Previous in Forum: GE WAY !   Next in Forum: Pump calibration column
24 comments
Marshall speakers 100w 4 x 12 any good for a hi fi?
08/23/2009 5:23 AM
My boys want to make a up a play room with a stereo system made up of Marshall guitar speakers 4 x 12,they can also be used for playing a guitar through am I mad or is this a good idea?
We can make a difference,e mail me and make it happen.
Location: Currently on break at home in Houston, Texas USA
Re: Marshall speakers 100w 4 x 12 any good for a hi fi?
08/23/2009 8:17 AM
Billy Joel once wrote a song about listening to rock and roll thru a "cheap set of speakers". I guarantee that it will be LOUD. So, the system will probably be a little lack-luster at low volumes especially when listening to such programs as St. Martin in the Fields. I sure hope the playroom is in the basement or in the garage and well insulated at that. Kids - yeah, well.........
08/23/2009 8:47 AM
Hi Buddy So at reasonable volume we could get a decent sound or do you think it would be pants?#
08/24/2009 12:59 PM
Because these are guitar speakers, I believe the roll-off of lower freqs. will be somewhat evident. With enough power, these cabinets will ROCK.
You will probably need some tweeters with a simple capacitor-coupling to keep the lower freqs from the tweeter. Hey, won't hurt to give it a try.......
08/24/2009 5:48 PM
Long time ago I had to move from parental home to bedsitland - which meant selling off my Marshall guitar amp & stack.
When a prospective buyer came, I'd connected the Marshall to the line out of my hi-fi amp, put "Who do you love?", by Juicy Lucy on the turntable and turned it up.
Sold before the vocals started. Price offered doubled when the first bottleneck break started.
You won't get hi-fi, but the kids'll love it!
Good Answers: 1693
08/23/2009 9:41 AM
You can use these speakers and get decent sound. For good reproduction of higher frequencies, you should throw in a couple of 2, 3or 4 inch speakers. The heavy mass of the 12" speakers won't allow them to reproduce the higher freqs.
Be sure that the speaker impedance matches the amplifier.
Party on!
Good Answers: 38
08/23/2009 10:48 AM
You might want to include a crossover to reduce the lower frequencies to the tweeters. Add an A/B switch to remove the tweeters when they play their guitars.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
08/23/2009 10:54 AM
I've just picked a up a 5 channel surround sound to go with a plasma tv to go in the same room, 100 watt rms per channel. I guess if we used the Marshalls for the side speakers we could use a voice speaker at the front and a couple of hi fi speakers to the rear and not have a need for a crossover......there speaks the voice of the man who has not a clue..
Good Answers: 1693
08/23/2009 11:50 AM
Kick around here, It may help:
The Thiele-Small Loudspeaker Database
Good Answers: 1693
08/23/2009 11:54 AM
Kick around here:
It will help. AH is right, designing enclosures is extremely complex.
Good Answers: 918
08/23/2009 11:45 AM
Sorry, those drivers will not be of very much use for HiFi.
The resonance frequency of the drivers will be too high to yield any real bass response and generally, any sound reinforcement (commercial) drivers will not give you faithful reproduction of music. Not to mention that the speakers will also lack treble.
On the flip side, if you don't care about the sound, why not? Running guitar through HiFi rated speakers will most likely send them to an early grave (they may send you to one, too), so using instrument rated drivers will prevent that.
Your best bet is to keep the four 12s and use them only for guitar with a dedicated guitar amp. Then build a set of cabinets with drivers just for the stereo. This way you can have the best of both worlds and a lot more flexibility in the end.
Speaker building is a lot of fun, but it is much more involved than you could ever imagine on a technical basis. That is, if you expect to get reasonable sound quality you will find the subject is deeply technical if you go at it totally as a DIY project and design the box and crossovers.
However, I would highly recommend Madisound's Recession Buster Speaker Kit. They have done all the design work and crossover design.
