Previous in Forum: Transformer Protection   Next in Forum: Six-Terminal Motor with VFD Connection
69 comments
Potentiometer on 12V Soldering Iron
08/06/2009 12:00 AM
hi. i have a 12 volt 30 watt soldering iron. But its too hot for my needs.
i have read that you can put a potentiometer on a regular iron and you will give less heat. So i want to do this for my iron, but i don't know what parts i would need to do this. can someone tell me what components i could use to do this? i need the iron to not get hotter than about 160F. thank you
Re: potentiometer on 12 volt soldering iron
08/06/2009 12:50 AM
i also want to measure the temperature of the iron with this thermometer, but it only measures up to 158F which is cutting it a bit close, but i don't think its software limitations, just the point where the plastic wires will start melting, at least thats my theory. anyone know if I'm right, or if there is a way around this? i don't want to buy an expensive thermometer. could i just buy some high heat resistant wire, and use it to replace the wires on the thermometer?
Good Answers: 103
08/06/2009 1:27 AM
1. Yes you can put a potentiometer in series and theoritically reduce the temperature (I2R ) but then these Irons are supposed to have the temperature controller and the input power is regulated by it to maintain the temperature. In that case this will not work.
2. 158oF is only about 71oC I don't think the plastic/Insulation will be limitation for this, nor the element. It is only the scale calibration. Could not see the exact spec hence unable to comment.
08/06/2009 11:44 AM
these irons aren't regulated. how big of a potentiometer would i need?
with my 120 volt (regular house outlet type) 25 watt iron i can melt through project box plastic, and project box plastic is quite thick and hard.
08/07/2009 12:00 AM
P=I*E, or I=P/E=30W/12V=2.5A This is the normal current drawn by your 12V pencil.
E=I*R, or R=E/I=12V/2.5A=4.8Ω This is the normal (hot) resistance of your pencil.
If the 10Ω, (20W or bigger) variable resistor suggested by PWSlack is too expensive (You should be able to find one for a few bucks or less at a surplus electronics place), then you could experiment with one or more fixed resistors, A 4.7Ω resistor (a common standard value) would cut both your voltage and your current in half, so would cut your power to one quarter. It would be carrying around 1.3 A, so it would need to have a power rating of around 10 Watts (including a safety factor). If that is still too hot, get a slightly higher resistance; if it is too cool, get a lower value. Any old electronics buff like myself has a box or drawer with a bunch of such resistors, and would be willing to loan you a few to try, and either give you the correct value or sell it for under a buck.
Note that you are going to need some form of cage or enclosure around the resistor to avoid burning your upholstery or yourself.
12VDC-120VAC Inverters are so cheap now, that I always have one in my car. That way I can use my computer without running down its battery, and also use my 120V soldering pencil when necessary.
Good Answers: 119
08/07/2009 12:45 PM
I've used this very basic chopper circuit for decades. It is a simple PWM switcher which allows power adjustment from 0-100%. You may need to tweak some component values for your particular application. Oscillator frequency should be ~330Hz for circuit shown. This can provide a useful audible feedback depending on the type of load. With carefully layout and selection of component values, I've been able to get this circuit to operate up to 100 kHz.
A standard kitchen meat temperature probe ($10-$20, up to ~400 deg F, available in many stores) could be used for your temperature measurement. A reasonable investment since one of these is a MUST HAVE in many home kitchens. You can use it for both applications if you can keep it clean enough for food use. Good luck!
08/07/2009 2:12 PM
I'm borrowing your circuit, it has a whole lot of applications besides the iron control.
Thanks
Yahlasit
Good Answers: 119
08/07/2009 2:48 PM
You are welcome. That is why I posted it.
08/07/2009 2:51 PM
Me too! GA!
Thanks!
Dick
08/07/2009 4:15 PM
In fact I liked it so much, I drew it up in CAD. Here is the result. Please check it for accuracy!
Thanks again!
Dick
Good Answers: 119
08/07/2009 4:29 PM
Looks fine. I had an old schematic capture and sim program for Windows, but haven't located a good (free) one yet for Linux. Until then, sketches are easier for me to post.
