Previous in Forum: Buried Pipes and Concrete   Next in Forum: Small, Very Thin Plastic Enclosures (Think Apple IR Remote)
Information on Aluminium Alloys
08/05/2009 12:07 AM
Hi,
I have a heat sink it is a aluminium alloy.
Grade AAA6005
What does AAA stands for and which hand book can i find this.
can anybody give me the alternative material to be used in place of it and its complete specification & application.
And please let me know were else this AAA 6005 material is used like its application.
Kind Regards
RAJ
Re: Information on Aluminium Alloys
08/06/2009 2:21 AM
Warning: I don't know anything about this sort of thing.
My guess is that it is either 6005 or 6005A
go here
08/06/2009 2:39 AM
6005 is the type of aluminium alloy. AAA, I am not very sure but it should refer to the surface treatment , "Anodising type." Could be hard anodising. Someone who knows about American standards should be able to help.
United Kingdom - Member -
08/06/2009 3:34 AM
you could try eFunda here:
http://www.efunda.com/materials/alloys/aluminum/show_aluminum.cfm?ID=AA_6005&show_prop=all&Page_Title=AA%206005
or matweb here:
http://www.matweb.com/search/DataSheet.aspx?MatGUID=2f1679ed1ada446c8f329a76c72a701a
I haven't got this grade in any of my reference books, but it appears that AA just means Aluminium Alloy. The extra A could be Anodised as Angelo suggested, heatsinks are usually anodised aren't they?
Drew
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
08/06/2009 3:43 AM
Hi all,
The internationally accepted designation system for aluminum alloys comes from Aluminum Association of America. Nowadays we just use the 4 digits to designate wrought product forms.
The series are:
1XXX = Unalloyed aluminum
2XXX = Cu alloyed aluminum
3XXX = Mn alloyed
4XXX = Si alloyed
5XXX = Mg alloyed
6XXX = Mg+Si alloyed
7XXX = Zn alloyed.....
So your alloy is a 6005, that's a Mg-Si alloyed which are age hardenable.
6005 alloy is a designation covered by ASTM B 221 and SAE J454.
Approximate composition:
Composition limits. 0.6 to 0.9 Si, 0.35 Fe max, 0.10 Cu max, 0.10 Mn max, 0.40 to 0.6 Mg, 0.10 Cr max, 0.10 Zn max, 0.10 Ti max, 0.05 max other (each), 0.15 max others (total), bal Al.
Main uses are for ladders, antennas...
Kind regards
08/06/2009 8:14 AM
If you have no restriction as to what material to use in place, you can go copper, it has around 10 times the thermal conductivity as the aluminium.
Just check the later microprocessors heatsinks.
Yahlasit
Good Answers: 25
08/06/2009 9:12 AM
Hi C.RAJ KUMAR,
Sorry but I missed the use of the Al alloy (heat sink).
Following is the thermal conductivity (at 25ºC/77ºF): 180-190 W/m ·°C
The alloy you have now has a good resistance to atmospheric corrosion, is weldable and light weight. There are other materials, as copper with much better thermal conductivity, but higher density (look at cost per unit weight).
I was in a factory which made "heat pipes" as heat sinks for satellite applications and obviously the weight was critical, so we used Al alloys.
The final solution depends on you, balancing the critical requirements of the application and the economical restraints.
Kind regards and good luck
10/23/2009 6:03 AM
http://www.matweb.com/index.aspx
this site will give you all the info on alloys.
Ronnie.
Register to Reply 7 comments
ad016 (1); angelo (1); Anonymous Poster (2); Kwetz (2); Randall (1)