The kit is $60 and includes everything you need to build a good stereo speaker system except the wood, screws, and connectors. You can't go wrong for a first project!
It would be a great project for you and the kids to do together and you will learn something fun.
08/23/2009 12:02 PM
They will work, but they are no where near hi-fi quality. The cones are too stiff to reproduce the full dynamic range. At high volume levels, the amplifier could "clip" and even shut down. Those Marshal's were just not designed for hi-fi use. Guitar amps use vacuum tubes to produce lots of db's, something a solid state amp can't do with good fidelity.
Mr.Ron from South Ms.
Good Answers: 918
08/23/2009 4:45 PM
You are mostly right.
However, it is not the stiffness of the cone, but the suspension compliance and voice coil/magnet geometry. I suspect that you were trying to sum that up with overall stiffness.
One thing about instrument speaker drivers is that they tend to be much more efficient than HiFi drivers, so you are likely to get more volume from one of the Marshal 12" speakers than you would with a good 12" stereo driver. The difference is the spectrum where they reproduce sound.
Lastly, vacuum tube amps generally produce much lower power levels than today's solid state amps. I am building a stereo tube amp as I write which uses four high power KT88 power tubes (two per channel), which will produce about 60 Watts per channel. My little Harman Kardon audio-video amp has 70 Watts per channel and 6 channels to boot.
While I am not a solid state amp fan (mostly for nostalgia reasons), I'll bet for any great tube amp you can cite I can show you a solid state amp that will beat those performance specs. The Quad 909 Current Dumping amp comes to mind here.
Additionally, solid state amps have much higher wattages. 1,000 Watts of output power into 4 Ohms is nothing for solid state. Solid state amps are lighter, more reliable, and do not change over time like tubes age.
As an engineer I have a "show-me the data" attitude and do not like to talk in subjective psychoacoustic terms. Still, I have to admit that for whatever reason, tubes seem to sound better to my ears, but I really do not want to go into that argument! ;-)
Musicians like tube amps because of the overdrive distortion they produce and it gives a unique sound to their instrument versus what you get when you overdrive solid state gear.
Anyway, I am off on a tangent here and marked my thread as such.
08/23/2009 7:12 PM
Amen, the best rock comes from tubes!
Good Answers: 981
08/23/2009 4:59 PM
Ronseto and AH,
You both get a GA from me. Electric guitar speakers will not produce anything close to High Fidelity quality. High fidelity tends to be what musicians call a colorless sound. High Fidelity strides to reproduce the sound as unaltered as possible. Guitar speakers and cabinets are deliberately colored by having a resonant frequency and other attributes to give the musician the tone he/she desires This is why one musician prefers a Marshall speaker stack over a HiWatt or Fender etc. The same is true for the tube amplifiers used to drive these speakers. Also tube guitar amplifiers are designed to deliberately distort when desired in the front end or output drive of the amplifier depending on the settings chosen by the musician. High Fidelity amplifiers should not distort the sound unless the sound is way too loud.
But as someone said, you will get sound using these speakers and presumably a lot of sound. But it will sound more like sound through a conical megaphone at times.
08/23/2009 5:37 PM
Hi Team I am amazed by the response and I am very grateful . What do I do.... the cross over kit looks like it might do the job (but i 'll have to get it shipped over UK),it may sound pants but it would look brilliant... what a dilemma? This is a boys room and what would you have dreamed of when you were 15 years old,looks like the Marshall cabinets are on the way!!! I am very grateful for all your inputs. thank you
08/23/2009 7:18 PM
Why not find a Marshall full stack cab and but stereo speakers in it.
Or even better get two Marshall full stack cabs, put stereo speakers in the bottom half, and guitar speakers in the top half then attach the guitar amp to the top half speakers, and the stereo to the bottom half speakers. You could probably fit tweeters in the cab as well.
Then you would be good either way. Just make sure to match impedance.
That would rock....