08/13/2009 11:10 AM
Try http://tech.groups.yahoo.com/group/OldDosOrcad/
I know it's for DOS use but I think a couple of members have tried it under Linux using emulation.
Good Answers: 119
08/08/2009 2:19 PM
The credit to my screen name is appreciated. However, this is an OLD app-note circuit from National Semiconductor (~1970's ?). I have analyzed, simulated, and built hundreds like it, but it was born in someone else's brain ;-)
08/07/2009 5:25 PM
what components do i need to "tweak"? sorry, i don't know much about how these different components work.
Good Answers: 119
08/07/2009 7:49 PM
Surplus MOSFET suggestions below. First one will run a little warm (~0.85W) and may need small heat sink. Second one should be fine without a heat sink.
http://www.goldmine-elec-products.com/prodinfo.asp?number=A20393
http://www.goldmine-elec-products.com/prodinfo.asp?number=A10095
The values shown should work for your 12v soldering iron. Try it as-is first. Tweaking may only be needed if you want to change the frequency or trim the min/max duty cycle limits. I could describe how each value affects the circuit, but I'd be typing all night. There is a golden IPA calling my name and it has a higher priority. Sorry. ;-) Cheers.
Good Answers: 68
08/13/2009 5:22 PM
Hello mjb,[p]
GA to you Sir........
Good Answers: 53
08/06/2009 2:34 AM
You can also use a thyristor based regulators (dimmers) normally used for lights and fans, Why to put a fuming hot goblet beside you?
Location: Currently on break at home in Houston, Texas USA
08/07/2009 5:56 AM
Rakesh is right on the money. Throw a lamp dimmer in the mains line.
08/07/2009 9:29 AM
Uh, those light dimmers are great stuff for AC where they chop off part of the waveform but they won't do squat on a DC circuit... except burn up that is.
Good Answers: 53
08/07/2009 11:48 PM
Does it matter operating an iron on AC or DC? I can not understand how it matters?its mealy a resistance, Its AC or DC its going to heat.
08/08/2009 12:09 AM
It doesn't matter as far as the soldering pencil is concerned (I refuse to call anything that small a soldering IRON), but it sure does matter when it comes to controlling the input power! A transformer (fixed or variable) works fine on AC, but it's useless on DC.
Good Answers: 53
08/08/2009 1:08 AM
Transformer is out of context here, Its nowhere in talk. Question is will a resistive load work on both AC and DC and answer is yes, So its a AC or DC regulator,both are going to work fine with a soldering iron no matter how big is it.
08/08/2009 1:26 AM
so i can use a regular dimmer and it will control the voltage going into the iron?
Good Answers: 53
08/08/2009 1:52 AM
Yes,of-course you will have to customize it to your requirements.and if you plug it, in between an AC source and soldering iron only.No cigarette lighter,
08/08/2009 2:00 AM
well it needs to be for my 12 volt car socket
Good Answers: 53
08/09/2009 1:48 AM
You can try this duty cycle controller.
Good Answers: 119
08/08/2009 2:09 AM
A standard light dimmer plugged into a 120Vac source will control a soldering iron designed for 120V operation. I use one like this all the time.
A standard light dimmer plugged into a 12Vdc source (car battery) will NOT work with any soldering iron.
Radio Shack (online) does appear to have the basic parts needed to build a version of the simple chopper circuit posted. I'm used to getting these parts at bulk/surplus pricing (whole circuit < $1.25), but I think it will cost you closer to $10 at RS. Is it still worth it? Your call.
08/08/2009 11:19 AM
yeah $10 is good. but i cant find either the lm393 or lm2903, and i don't know what would be equal to them, i also don't know what an n-fet is.
i have now gone through the radioshack website and have found everything aside from the c1 and c2, the n-fet, and the pot. i don't know which pot to get. there are three
1
Good Answers: 119
08/08/2009 11:32 AM
Radio shack does appear to have an N-Channel MOSFET which should work, but will require a small heat sink (worst case ~2.8 W). Suggestions below.
data sheets
http://www.irf.com/product-info/datasheets/data/irf510.pdf
http://www.national.com/mpf/LM/LM339.html
N-Channel MOSFET
http://www.radioshack.com/product/index.jsp?productId=2062618
LM339, basically the same except 4 comparators inside chip
http://www.radioshack.com/product/index.jsp?productId=2062593
linear taper pot 100k
http://www.radioshack.com/product/index.jsp?productId=2062287
heat sink for TO-220 package MOSFET
http://www.radioshack.com/product/index.jsp?productId=2102856
08/08/2009 11:44 AM
thank you very much for the time you have given me!
i only need one N-Channel MOSFETand one lm339 correct?
