
Good Answers: 75
Re: Prime Numbers
08/06/2009 8:20 AM
A tip for retaining your sanity (if you have any) whilst on CR4 - lighten up and go with the flow. It really is worth it.
Chrisg288 has already quoted the OP, which make's Kris's pix relevant. Kris is very quite almost good at keeping threads from disappearing up their own wotsits whilst retaining relevance (most of the time!). For an introduction to what is acceptable on CR4 see this thread.
Happy playing. (And this really is off-topic!)
Good Answers: 75
Re: Prime Numbers
08/06/2009 8:03 AM
I found it!
This problem was solved in 2002 by a high school student, who derived the limiting equations and as a consequence ceated a unique series of numbers that is now registered.
The limit is actually 12 for same direction folding - oh look! we're back to that other "magic" and "holy" number!!
I remember "Record Breakers" trying this when I was a kid - can't remember what the result was!
Re: Prime Numbers
08/05/2009 4:54 PM
For a picture of some 7-tooth gears, see this link:
http://cgi.ebay.com/Pinion-gear-7-tooth-48-pitch-brass-press-on-new-NR-BRP_W0QQitemZ370229584368QQcmdZViewItemQQimsxZ20090715?IMSfp=TL090715214005r6590
And there are lots of gears in the world with other prime numbers of teeth.
3Doug (1); Amir Sofwan (1); Anonymous Poster (5); aurizon (1); chrisg288 (3); cingold (1); DCaD (1); devitg (1); English Rose (23); gsuhas (4); HUX (2); JohnDG (8); jpcomanche (1); Kris (15); phoenix911 (7); Pineapple (1); PWSlack (4); r5 (1); ronseto (6); RVZ717 (3); saddlechariot (5); sb (6); scotchdrnkr (1); tcmtech (1); tkot (2); Tornado (3); TVP45 (2); user-deleted-13 (2); vermin (4)