08/24/2009 11:16 AM
By "stereo", I think you mean hi-fi or a speaker capable of producing sounds in high fidelity. Hi-fi speakers and enclosures have to be designed as an integral unit. Putting a hi-fi- speaker in a cabinet designed for another speaker, will not produce a hi-fi sound.
08/24/2009 7:15 PM
Yes, but have you listened to the music that kids are into today. Hi Fi is not necessary.....
In this case the only issue is not blowing out speakers I think. I am starting lean back toward the idea that the Marshall speakers will do fine....
Hobbies - Musician - Tube Amps Only Please!
08/24/2009 12:32 AM
As a Guitar player and amp designer it would be better to buy a 5.1 surround sound 200W with all the speakers and have a better than stereo system. RCA has a 200W unit for about $100 @ Wallmart. I put (2) together for 400W. The Marshall cabinet is really a guitar speaker and is not Hi Fi because it does not cover the full frequency spectrum 20-20kHz. It will not sound good and it is worth a lot of money if you sell it to a musician. It is for a Marshall 100W head or amplifier which if you have that is very suited for guitar playing. If it is a cabinet it is also monaural so it is not stereo.
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
08/24/2009 1:01 AM
So where are you moving too ???
Head phones are someting to consider in the same house with you or maybe a barn about 2 miles from the house for your son to do what he wants. As long as the cops never are called for noise.
Good Answers: 70
08/24/2009 10:18 AM
I've been out of the music biz for too long now, but I do remember that you can buy small piezoelectric tweeters for ~$10 (I think Radio Shack has them) that will add some high frequencies that the 12" speakers won't reproduce. If I remember correctly they don't require crossovers. This won't be hi-fi, but it will be noticeably better, and it will be hard to beat for price and simplicity. If you want to get fancy you can mount them in your half-stack (in the unused space around the speakers) using a circular door-knob saw in your electric drill, and include an on-off switch to disconnect them when playing guitar.
http://members.misty.com/don/pzfix.html
08/24/2009 2:17 PM
Whatta opportunity...! Thisizza Engineering Forum, yes? Give the boys a real head start, here. They want BIG sound, no? Get out yer jig-saws, caulking guns and pipe clamps, and work on some "Variations-on-this-theme":
http://passdiy.com/pdf/KleinHorn.pdf
http://www.passdiy.com/pdf/KleinHorn2.pdf
They'll be the envy of the county, and you'll be the best Dad in the wurld...!
Good Answers: 981
08/24/2009 3:00 PM
Now that's a pair of horns!. An excellent pair of write ups, too. Please, oh please register with this forum. This is precisely the spirit we need. (No offence meant to the rest of us.)
08/28/2009 12:12 PM
Those Klein horns are really impressive to look at. I can only imagine what they sound like. I can see the resemblance to a Klein bottle. Back in the early 50's, when high fidelity was emerging and stereo was still a long way off, I was a student (not actually) of G.A.Briggs, the renowned British designer of loudspeakers. In those days, hi-fi sound meant a lot of experimenting with raw materials and relatively low power electronics. One of my projects was putting a Wharfdale woofer in a folded horn enclosure. The enclosure was made from 3/4" plywood. The speaker was a direct radiator mounted on a speaker board composed of two pieces of plywood with a sand core to reduce the resonance. In those days I can remember my first amplifier was a Bogen PH-10 with 6V6's in push/pull operation. I fooled around with stereo tape recording and binaural sound. I was going to school at the time, but not to study audio or sound engineering. I have followed the progress and trends in sound engineering up to the present. Unfortunately finances has always kept me away from the real high end equipment, so I have had to make do with what I could. I still enjoy hearing a Bach Fugue blasting out at me with gut rumbling bass. Welcome to this forum. Hope to hear from you soon.
Register to Reply 24 comments
Anonymous Hero (2); Anonymous Poster (1); charsley99 (1); dadw5boys (1); JohnDG (1); johnfotl (1); lyn (3); martin clack (3); maveric_manic (1); redfred (2); ronseto (3); Steve S. (3); tropicalspeed (2)