Good Answers: 119
08/08/2009 2:03 PM
Correct. Only one of each is needed.
Be careful when initially testing circuit. A bench-top power supply is preferred because they usually have a current limit setting. Incorrect wiring of parts and testing directly on a car battery can lead to large current surges which can EXPLODE parts and melt wires. Double (triple) check your circuit wiring before connecting to the battery.
08/08/2009 7:53 PM
ok, i have soldered together most of the circuit. But i don't know which leg from the nfet goes where. and I'm not completely sure how the pot should be wired. so i drew a bad picture of what i think is the right way to solder them
Good Answers: 119
08/08/2009 9:13 PM
The pot connection looks OK. Full CCW should be min power and full CW should provide max power. Just like a normal volume control.
The FET wiring looks incorrect. See clip below for pin labels.
08/09/2009 2:03 AM
thank you!
it works great!
thank you so much mjb1962853!
Good Answers: 119
08/09/2009 2:13 AM
I'm glad it worked for you. Best wishes.
08/09/2009 1:13 AM
As you should have seen by now the requirement is for a method of controlling energy from a 12VDC source (cigarette lighter type output) to power a 12VDC soldering pencil.
To my knowledge, there are two basic possibilities: 1. Throw away part of the energy somewhere else, as in a rheostat controller, or 2. Use some form of chopper (PWM) to turn off the power part of the time.
08/07/2009 2:26 PM
Exactly, and you'll se how much money you can save on your car's electricity bill.
Thank you Rakesh
Thankyou Tripcalspeed
Australia - Member - Igor...pull the switch!!!
Good Answers: 12
08/08/2009 8:45 PM
Rakesh,
I use one of those thyristor reg's on my 240AC soldering iron....totally awesome
I have one in use for a studio light too, but that's off topic.
...to go this way, make sure your amperage consumption matches the thyristor unit.
For DC, I use an old ATX power supply and also use sometimes a heavy duty Lab Power Supply.
CraziestOzzy
08/06/2009 3:13 AM
  1. A big ol' 10Ω rheostat would do the job, though it's a bit wasteful.
  2. Another possibility would be a speed controller for a model railway application - preferably one intended for Gauge 1, as it needs to deliver some amps.
  3. How about a bench-top power supply unit, appropriately rated?
Good Answers: 53
08/06/2009 3:25 AM
Yes you are correct.
Re: Potentiometer on 12 Volt Soldering Iron
08/06/2009 11:55 AM
rakesh_semwal
Dimmers are made to be used on your houses power lines (120 volts at however many amps). my cars cigarette lighter plug only has an output of about 14 volts, i don't know the amperage here either, but i doubt its very high.
"Why to put a fuming hot goblet beside you?" what?
PWSlack
1 quick search. seems like this coasts more than my thermometer and the iron put together. I'm meaning very low here
2 don't have one of these, so again too much money, also i want the iron to run off my cars power.
3 i do have one of these, but like the last one, i need it to run off my cars power
Good Answers: 53
08/06/2009 12:24 PM
Rheostat, isn't it?
08/07/2009 2:29 PM
Come on Rakesh, you're very good at other stuff, but this time you're not even close, just get over this OK?
Good Answers: 53
08/07/2009 11:52 PM
How come? Don't you know controlling power with resistance means something heating somewhere? Is it first time someone saying?
come-on!!!!!
Re: Potentiometer on 12V Soldering Iron
08/06/2009 11:24 PM
You can connect a wire wound variable resistor (Potentiometer) of 5 Ohm, 10 watts capacity with suitable arrangement for mounting, considering heat dissipation - there will be more heat generation (in potentiometr) at lower setting. The power output at Soldering iron will be in the range of 7.2 Watts to 30 Watts depending on setting of the variable resistor. This will be connected in series with the soldering iron.
