I have been unsucessful in finding a simple cross listing whereby I can specify wire sizes in metric when the original calculations were done for AWG wire sizes. Anybody know where I can find it?
The problem is twofold. LLoyds of London engineers require me to specify a wire size that does not produce more than a 3% voltage drop. Simple! right?? Except when I convert to a metric size I discover the size is not a normal wire size readily available. Going to the next size up that is commercially available is playing it safe but the customer will howl at the greatly increased cost. And the next commercial size up is so oversized it gives less than 2% loss. Way more than what is required.
Then I discover there is also a discrepancy that is apparently related to the temperature rating of the insulation. My AWG tables say #16 Ga is good for 10A. But my euro tables state for 10Amp I need to use a 1.5mm2 size. The conversion table indicates a 1.5mm2 wire is close to a #14 AWG which in North American usage is good for 15A which is 50% higher. And both of these wires are supposedly rated for 85C temp. What gives?
