Previous in Forum: TIG Welding   Next in Forum: Sheet Metal Factory
Hot Forming
08/16/2009 11:01 PM
Dear All Members,
I want to design C/S + S/Sclad Vessel (SA 516 Gr. 70N + SS 316L). when calculated, 2:1 ellipse head have >5% of fiber elongation. As per ASME UCS-79, this head required stress relief but according to our client spec, stress relief should be replace with Normalising. In this regard, i think want to perform head by using hot forming. After check with supplier, they said temperature for hot forming not reach normalising temperature.
So, i need to do normalising treatment again to reduce fiber elongation? Matl can be with this temperature>
Could anyone advice us regarding this matter.
Thank you.
Re: Hot Forming
08/18/2009 4:37 AM
Normalizing is appropriate for CS but for SS part should be solution annealing. In similar situation (Clad vessel for high pressure service) stress releiving at a temperature lower than critical temperature with increased soaking time had been done.
You might be interested in: Tube End Forming Machines