Good Answers: 119
08/07/2009 12:50 AM
Put together a small chopper circuit that uses a low watt potentiometer to control duty cycle from 0-100%. This should be cheap and easy for a 12V and 2.5 A. You will get total control of the iron and none of the control parts should even get warm. You can also add a thermistor and a few extra parts for temperature feedback or a simple temperature limit control.
08/07/2009 8:29 AM
Very good. Precisely what I was thinking of. The cheap way to go. GA
08/07/2009 2:20 PM
Very good, yes, but not precisely what your previous posts reflected.
Yahlasit
08/07/2009 3:03 PM
In my previous post, I threw out there an AC operating device without reading throughly and discovering that the application requires 12VDC. A simple PWM circuit with a load-control will do nicely. As a footnote, why should I explain myself to someone who is logged on as a Guest anyway?
Good Answers: 119
08/07/2009 3:26 PM
"lux ex tenebris" = "Light from Darkness"
If you are part of the 67th, I salute you and all the men and women serving our country. If not, I still like your motto! Best wishes.
08/08/2009 2:37 AM
Thanks for that friend but I'm not part of the 67th. I was part of the 12th TFW although they had no latin motto: only the english one "Drink all you can and give away the rest".
I am fluent in Latin and like to change out my motto occasionally. It may get readers to thinking.....
Here is one of my favorites and I take credit for this one. It describes the alternate acronym for the electronic communication term "FM": Fornicationus Magus!
08/07/2009 2:03 PM
Hmm, interesting, you posted the best answer in this thread along with a schematic but didn't even get a reply; but when you posted basically the same without the schematic you even got a GA !
I wander what it means...
Yahlasit
08/07/2009 7:50 AM
If you want to keep it simple there are low voltage multi tapped transformers available, one I am looking at has 0v-15v-17.5v20v-24v-27.5v-30v, you can switch to any of these taps to give you a range of voltages. Also you will know that the temperature output will be repeatable for any of these tap positions.
You will have no power loss and a quiet circuit with no switching noise.It will be cheaper than a 3amp WW potentiometer.
Hah sorry just noticed you want to run it off a car battery not stated in your origonal post.
Just strap a 10Amp power mosfet to a heat sink and regulate it gate bias with a cheap potentiometer feed your soldeing iron through this.
08/07/2009 1:57 PM
Power Mosfet? thats Ok for switching, not for proportional linear output.
Yahlasit
08/07/2009 9:05 PM
Rubbish its perfectly fine I have used them many times for power regulation. Go and study MOSFETs circuits some more.
Garth
08/07/2009 1:17 PM
The key words are "12 volt" and "car". Lets brute force this and just wire tailight bulbs in parallel to get the wattage to power it and then add them in series to change the temperature needed. Headlights could be used since they are higher amperage (resistors).
The added plus is that they can also be used as work ilumination!
08/07/2009 9:22 PM
Regards.
Is it an AC or DC operated?
If AC put a diode in series & a push button NO [Normally open] in parallel to diode; on handle.
Iron will have nearly half the voltage [one 1/2 cycle on 1 off]
Push to solder & release to standby.
In case of DC Pot will not do unless it is at least 20W & you have to select its value for your optimum requirement.
08/08/2009 12:30 AM
dc. I'm going to run the soldering pencil/iron off of the cigarette lighter socket (whats the proper name for these?) in my car.
i just want a real simple (cheap) solution, a solution were i can buy everything i need from radioshack (no other electronics store near by)
Good Answers: 68
08/09/2009 10:38 AM
Hello vn,
I have found a complete circuit and switch for your iron. I have not read any other posts so please forgive me if this has been posts already.
Can you please let me know if it is suitable for your use? Tell me what country you live in and I will try and find another if this does not suit. Take care.
Home > Kits > Power Supply Kits
0-12V Variable Power Supply Kit
Item Number : C6724
Unit Price: $11.05
Quantity
Refer this page to a friend
Detailed Description
This is one of the most inexpensive and reliable power supply kits on the market today! It is ideal for powering breadboard experiments, small tape recorders, radios, amplifiers, calculators and various electronic projects. This kit features a transformer, a circuit protecting fuse, a power transistor, full-wave rectification, two radial electrolytic capacitors , an LED power indicator, On/ Off switch, a potentiometer and other components. This power supply has a reliable circuit design with momentarily short circuit protection. Power supply outputs a maximum current of 125mA@12V and 200mA@10V or less. Size of board: 3 1/2'' x 2''. Complete with all parts, PC board and instructions. Skill Level 2. This kit requires soldering of components to the PC board while building.
C6724
Manufactured by Chaney Electronics
OPTIONAL PLASTIC BOX FOR THIS KIT
C6365
Type 3 Plastic Box$2.95
08/09/2009 11:40 AM
sorry, but not what i was looking for. the input voltage would have to be around 12 volts, not the output. I'm trying to power my soldering iron using a car 12 volt cigarette socket. my problem has been fixed already though. but thank you for trying to help :)
Good Answers: 119
08/09/2009 1:27 PM
Wouldn't work to power the iron off AC. Although a nice little power supply, current is too low @ 0.125A. Project needed 12V @ 2.5A.
Good Answers: 68
08/10/2009 2:56 AM
Hi mjb,
Thanks for the nice reply.
I realised about an hour after I sent the answer in that I had made a mistake. My usual mistake of not reading the request correctly!. Sorry to you and all!
I do not know what the iron is used for, but, there is some really handy gas powered 'pen' type irons around which may have been better?
Thanks again
bb
08/09/2009 8:32 PM
Many years ago I ran across a circuit for precisely controlling the temperature of a heater by measuring the resistance of the heater during the AC zero crossing, and controlling the phase shift triggering of a triac. I have been looking for this circuit ever since to no avail, anybody know of it?
Thought occurred to me that the chopper circuit/s provided as good answers could incorporate such a circuit for measuring the heater resistance during the "Off" time of the switch, modifying the PWM to accurately control the temp of the soldering iron (Excuse me "Pencil"). Also perhaps incorporating a display of the temp as a function of the controller circuit.
Regards CEKM
Good Answers: 68
In reply to #59
08/10/2009 3:03 AM
Hello CEKM,
Sounds interesting!
I have searched and found this page if you would like to view it?
http://www.google.com/search?client=safari&rls=en-gb&q=control+circuit+measuring+the+%22AC%22+crossing&ie=UTF-8&oe=UTF-8
Take care.
08/19/2009 12:17 AM
Thanks for the info, I'll check out those sites.
regards CEKM
08/17/2009 12:32 PM
Consider the following
1. Try an iron with temp controlled tip.
2. Yes make sure the pot is rated to carry the current of approx 3 amps.
3.How to check the temprature
4.heating effect proportional to square of current and or voltage.
5.pot should not be linear but wound to square law.
6 lifes too short see 1 !
In reply to #64
08/17/2009 2:28 PM
Have you ever seen a temperature controlled soldering pencil that ran on 12VDC?
Good Answers: 12
In reply to #65
08/17/2009 3:40 PM
I actually have a home brewed 12VDC "pencil"...has outlast all my soldering irons that ran on 240VAC
CraziestOzzy
In reply to #65
08/19/2009 10:06 AM
Yes!!!
The good tips have a magnet in them that holds a contact together and supplies current. When the temperature is reached where the magnetism is gone, a spring separates the contacts and removes current....
A very well known company called Weller, used this system with a mains to 12 volt transformer for years!
The tips are stamped with the temperature that the magnet drops out at.....I would guess they are still available.....not having personally tried though.....
They will work fine on 12 volts DC too....
BUT, I like the PWM approach better as you could calibrate the pot to select the temperature you wish.....whereas the Weller approach, you need to swap bits for different temps....
Hobbies - Musician - Tube Amps Only Please!
10/30/2009 8:17 PM
Sounds like you need to upgrade to an iron with temp. control. Not that expensive.
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
Register to Reply 69 comments
Andy Germany (1); Anonymous Poster (10); babybear (4); CraziestOzzy (2); dkwarner (6); garth (2); Haajee (1); Mac9 (1); maveric_manic (1); mjb1962853 (13); PWSlack (1); rakesh_semwal (8); sb (1); tropicalspeed (4); visible noise (12)
